Versions etc:
richard@akl-host6:~$ sudo lxc-start --version
4.0.6
richard@akl-host6:~$ sudo lxc-checkconfig
LXC version 4.0.6
— Namespaces —
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
— Control groups —
Cgroups: enabled
Cgroup v1 mount points:
Cgroup v2 mount points:
/sys/fs/cgroup
Cgroup v1 systemd controller: missing
Cgroup v1 freezer controller: missing
Cgroup namespace: required
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled
— Misc —
Veth pair device: enabledlibkmod: ERROR …/libkmod/libkmod-module.c:1668 kmod_module_new_from_loaded: could not open /proc/modules: No such file or directory
Error: could not get list of modules: No such file or directory
, not loaded
Macvlan: enabledlibkmod: ERROR …/libkmod/libkmod-module.c:1668 kmod_module_new_from_loaded: could not open /proc/modules: No such file or directory
, not loaded
Vlan: enabledlibkmod: ERROR …/libkmod/libkmod-module.c:1668 kmod_module_new_from_loaded: could not open /proc/modules: No such file or directory
, not loaded
Bridges: enabledlibkmod: ERROR …/libkmod/libkmod-module.c:1668 kmod_module_new_from_loaded: could not open /proc/modules: No such file or directory
, not loaded
Advanced netfilter: enabledlibkmod: ERROR …/libkmod/libkmod-module.c:1668 kmod_module_new_from_loaded: could not open /proc/modules: No such file or directory
, not loaded
CONFIG_NF_NAT_IPV4: missing
CONFIG_NF_NAT_IPV6: missing
CONFIG_IP_NF_TARGET_MASQUERADE: enabledlibkmod: ERROR …/libkmod/libkmod-module.c:1668 kmod_module_new_from_loaded: could not open /proc/modules: No such file or directory
, not loaded
CONFIG_IP6_NF_TARGET_MASQUERADE: enabledlibkmod: ERROR …/libkmod/libkmod-module.c:1668 kmod_module_new_from_loaded: could not open /proc/modules: No such file or directory
, not loaded
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabledlibkmod: ERROR …/libkmod/libkmod-module.c:1668 kmod_module_new_from_loaded: could not open /proc/modules: No such file or directory
, not loaded
CONFIG_NETFILTER_XT_MATCH_COMMENT: enabledlibkmod: ERROR …/libkmod/libkmod-module.c:1668 kmod_module_new_from_loaded: could not open /proc/modules: No such file or directory
, not loaded
FUSE (for use with lxcfs): enabledlibkmod: ERROR …/libkmod/libkmod-module.c:1668 kmod_module_new_from_loaded: could not open /proc/modules: No such file or directory
, not loaded
— Checkpoint/Restore —
checkpoint restore: missing
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities:
richard@akl-host6:~$ uname -a
Linux akl-host6.backend.net.nz 5.10.0-really170-rh178-20230226002031.xenU.x86_64 #1 SMP Sun Feb 26 00:21:44 UTC 2023 x86_64 GNU/Linux
richard@akl-host6:~$ sudo cat /proc/self/cgroup
0::/user.slice/user-1001.slice/session-6.scope
richard@akl-host6:~$ cat /proc/1/mounts ## mounts for other containers redacted
/dev/root / ext4 rw,relatime 0 0
devtmpfs /dev devtmpfs rw,relatime,size=2186448k,nr_inodes=546612,mode=755 0 0
proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0
sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /run tmpfs rw,nosuid,nodev,size=875780k,nr_inodes=819200,mode=755 0 0
tmpfs /run/lock tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k 0 0
cgroup2 /sys/fs/cgroup cgroup2 rw,nosuid,nodev,noexec,relatime 0 0
none /sys/fs/bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 0 0
hugetlbfs /dev/hugepages hugetlbfs rw,relatime,pagesize=2M 0 0
mqueue /dev/mqueue mqueue rw,nosuid,nodev,noexec,relatime 0 0
fusectl /sys/fs/fuse/connections fusectl rw,nosuid,nodev,noexec,relatime 0 0
configfs /sys/kernel/config configfs rw,nosuid,nodev,noexec,relatime 0 0
/dev/mapper/vgssd0-LD1rh–wptest2 /guestfs/rh-wptest2-srv xfs rw,relatime,attr2,inode64,logbufs=8,logbsize=32k,noquota 0 0
/dev/mapper/vgssd0-LRrh–wptest2 /var/lib/lxc/rh-wptest2/rootfs xfs rw,relatime,attr2,inode64,logbufs=8,logbsize=32k,noquota 0 0
lxcfs /var/lib/lxcfs fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other 0 0
tmpfs /run/user/1001 tmpfs rw,nosuid,nodev,relatime,size=437888k,nr_inodes=109472,mode=700,uid=1001,gid=1001 0 0
