Lxc export: "Snapshot ... in storage but not expected"
After some recent upgrades (ubuntu 18.04 → 20.04, lxd 4.10 → lxd 4.15), my custom backup script fails while exporting (at least) one container:
$ lxc export --optimized-storage blog blogbackup
Error: Create backup: Backup create: Snapshot "snap23" in storage but not expected
From lxc info:
Snapshots:
  snap0 (taken at 2017/09/13 11:31 UTC) (stateless)
  snap1 (taken at 2017/09/18 11:35 UTC) (stateless)
  before-v3.8 (taken at 2018/07/24 15:07 UTC) (stateless)
  before-fixing-certbot (taken at 2018/09/22 15:00 UTC) (stateless)
  after-fixing-certbot (taken at 2018/09/22 15:22 UTC) (stateless)
  finally-fixed (taken at 2019/11/19 20:19 UTC) (stateless)
  snap116 (taken at 2021/05/15 04:18 UTC) (expires at 2021/08/07 04:18 UTC) (stateless)
  snap117 (taken at 2021/05/22 04:18 UTC) (expires at 2021/08/14 04:18 UTC) (stateless)
  snap118 (taken at 2021/05/29 04:18 UTC) (expires at 2021/08/21 04:18 UTC) (stateless)
  snap119 (taken at 2021/06/05 04:18 UTC) (expires at 2021/08/28 04:18 UTC) (stateless)
  snap120 (taken at 2021/06/12 04:18 UTC) (expires at 2021/09/04 04:18 UTC) (stateless)
  snap121 (taken at 2021/06/19 04:18 UTC) (expires at 2021/09/11 04:18 UTC) (stateless)
  snap122 (taken at 2021/06/26 04:18 UTC) (expires at 2021/09/18 04:18 UTC) (stateless)
  snap123 (taken at 2021/07/03 04:18 UTC) (expires at 2021/09/25 04:18 UTC) (stateless)
  snap124 (taken at 2021/07/10 04:18 UTC) (expires at 2021/10/02 04:18 UTC) (stateless)
  snap125 (taken at 2021/07/17 04:18 UTC) (expires at 2021/10/09 04:18 UTC) (stateless)
  snap126 (taken at 2021/07/24 04:18 UTC) (expires at 2021/10/16 04:18 UTC) (stateless)
  snap127 (taken at 2021/07/31 04:18 UTC) (expires at 2021/10/23 04:18 UTC) (stateless)
on disk:
$ sudo ls -l /mnt/ssdbtrfs/lxd/containers-snapshots/blog/
total 0
drwxr-xr-x+ 1  100000 100000 78 Nov 28  2018 after-fixing-certbot
drwxr-xr-x+ 1  100000 100000 78 Nov 28  2018 before-fixing-certbot
drwxr-xr-x+ 1  100000 100000 78 Nov 28  2018 before-v3.8
d--x------+ 1 1000000 root   78 Nov 28  2018 finally-fixed
drwxr-xr-x+ 1  100000 100000 78 Nov 28  2018 snap0
drwxr-xr-x+ 1  100000 100000 78 Nov 28  2018 snap1
d--x------+ 1 1000000 root   78 Nov 28  2018 snap116
d--x------+ 1 1000000 root   78 Nov 28  2018 snap117
d--x------+ 1 1000000 root   78 Nov 28  2018 snap118
d--x------+ 1 1000000 root   78 Nov 28  2018 snap119
d--x------+ 1 1000000 root   78 Nov 28  2018 snap120
d--x------+ 1 1000000 root   78 Nov 28  2018 snap121
d--x------+ 1 1000000 root   78 Nov 28  2018 snap122
d--x------+ 1 1000000 root   78 Nov 28  2018 snap123
d--x------+ 1 1000000 root   78 Nov 28  2018 snap124
d--x------+ 1 1000000 root   78 Nov 28  2018 snap125
d--x------+ 1 1000000 root   78 Nov 28  2018 snap126
d--x------+ 1 1000000 root   78 Nov 28  2018 snap127
drwx--x--x+ 1 root    root   78 Nov 28  2018 snap23
drwx--x--x+ 1 root    root   78 Nov 28  2018 snap24
drwx--x--x+ 1 root    root   78 Nov 28  2018 snap25
I suppose there has been a permission problem in LXD some (long) time ago that resulted in some older snapshots having the wrong permissions and could therefore not be properly deleted. I suppose I can just manually delete those on-disk remnants without breaking anything else?
(storage is btrfs, which is marvelous for LXD)
Yeah, you should just go ahead and delete snap23, snap24 and snap25 from the filesystem, that should take care of it.
Thanks for your quick response. (which I did not even expect on a Sunday!)
