cat cloud-init.log
2021-03-06 13:56:01,983 - util.py[DEBUG]: Cloud-init v. 20.4.1-0ubuntu1~20.10.1 running 'modules:config' at Sat, 06 Mar 2021 13:56:01 +0000. Up 46.60 seconds.
2021-03-06 13:56:02,035 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.ubuntu.Distro'>
2021-03-06 13:56:02,037 - stages.py[DEBUG]: Running module emit_upstart (<module 'cloudinit.config.cc_emit_upstart' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_emit_upstart.py'>) with frequency always
2021-03-06 13:56:02,038 - handlers.py[DEBUG]: start: modules-config/config-emit_upstart: running config-emit_upstart with frequency always
2021-03-06 13:56:02,039 - helpers.py[DEBUG]: Running config-emit_upstart using lock (<cloudinit.helpers.DummyLock object at 0xffffa42da370>)
2021-03-06 13:56:02,039 - cc_emit_upstart.py[DEBUG]: no /sbin/initctl located
2021-03-06 13:56:02,039 - cc_emit_upstart.py[DEBUG]: not upstart system, 'emit_upstart' disabled
2021-03-06 13:56:02,039 - handlers.py[DEBUG]: finish: modules-config/config-emit_upstart: SUCCESS: config-emit_upstart ran successfully
2021-03-06 13:56:02,039 - stages.py[DEBUG]: Running module snap (<module 'cloudinit.config.cc_snap' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_snap.py'>) with frequency once-per-instance
2021-03-06 13:56:02,040 - handlers.py[DEBUG]: start: modules-config/config-snap: running config-snap with frequency once-per-instance
2021-03-06 13:56:02,040 - helpers.py[DEBUG]: config-snap already ran (freq=once-per-instance)
2021-03-06 13:56:02,041 - handlers.py[DEBUG]: finish: modules-config/config-snap: SUCCESS: config-snap previously ran
2021-03-06 13:56:02,041 - stages.py[DEBUG]: Running module ssh-import-id (<module 'cloudinit.config.cc_ssh_import_id' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_ssh_import_id.py'>) with frequency once-per-instance
2021-03-06 13:56:02,041 - handlers.py[DEBUG]: start: modules-config/config-ssh-import-id: running config-ssh-import-id with frequency once-per-instance
2021-03-06 13:56:02,042 - helpers.py[DEBUG]: config-ssh-import-id already ran (freq=once-per-instance)
2021-03-06 13:56:02,042 - handlers.py[DEBUG]: finish: modules-config/config-ssh-import-id: SUCCESS: config-ssh-import-id previously ran
2021-03-06 13:56:02,042 - stages.py[DEBUG]: Running module locale (<module 'cloudinit.config.cc_locale' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_locale.py'>) with frequency once-per-instance
2021-03-06 13:56:02,043 - handlers.py[DEBUG]: start: modules-config/config-locale: running config-locale with frequency once-per-instance
2021-03-06 13:56:02,043 - helpers.py[DEBUG]: config-locale already ran (freq=once-per-instance)
2021-03-06 13:56:02,043 - handlers.py[DEBUG]: finish: modules-config/config-locale: SUCCESS: config-locale previously ran
2021-03-06 13:56:02,044 - stages.py[DEBUG]: Running module set-passwords (<module 'cloudinit.config.cc_set_passwords' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_set_passwords.py'>) with frequency once-per-instance
2021-03-06 13:56:02,044 - handlers.py[DEBUG]: start: modules-config/config-set-passwords: running config-set-passwords with frequency once-per-instance
2021-03-06 13:56:02,044 - helpers.py[DEBUG]: config-set-passwords already ran (freq=once-per-instance)
2021-03-06 13:56:02,045 - handlers.py[DEBUG]: finish: modules-config/config-set-passwords: SUCCESS: config-set-passwords previously ran
2021-03-06 13:56:02,045 - stages.py[DEBUG]: Running module grub-dpkg (<module 'cloudinit.config.cc_grub_dpkg' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_grub_dpkg.py'>) with frequency once-per-instance
2021-03-06 13:56:02,046 - handlers.py[DEBUG]: start: modules-config/config-grub-dpkg: running config-grub-dpkg with frequency once-per-instance
2021-03-06 13:56:02,046 - helpers.py[DEBUG]: config-grub-dpkg already ran (freq=once-per-instance)
2021-03-06 13:56:02,046 - handlers.py[DEBUG]: finish: modules-config/config-grub-dpkg: SUCCESS: config-grub-dpkg previously ran
2021-03-06 13:56:02,047 - stages.py[DEBUG]: Running module apt-pipelining (<module 'cloudinit.config.cc_apt_pipelining' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_apt_pipelining.py'>) with frequency once-per-instance
2021-03-06 13:56:02,047 - handlers.py[DEBUG]: start: modules-config/config-apt-pipelining: running config-apt-pipelining with frequency once-per-instance
2021-03-06 13:56:02,047 - helpers.py[DEBUG]: config-apt-pipelining already ran (freq=once-per-instance)
2021-03-06 13:56:02,048 - handlers.py[DEBUG]: finish: modules-config/config-apt-pipelining: SUCCESS: config-apt-pipelining previously ran
2021-03-06 13:56:02,048 - stages.py[DEBUG]: Running module apt-configure (<module 'cloudinit.config.cc_apt_configure' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_apt_configure.py'>) with frequency once-per-instance
2021-03-06 13:56:02,048 - handlers.py[DEBUG]: start: modules-config/config-apt-configure: running config-apt-configure with frequency once-per-instance
2021-03-06 13:56:02,049 - helpers.py[DEBUG]: config-apt-configure already ran (freq=once-per-instance)
2021-03-06 13:56:02,049 - handlers.py[DEBUG]: finish: modules-config/config-apt-configure: SUCCESS: config-apt-configure previously ran
2021-03-06 13:56:02,049 - stages.py[DEBUG]: Running module ubuntu-advantage (<module 'cloudinit.config.cc_ubuntu_advantage' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_ubuntu_advantage.py'>) with frequency once-per-instance
2021-03-06 13:56:02,050 - handlers.py[DEBUG]: start: modules-config/config-ubuntu-advantage: running config-ubuntu-advantage with frequency once-per-instance
2021-03-06 13:56:02,050 - helpers.py[DEBUG]: config-ubuntu-advantage already ran (freq=once-per-instance)
2021-03-06 13:56:02,051 - handlers.py[DEBUG]: finish: modules-config/config-ubuntu-advantage: SUCCESS: config-ubuntu-advantage previously ran
2021-03-06 13:56:02,051 - stages.py[DEBUG]: Running module ntp (<module 'cloudinit.config.cc_ntp' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_ntp.py'>) with frequency once-per-instance
2021-03-06 13:56:02,051 - handlers.py[DEBUG]: start: modules-config/config-ntp: running config-ntp with frequency once-per-instance
2021-03-06 13:56:02,052 - helpers.py[DEBUG]: config-ntp already ran (freq=once-per-instance)
2021-03-06 13:56:02,052 - handlers.py[DEBUG]: finish: modules-config/config-ntp: SUCCESS: config-ntp previously ran
2021-03-06 13:56:02,052 - stages.py[DEBUG]: Running module timezone (<module 'cloudinit.config.cc_timezone' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_timezone.py'>) with frequency once-per-instance
2021-03-06 13:56:02,053 - handlers.py[DEBUG]: start: modules-config/config-timezone: running config-timezone with frequency once-per-instance
2021-03-06 13:56:02,053 - helpers.py[DEBUG]: config-timezone already ran (freq=once-per-instance)
2021-03-06 13:56:02,053 - handlers.py[DEBUG]: finish: modules-config/config-timezone: SUCCESS: config-timezone previously ran
2021-03-06 13:56:02,053 - stages.py[DEBUG]: Running module disable-ec2-metadata (<module 'cloudinit.config.cc_disable_ec2_metadata' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_disable_ec2_metadata.py'>) with frequency always
2021-03-06 13:56:02,054 - handlers.py[DEBUG]: start: modules-config/config-disable-ec2-metadata: running config-disable-ec2-metadata with frequency always
2021-03-06 13:56:02,054 - helpers.py[DEBUG]: Running config-disable-ec2-metadata using lock (<cloudinit.helpers.DummyLock object at 0xffffa42de430>)
2021-03-06 13:56:02,054 - cc_disable_ec2_metadata.py[DEBUG]: Skipping module named disable-ec2-metadata, disabling the ec2 route not enabled
2021-03-06 13:56:02,054 - handlers.py[DEBUG]: finish: modules-config/config-disable-ec2-metadata: SUCCESS: config-disable-ec2-metadata ran successfully
2021-03-06 13:56:02,055 - stages.py[DEBUG]: Running module runcmd (<module 'cloudinit.config.cc_runcmd' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_runcmd.py'>) with frequency once-per-instance
2021-03-06 13:56:02,055 - handlers.py[DEBUG]: start: modules-config/config-runcmd: running config-runcmd with frequency once-per-instance
2021-03-06 13:56:02,056 - helpers.py[DEBUG]: config-runcmd already ran (freq=once-per-instance)
2021-03-06 13:56:02,056 - handlers.py[DEBUG]: finish: modules-config/config-runcmd: SUCCESS: config-runcmd previously ran
2021-03-06 13:56:02,056 - stages.py[DEBUG]: Running module byobu (<module 'cloudinit.config.cc_byobu' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_byobu.py'>) with frequency once-per-instance
2021-03-06 13:56:02,057 - handlers.py[DEBUG]: start: modules-config/config-byobu: running config-byobu with frequency once-per-instance
2021-03-06 13:56:02,057 - helpers.py[DEBUG]: config-byobu already ran (freq=once-per-instance)
2021-03-06 13:56:02,058 - handlers.py[DEBUG]: finish: modules-config/config-byobu: SUCCESS: config-byobu previously ran
2021-03-06 13:56:02,058 - main.py[DEBUG]: Ran 14 modules with 0 failures
2021-03-06 13:56:02,059 - atomic_helper.py[DEBUG]: Atomically writing to file /var/lib/cloud/data/status.json (via temporary file /var/lib/cloud/data/tmpsec7j1fb) - w: [644] 579 bytes/chars
2021-03-06 13:56:02,060 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2021-03-06 13:56:02,061 - util.py[DEBUG]: Read 13 bytes from /proc/uptime
2021-03-06 13:56:02,061 - util.py[DEBUG]: cloud-init mode 'modules' took 0.257 seconds (0.26)
2021-03-06 13:56:02,062 - handlers.py[DEBUG]: finish: modules-config: SUCCESS: running modules for config
2021-03-06 13:56:46,672 - util.py[DEBUG]: Cloud-init v. 20.4.1-0ubuntu1~20.10.1 running 'modules:final' at Sat, 06 Mar 2021 13:56:46 +0000. Up 60.69 seconds.
2021-03-06 13:56:46,720 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.ubuntu.Distro'>
2021-03-06 13:56:46,722 - stages.py[DEBUG]: Running module package-update-upgrade-install (<module 'cloudinit.config.cc_package_update_upgrade_install' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_package_update_upgrade_install.py'>) with frequency once-per-instance
2021-03-06 13:56:46,723 - handlers.py[DEBUG]: start: modules-final/config-package-update-upgrade-install: running config-package-update-upgrade-install with frequency once-per-instance
2021-03-06 13:56:46,723 - helpers.py[DEBUG]: config-package-update-upgrade-install already ran (freq=once-per-instance)
2021-03-06 13:56:46,723 - handlers.py[DEBUG]: finish: modules-final/config-package-update-upgrade-install: SUCCESS: config-package-update-upgrade-install previously ran
2021-03-06 13:56:46,723 - stages.py[DEBUG]: Running module fan (<module 'cloudinit.config.cc_fan' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_fan.py'>) with frequency once-per-instance
2021-03-06 13:56:46,724 - handlers.py[DEBUG]: start: modules-final/config-fan: running config-fan with frequency once-per-instance
2021-03-06 13:56:46,724 - helpers.py[DEBUG]: config-fan already ran (freq=once-per-instance)
2021-03-06 13:56:46,724 - handlers.py[DEBUG]: finish: modules-final/config-fan: SUCCESS: config-fan previously ran
2021-03-06 13:56:46,724 - stages.py[DEBUG]: Running module landscape (<module 'cloudinit.config.cc_landscape' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_landscape.py'>) with frequency once-per-instance
2021-03-06 13:56:46,725 - handlers.py[DEBUG]: start: modules-final/config-landscape: running config-landscape with frequency once-per-instance
2021-03-06 13:56:46,725 - helpers.py[DEBUG]: config-landscape already ran (freq=once-per-instance)
2021-03-06 13:56:46,725 - handlers.py[DEBUG]: finish: modules-final/config-landscape: SUCCESS: config-landscape previously ran
2021-03-06 13:56:46,725 - stages.py[DEBUG]: Running module lxd (<module 'cloudinit.config.cc_lxd' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_lxd.py'>) with frequency once-per-instance
2021-03-06 13:56:46,726 - handlers.py[DEBUG]: start: modules-final/config-lxd: running config-lxd with frequency once-per-instance
2021-03-06 13:56:46,726 - helpers.py[DEBUG]: config-lxd already ran (freq=once-per-instance)
2021-03-06 13:56:46,726 - handlers.py[DEBUG]: finish: modules-final/config-lxd: SUCCESS: config-lxd previously ran
2021-03-06 13:56:46,726 - stages.py[DEBUG]: Running module ubuntu-drivers (<module 'cloudinit.config.cc_ubuntu_drivers' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_ubuntu_drivers.py'>) with frequency once-per-instance
2021-03-06 13:56:46,727 - handlers.py[DEBUG]: start: modules-final/config-ubuntu-drivers: running config-ubuntu-drivers with frequency once-per-instance
2021-03-06 13:56:46,727 - helpers.py[DEBUG]: config-ubuntu-drivers already ran (freq=once-per-instance)
2021-03-06 13:56:46,727 - handlers.py[DEBUG]: finish: modules-final/config-ubuntu-drivers: SUCCESS: config-ubuntu-drivers previously ran
2021-03-06 13:56:46,727 - stages.py[DEBUG]: Running module puppet (<module 'cloudinit.config.cc_puppet' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_puppet.py'>) with frequency once-per-instance
2021-03-06 13:56:46,727 - handlers.py[DEBUG]: start: modules-final/config-puppet: running config-puppet with frequency once-per-instance
2021-03-06 13:56:46,728 - helpers.py[DEBUG]: config-puppet already ran (freq=once-per-instance)
2021-03-06 13:56:46,728 - handlers.py[DEBUG]: finish: modules-final/config-puppet: SUCCESS: config-puppet previously ran
2021-03-06 13:56:46,728 - stages.py[DEBUG]: Running module chef (<module 'cloudinit.config.cc_chef' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_chef.py'>) with frequency always
2021-03-06 13:56:46,728 - handlers.py[DEBUG]: start: modules-final/config-chef: running config-chef with frequency always
2021-03-06 13:56:46,729 - helpers.py[DEBUG]: Running config-chef using lock (<cloudinit.helpers.DummyLock object at 0xffff9a016430>)
2021-03-06 13:56:46,729 - cc_chef.py[DEBUG]: Skipping module named chef, no 'chef' key in configuration
2021-03-06 13:56:46,729 - handlers.py[DEBUG]: finish: modules-final/config-chef: SUCCESS: config-chef ran successfully
2021-03-06 13:56:46,729 - stages.py[DEBUG]: Running module mcollective (<module 'cloudinit.config.cc_mcollective' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_mcollective.py'>) with frequency once-per-instance
2021-03-06 13:56:46,730 - handlers.py[DEBUG]: start: modules-final/config-mcollective: running config-mcollective with frequency once-per-instance
2021-03-06 13:56:46,730 - helpers.py[DEBUG]: config-mcollective already ran (freq=once-per-instance)
2021-03-06 13:56:46,730 - handlers.py[DEBUG]: finish: modules-final/config-mcollective: SUCCESS: config-mcollective previously ran
2021-03-06 13:56:46,730 - stages.py[DEBUG]: Running module salt-minion (<module 'cloudinit.config.cc_salt_minion' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_salt_minion.py'>) with frequency once-per-instance
2021-03-06 13:56:46,731 - handlers.py[DEBUG]: start: modules-final/config-salt-minion: running config-salt-minion with frequency once-per-instance
2021-03-06 13:56:46,731 - helpers.py[DEBUG]: config-salt-minion already ran (freq=once-per-instance)
2021-03-06 13:56:46,731 - handlers.py[DEBUG]: finish: modules-final/config-salt-minion: SUCCESS: config-salt-minion previously ran
2021-03-06 13:56:46,731 - stages.py[DEBUG]: Running module reset_rmc (<module 'cloudinit.config.cc_reset_rmc' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_reset_rmc.py'>) with frequency once-per-instance
2021-03-06 13:56:46,731 - handlers.py[DEBUG]: start: modules-final/config-reset_rmc: running config-reset_rmc with frequency once-per-instance
2021-03-06 13:56:46,732 - helpers.py[DEBUG]: config-reset_rmc already ran (freq=once-per-instance)
2021-03-06 13:56:46,732 - handlers.py[DEBUG]: finish: modules-final/config-reset_rmc: SUCCESS: config-reset_rmc previously ran
2021-03-06 13:56:46,732 - stages.py[DEBUG]: Running module refresh_rmc_and_interface (<module 'cloudinit.config.cc_refresh_rmc_and_interface' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_refresh_rmc_and_interface.py'>) with frequency always
2021-03-06 13:56:46,732 - handlers.py[DEBUG]: start: modules-final/config-refresh_rmc_and_interface: running config-refresh_rmc_and_interface with frequency always
2021-03-06 13:56:46,732 - helpers.py[DEBUG]: Running config-refresh_rmc_and_interface using lock (<cloudinit.helpers.DummyLock object at 0xffff99fa3580>)
2021-03-06 13:56:46,733 - cc_refresh_rmc_and_interface.py[DEBUG]: No 'rmcctrl' in path, disabled
2021-03-06 13:56:46,733 - handlers.py[DEBUG]: finish: modules-final/config-refresh_rmc_and_interface: SUCCESS: config-refresh_rmc_and_interface ran successfully
2021-03-06 13:56:46,733 - stages.py[DEBUG]: Running module rightscale_userdata (<module 'cloudinit.config.cc_rightscale_userdata' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_rightscale_userdata.py'>) with frequency once-per-instance
2021-03-06 13:56:46,734 - handlers.py[DEBUG]: start: modules-final/config-rightscale_userdata: running config-rightscale_userdata with frequency once-per-instance
2021-03-06 13:56:46,734 - helpers.py[DEBUG]: config-rightscale_userdata already ran (freq=once-per-instance)
2021-03-06 13:56:46,734 - handlers.py[DEBUG]: finish: modules-final/config-rightscale_userdata: SUCCESS: config-rightscale_userdata previously ran
2021-03-06 13:56:46,734 - stages.py[DEBUG]: Running module scripts-vendor (<module 'cloudinit.config.cc_scripts_vendor' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_vendor.py'>) with frequency once-per-instance
2021-03-06 13:56:46,734 - handlers.py[DEBUG]: start: modules-final/config-scripts-vendor: running config-scripts-vendor with frequency once-per-instance
2021-03-06 13:56:46,735 - helpers.py[DEBUG]: config-scripts-vendor already ran (freq=once-per-instance)
2021-03-06 13:56:46,735 - handlers.py[DEBUG]: finish: modules-final/config-scripts-vendor: SUCCESS: config-scripts-vendor previously ran
2021-03-06 13:56:46,735 - stages.py[DEBUG]: Running module scripts-per-once (<module 'cloudinit.config.cc_scripts_per_once' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_per_once.py'>) with frequency once
2021-03-06 13:56:46,735 - handlers.py[DEBUG]: start: modules-final/config-scripts-per-once: running config-scripts-per-once with frequency once
2021-03-06 13:56:46,735 - helpers.py[DEBUG]: config-scripts-per-once already ran (freq=once)
2021-03-06 13:56:46,736 - handlers.py[DEBUG]: finish: modules-final/config-scripts-per-once: SUCCESS: config-scripts-per-once previously ran
2021-03-06 13:56:46,736 - stages.py[DEBUG]: Running module scripts-per-boot (<module 'cloudinit.config.cc_scripts_per_boot' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_per_boot.py'>) with frequency always
2021-03-06 13:56:46,736 - handlers.py[DEBUG]: start: modules-final/config-scripts-per-boot: running config-scripts-per-boot with frequency always
2021-03-06 13:56:46,736 - helpers.py[DEBUG]: Running config-scripts-per-boot using lock (<cloudinit.helpers.DummyLock object at 0xffff99fd8130>)
2021-03-06 13:56:46,737 - handlers.py[DEBUG]: finish: modules-final/config-scripts-per-boot: SUCCESS: config-scripts-per-boot ran successfully
2021-03-06 13:56:46,738 - stages.py[DEBUG]: Running module scripts-per-instance (<module 'cloudinit.config.cc_scripts_per_instance' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_per_instance.py'>) with frequency once-per-instance
2021-03-06 13:56:46,738 - handlers.py[DEBUG]: start: modules-final/config-scripts-per-instance: running config-scripts-per-instance with frequency once-per-instance
2021-03-06 13:56:46,738 - helpers.py[DEBUG]: config-scripts-per-instance already ran (freq=once-per-instance)
2021-03-06 13:56:46,739 - handlers.py[DEBUG]: finish: modules-final/config-scripts-per-instance: SUCCESS: config-scripts-per-instance previously ran
2021-03-06 13:56:46,739 - stages.py[DEBUG]: Running module scripts-user (<module 'cloudinit.config.cc_scripts_user' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_user.py'>) with frequency once-per-instance
2021-03-06 13:56:46,739 - handlers.py[DEBUG]: start: modules-final/config-scripts-user: running config-scripts-user with frequency once-per-instance
2021-03-06 13:56:46,739 - helpers.py[DEBUG]: config-scripts-user already ran (freq=once-per-instance)
2021-03-06 13:56:46,740 - handlers.py[DEBUG]: finish: modules-final/config-scripts-user: SUCCESS: config-scripts-user previously ran
2021-03-06 13:56:46,740 - stages.py[DEBUG]: Running module ssh-authkey-fingerprints (<module 'cloudinit.config.cc_ssh_authkey_fingerprints' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_ssh_authkey_fingerprints.py'>) with frequency once-per-instance
2021-03-06 13:56:46,740 - handlers.py[DEBUG]: start: modules-final/config-ssh-authkey-fingerprints: running config-ssh-authkey-fingerprints with frequency once-per-instance
2021-03-06 13:56:46,740 - helpers.py[DEBUG]: config-ssh-authkey-fingerprints already ran (freq=once-per-instance)
2021-03-06 13:56:46,741 - handlers.py[DEBUG]: finish: modules-final/config-ssh-authkey-fingerprints: SUCCESS: config-ssh-authkey-fingerprints previously ran
2021-03-06 13:56:46,741 - stages.py[DEBUG]: Running module keys-to-console (<module 'cloudinit.config.cc_keys_to_console' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_keys_to_console.py'>) with frequency once-per-instance
2021-03-06 13:56:46,741 - handlers.py[DEBUG]: start: modules-final/config-keys-to-console: running config-keys-to-console with frequency once-per-instance
2021-03-06 13:56:46,741 - helpers.py[DEBUG]: config-keys-to-console already ran (freq=once-per-instance)
2021-03-06 13:56:46,741 - handlers.py[DEBUG]: finish: modules-final/config-keys-to-console: SUCCESS: config-keys-to-console previously ran
2021-03-06 13:56:46,741 - stages.py[DEBUG]: Running module phone-home (<module 'cloudinit.config.cc_phone_home' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_phone_home.py'>) with frequency once-per-instance
2021-03-06 13:56:46,742 - handlers.py[DEBUG]: start: modules-final/config-phone-home: running config-phone-home with frequency once-per-instance
2021-03-06 13:56:46,742 - helpers.py[DEBUG]: config-phone-home already ran (freq=once-per-instance)
2021-03-06 13:56:46,742 - handlers.py[DEBUG]: finish: modules-final/config-phone-home: SUCCESS: config-phone-home previously ran
2021-03-06 13:56:46,742 - stages.py[DEBUG]: Running module final-message (<module 'cloudinit.config.cc_final_message' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_final_message.py'>) with frequency always
2021-03-06 13:56:46,743 - handlers.py[DEBUG]: start: modules-final/config-final-message: running config-final-message with frequency always
2021-03-06 13:56:46,743 - helpers.py[DEBUG]: Running config-final-message using lock (<cloudinit.helpers.DummyLock object at 0xffff99fd8070>)
2021-03-06 13:56:46,743 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2021-03-06 13:56:46,743 - util.py[DEBUG]: Read 13 bytes from /proc/uptime
2021-03-06 13:56:46,750 - util.py[DEBUG]: Cloud-init v. 20.4.1-0ubuntu1~20.10.1 finished at Sat, 06 Mar 2021 13:56:46 +0000. Datasource DataSourceNoCloud [seed=/dev/mmcblk0p1][dsmode=net]. Up 60.91 seconds
2021-03-06 13:56:46,750 - util.py[DEBUG]: Writing to /var/lib/cloud/instance/boot-finished - wb: [644] 69 bytes
2021-03-06 13:56:46,751 - handlers.py[DEBUG]: finish: modules-final/config-final-message: SUCCESS: config-final-message ran successfully
2021-03-06 13:56:46,752 - stages.py[DEBUG]: Running module power-state-change (<module 'cloudinit.config.cc_power_state_change' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_power_state_change.py'>) with frequency once-per-instance
2021-03-06 13:56:46,752 - handlers.py[DEBUG]: start: modules-final/config-power-state-change: running config-power-state-change with frequency once-per-instance
2021-03-06 13:56:46,752 - helpers.py[DEBUG]: config-power-state-change already ran (freq=once-per-instance)
2021-03-06 13:56:46,753 - handlers.py[DEBUG]: finish: modules-final/config-power-state-change: SUCCESS: config-power-state-change previously ran
2021-03-06 13:56:46,753 - main.py[DEBUG]: Ran 22 modules with 0 failures
2021-03-06 13:56:46,754 - atomic_helper.py[DEBUG]: Atomically writing to file /var/lib/cloud/data/status.json (via temporary file /var/lib/cloud/data/tmpdkto8nwg) - w: [644] 607 bytes/chars
2021-03-06 13:56:46,755 - atomic_helper.py[DEBUG]: Atomically writing to file /var/lib/cloud/data/result.json (via temporary file /var/lib/cloud/data/tmpq9__zt9z) - w: [644] 102 bytes/chars
2021-03-06 13:56:46,755 - util.py[DEBUG]: Creating symbolic link from '/run/cloud-init/result.json' => '../../var/lib/cloud/data/result.json'
2021-03-06 13:56:46,755 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2021-03-06 13:56:46,756 - util.py[DEBUG]: Read 13 bytes from /proc/uptime
2021-03-06 13:56:46,756 - util.py[DEBUG]: cloud-init mode 'modules' took 0.234 seconds (0.23)
2021-03-06 13:56:46,756 - handlers.py[DEBUG]: finish: modules-final: SUCCESS: running modules for final
2021-03-06 14:23:48,313 - util.py[DEBUG]: Cloud-init v. 20.4.1-0ubuntu1~20.10.1 running 'init-local' at Sat, 06 Mar 2021 14:23:48 +0000. Up 13.33 seconds.
2021-03-06 14:23:48,314 - main.py[DEBUG]: No kernel command line url found.
2021-03-06 14:23:48,315 - main.py[DEBUG]: Closing stdin.
2021-03-06 14:23:48,321 - util.py[DEBUG]: Writing to /var/log/cloud-init.log - ab: [644] 0 bytes
2021-03-06 14:23:48,323 - util.py[DEBUG]: Changing the ownership of /var/log/cloud-init.log to 104:4
2021-03-06 14:23:48,323 - util.py[DEBUG]: Attempting to remove /var/lib/cloud/instance/boot-finished
2021-03-06 14:23:48,324 - util.py[DEBUG]: Attempting to remove /var/lib/cloud/data/no-net
2021-03-06 14:23:48,324 - handlers.py[DEBUG]: start: init-local/check-cache: attempting to read from cache [check]
2021-03-06 14:23:48,324 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/obj.pkl (quiet=False)
2021-03-06 14:23:48,325 - util.py[DEBUG]: Read 11634 bytes from /var/lib/cloud/instance/obj.pkl
2021-03-06 14:23:48,334 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud/meta-data (quiet=False)
2021-03-06 14:23:48,335 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud-net/meta-data (quiet=False)
2021-03-06 14:23:48,335 - stages.py[DEBUG]: cache invalid in datasource: DataSourceNoCloud [seed=/dev/mmcblk0p1][dsmode=net]
2021-03-06 14:23:48,335 - handlers.py[DEBUG]: finish: init-local/check-cache: SUCCESS: cache invalid in datasource: DataSourceNoCloud [seed=/dev/mmcblk0p1][dsmode=net]
2021-03-06 14:23:48,336 - util.py[DEBUG]: Attempting to remove /var/lib/cloud/instance
2021-03-06 14:23:48,338 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.ubuntu.Distro'>
2021-03-06 14:23:48,339 - __init__.py[DEBUG]: Looking for data source in: ['NoCloud', 'None'], via packages ['', 'cloudinit.sources'] that matches dependencies ['FILESYSTEM']
2021-03-06 14:23:48,341 - __init__.py[DEBUG]: Searching for local data source in: ['DataSourceNoCloud']
2021-03-06 14:23:48,342 - handlers.py[DEBUG]: start: init-local/search-NoCloud: searching for local data from DataSourceNoCloud
2021-03-06 14:23:48,342 - __init__.py[DEBUG]: Seeing if we can get any data from <class 'cloudinit.sources.DataSourceNoCloud.DataSourceNoCloud'>
2021-03-06 14:23:48,342 - __init__.py[DEBUG]: Update datasource metadata and network config due to events: New instance first boot
2021-03-06 14:23:48,342 - dmi.py[DEBUG]: querying dmi data /sys/class/dmi/id/product_serial
2021-03-06 14:23:48,342 - dmi.py[DEBUG]: did not find /sys/class/dmi/id/product_serial
2021-03-06 14:23:48,343 - subp.py[DEBUG]: Running command ['/usr/sbin/dmidecode', '--string', 'system-serial-number'] with allowed return codes [0] (shell=False, capture=True)
2021-03-06 14:23:48,349 - dmi.py[DEBUG]: dmidecode returned '' for 'system-serial-number'
2021-03-06 14:23:48,350 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud/user-data (quiet=False)
2021-03-06 14:23:48,350 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud/meta-data (quiet=False)
2021-03-06 14:23:48,350 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud/vendor-data (quiet=False)
2021-03-06 14:23:48,350 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud/network-config (quiet=False)
2021-03-06 14:23:48,350 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud-net/user-data (quiet=False)
2021-03-06 14:23:48,351 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud-net/meta-data (quiet=False)
2021-03-06 14:23:48,351 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud-net/vendor-data (quiet=False)
2021-03-06 14:23:48,351 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud-net/network-config (quiet=False)
2021-03-06 14:23:48,351 - subp.py[DEBUG]: Running command ['blkid', '-tTYPE=vfat', '-odevice'] with allowed return codes [0, 2] (shell=False, capture=True)
2021-03-06 14:23:48,419 - subp.py[DEBUG]: Running command ['blkid', '-tTYPE=iso9660', '-odevice'] with allowed return codes [0, 2] (shell=False, capture=True)
2021-03-06 14:23:48,438 - subp.py[DEBUG]: Running command ['blkid', '-tLABEL=SYSTEM-BOOT', '-odevice'] with allowed return codes [0, 2] (shell=False, capture=True)
2021-03-06 14:23:48,455 - subp.py[DEBUG]: Running command ['blkid', '-tLABEL=system-boot', '-odevice'] with allowed return codes [0, 2] (shell=False, capture=True)
2021-03-06 14:23:48,472 - subp.py[DEBUG]: Running command ['blkid', '-tLABEL_FATBOOT=system-boot', '-odevice'] with allowed return codes [0, 2] (shell=False, capture=True)
2021-03-06 14:23:48,490 - DataSourceNoCloud.py[DEBUG]: Attempting to use data from /dev/mmcblk0p1
2021-03-06 14:23:48,490 - util.py[DEBUG]: Reading from /proc/mounts (quiet=False)
2021-03-06 14:23:48,491 - util.py[DEBUG]: Read 2689 bytes from /proc/mounts
2021-03-06 14:23:48,491 - util.py[DEBUG]: Fetched {'sysfs': {'fstype': 'sysfs', 'mountpoint': '/sys', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'proc': {'fstype': 'proc', 'mountpoint': '/proc', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'udev': {'fstype': 'devtmpfs', 'mountpoint': '/dev', 'opts': 'rw,nosuid,noexec,relatime,size=3627832k,nr_inodes=906958,mode=755'}, 'devpts': {'fstype': 'devpts', 'mountpoint': '/dev/pts', 'opts': 'rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000'}, 'tmpfs': {'fstype': 'tmpfs', 'mountpoint': '/sys/fs/cgroup', 'opts': 'ro,nosuid,nodev,noexec,size=4096k,nr_inodes=1024,mode=755'}, '/dev/mmcblk0p2': {'fstype': 'ext4', 'mountpoint': '/', 'opts': 'rw,relatime'}, 'securityfs': {'fstype': 'securityfs', 'mountpoint': '/sys/kernel/security', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'cgroup2': {'fstype': 'cgroup2', 'mountpoint': '/sys/fs/cgroup/unified', 'opts': 'rw,nosuid,nodev,noexec,relatime,nsdelegate'}, 'cgroup': {'fstype': 'cgroup', 'mountpoint': '/sys/fs/cgroup/cpuset', 'opts': 'rw,nosuid,nodev,noexec,relatime,cpuset'}, 'pstore': {'fstype': 'pstore', 'mountpoint': '/sys/fs/pstore', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'none': {'fstype': 'bpf', 'mountpoint': '/sys/fs/bpf', 'opts': 'rw,nosuid,nodev,noexec,relatime,mode=700'}, 'systemd-1': {'fstype': 'autofs', 'mountpoint': '/proc/sys/fs/binfmt_misc', 'opts': 'rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=41900'}, 'mqueue': {'fstype': 'mqueue', 'mountpoint': '/dev/mqueue', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'debugfs': {'fstype': 'debugfs', 'mountpoint': '/sys/kernel/debug', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'tracefs': {'fstype': 'tracefs', 'mountpoint': '/sys/kernel/tracing', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'fusectl': {'fstype': 'fusectl', 'mountpoint': '/sys/fs/fuse/connections', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'configfs': {'fstype': 'configfs', 'mountpoint': '/sys/kernel/config', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, '/dev/loop0': {'fstype': 'squashfs', 'mountpoint': '/snap/core18/1888', 'opts': 'ro,nodev,relatime'}, '/dev/loop1': {'fstype': 'squashfs', 'mountpoint': '/snap/snapd/11043', 'opts': 'ro,nodev,relatime'}, '/dev/loop2': {'fstype': 'squashfs', 'mountpoint': '/snap/lxd/19573', 'opts': 'ro,nodev,relatime'}, '/dev/loop3': {'fstype': 'squashfs', 'mountpoint': '/snap/core18/1990', 'opts': 'ro,nodev,relatime'}, '/dev/loop4': {'fstype': 'squashfs', 'mountpoint': '/snap/lxd/19390', 'opts': 'ro,nodev,relatime'}, '/dev/loop5': {'fstype': 'squashfs', 'mountpoint': '/snap/snapd/11115', 'opts': 'ro,nodev,relatime'}, '/dev/mmcblk0p1': {'fstype': 'vfat', 'mountpoint': '/boot/firmware', 'opts': 'rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro'}} mounts from proc
2021-03-06 14:23:48,492 - util.py[DEBUG]: Reading from /boot/firmware//user-data (quiet=False)
2021-03-06 14:23:48,493 - util.py[DEBUG]: Read 2114 bytes from /boot/firmware//user-data
2021-03-06 14:23:48,493 - util.py[DEBUG]: Reading from /boot/firmware//meta-data (quiet=False)
2021-03-06 14:23:48,494 - util.py[DEBUG]: Read 240 bytes from /boot/firmware//meta-data
2021-03-06 14:23:48,494 - util.py[DEBUG]: Reading from /boot/firmware//vendor-data (quiet=False)
2021-03-06 14:23:48,494 - util.py[DEBUG]: Reading from /boot/firmware//network-config (quiet=False)
2021-03-06 14:23:48,495 - util.py[DEBUG]: Read 1389 bytes from /boot/firmware//network-config
2021-03-06 14:23:48,495 - util.py[DEBUG]: Attempting to load yaml from string of length 240 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,497 - util.py[DEBUG]: Attempting to load yaml from string of length 1389 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,503 - DataSourceNoCloud.py[DEBUG]: Using data from /dev/mmcblk0p1
2021-03-06 14:23:48,503 - util.py[DEBUG]: Reading from /etc/hosts (quiet=False)
2021-03-06 14:23:48,504 - util.py[DEBUG]: Read 239 bytes from /etc/hosts
2021-03-06 14:23:48,507 - atomic_helper.py[DEBUG]: Atomically writing to file /run/cloud-init/instance-data-sensitive.json (via temporary file /run/cloud-init/tmp7mmmfx6o) - w: [600] 4762 bytes/chars
2021-03-06 14:23:48,508 - atomic_helper.py[DEBUG]: Atomically writing to file /run/cloud-init/instance-data.json (via temporary file /run/cloud-init/tmp2gvvptau) - w: [644] 1419 bytes/chars
2021-03-06 14:23:48,509 - handlers.py[DEBUG]: finish: init-local/search-NoCloud: SUCCESS: found local data from DataSourceNoCloud
2021-03-06 14:23:48,509 - stages.py[INFO]: Loaded datasource DataSourceNoCloud - DataSourceNoCloud [seed=/dev/mmcblk0p1][dsmode=net]
2021-03-06 14:23:48,509 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg (quiet=False)
2021-03-06 14:23:48,509 - util.py[DEBUG]: Read 3618 bytes from /etc/cloud/cloud.cfg
2021-03-06 14:23:48,510 - util.py[DEBUG]: Attempting to load yaml from string of length 3618 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,537 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/99-fake_cloud.cfg (quiet=False)
2021-03-06 14:23:48,537 - util.py[DEBUG]: Read 119 bytes from /etc/cloud/cloud.cfg.d/99-fake_cloud.cfg
2021-03-06 14:23:48,537 - util.py[DEBUG]: Attempting to load yaml from string of length 119 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,539 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg.cfg (quiet=False)
2021-03-06 14:23:48,539 - util.py[DEBUG]: Read 285 bytes from /etc/cloud/cloud.cfg.d/90_dpkg.cfg
2021-03-06 14:23:48,539 - util.py[DEBUG]: Attempting to load yaml from string of length 285 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,543 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/05_logging.cfg (quiet=False)
2021-03-06 14:23:48,543 - util.py[DEBUG]: Read 2070 bytes from /etc/cloud/cloud.cfg.d/05_logging.cfg
2021-03-06 14:23:48,543 - util.py[DEBUG]: Attempting to load yaml from string of length 2070 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,551 - util.py[DEBUG]: Reading from /run/cloud-init/cloud.cfg (quiet=False)
2021-03-06 14:23:48,551 - util.py[DEBUG]: Read 35 bytes from /run/cloud-init/cloud.cfg
2021-03-06 14:23:48,551 - util.py[DEBUG]: Attempting to load yaml from string of length 35 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,552 - util.py[DEBUG]: Attempting to load yaml from string of length 0 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,552 - util.py[DEBUG]: loaded blob returned None, returning default.
2021-03-06 14:23:48,553 - util.py[DEBUG]: Attempting to remove /var/lib/cloud/instance
2021-03-06 14:23:48,554 - util.py[DEBUG]: Creating symbolic link from '/var/lib/cloud/instance' => '/var/lib/cloud/instances/nocloud'
2021-03-06 14:23:48,555 - util.py[DEBUG]: Reading from /var/lib/cloud/instances/nocloud/datasource (quiet=False)
2021-03-06 14:23:48,556 - util.py[DEBUG]: Read 71 bytes from /var/lib/cloud/instances/nocloud/datasource
2021-03-06 14:23:48,557 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/nocloud/datasource - wb: [644] 71 bytes
2021-03-06 14:23:48,558 - util.py[DEBUG]: Writing to /var/lib/cloud/data/previous-datasource - wb: [644] 71 bytes
2021-03-06 14:23:48,559 - util.py[DEBUG]: Reading from /var/lib/cloud/data/instance-id (quiet=False)
2021-03-06 14:23:48,560 - util.py[DEBUG]: Read 8 bytes from /var/lib/cloud/data/instance-id
2021-03-06 14:23:48,561 - stages.py[DEBUG]: previous iid found to be nocloud
2021-03-06 14:23:48,561 - util.py[DEBUG]: Writing to /var/lib/cloud/data/instance-id - wb: [644] 8 bytes
2021-03-06 14:23:48,562 - util.py[DEBUG]: Writing to /run/cloud-init/.instance-id - wb: [644] 8 bytes
2021-03-06 14:23:48,563 - util.py[DEBUG]: Writing to /var/lib/cloud/data/previous-instance-id - wb: [644] 8 bytes
2021-03-06 14:23:48,565 - util.py[DEBUG]: Writing to /var/lib/cloud/instance/obj.pkl - wb: [400] 7882 bytes
2021-03-06 14:23:48,567 - main.py[DEBUG]: [local] init will now be targeting instance id: nocloud. new=False
2021-03-06 14:23:48,567 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg (quiet=False)
2021-03-06 14:23:48,567 - util.py[DEBUG]: Read 3618 bytes from /etc/cloud/cloud.cfg
2021-03-06 14:23:48,567 - util.py[DEBUG]: Attempting to load yaml from string of length 3618 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,594 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/99-fake_cloud.cfg (quiet=False)
2021-03-06 14:23:48,594 - util.py[DEBUG]: Read 119 bytes from /etc/cloud/cloud.cfg.d/99-fake_cloud.cfg
2021-03-06 14:23:48,594 - util.py[DEBUG]: Attempting to load yaml from string of length 119 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,596 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg.cfg (quiet=False)
2021-03-06 14:23:48,596 - util.py[DEBUG]: Read 285 bytes from /etc/cloud/cloud.cfg.d/90_dpkg.cfg
2021-03-06 14:23:48,597 - util.py[DEBUG]: Attempting to load yaml from string of length 285 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,600 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/05_logging.cfg (quiet=False)
2021-03-06 14:23:48,600 - util.py[DEBUG]: Read 2070 bytes from /etc/cloud/cloud.cfg.d/05_logging.cfg
2021-03-06 14:23:48,601 - util.py[DEBUG]: Attempting to load yaml from string of length 2070 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,608 - util.py[DEBUG]: Reading from /run/cloud-init/cloud.cfg (quiet=False)
2021-03-06 14:23:48,608 - util.py[DEBUG]: Read 35 bytes from /run/cloud-init/cloud.cfg
2021-03-06 14:23:48,608 - util.py[DEBUG]: Attempting to load yaml from string of length 35 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,609 - util.py[DEBUG]: Attempting to load yaml from string of length 0 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,609 - util.py[DEBUG]: loaded blob returned None, returning default.
2021-03-06 14:23:48,610 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/cloud-config.txt (quiet=False)
2021-03-06 14:23:48,610 - util.py[DEBUG]: Read 124 bytes from /var/lib/cloud/instance/cloud-config.txt
2021-03-06 14:23:48,610 - util.py[DEBUG]: Attempting to load yaml from string of length 124 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:48,614 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.ubuntu.Distro'>
2021-03-06 14:23:48,617 - util.py[DEBUG]: Reading from /sys/class/net/wlan0/address (quiet=False)
2021-03-06 14:23:48,617 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/wlan0/address
2021-03-06 14:23:48,617 - util.py[DEBUG]: Reading from /sys/class/net/lo/address (quiet=False)
2021-03-06 14:23:48,617 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/lo/address
2021-03-06 14:23:48,617 - util.py[DEBUG]: Reading from /sys/class/net/eth0/address (quiet=False)
2021-03-06 14:23:48,618 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/eth0/address
2021-03-06 14:23:48,618 - __init__.py[DEBUG]: Datasource DataSourceNoCloud [seed=/dev/mmcblk0p1][dsmode=net] not updated for events: System boot
2021-03-06 14:23:48,618 - stages.py[DEBUG]: No network config applied. Neither a new instance nor datasource network update on 'System boot' event
2021-03-06 14:23:48,618 - stages.py[DEBUG]: applying net config names for {'version': 2, 'ethernets': {'eth0': {'match': {'driver': 'bcmgenet smsc95xx lan78xx'}, 'set-name': 'eth0', 'dhcp4': True, 'optional': True}}}
2021-03-06 14:23:48,619 - __init__.py[DEBUG]: no interfaces to rename
2021-03-06 14:23:48,619 - main.py[DEBUG]: [local] Exiting. datasource DataSourceNoCloud [seed=/dev/mmcblk0p1][dsmode=net] not in local mode.
2021-03-06 14:23:48,619 - atomic_helper.py[DEBUG]: Atomically writing to file /var/lib/cloud/data/status.json (via temporary file /var/lib/cloud/data/tmpcnc5gyfo) - w: [644] 524 bytes/chars
2021-03-06 14:23:48,620 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2021-03-06 14:23:48,620 - util.py[DEBUG]: Read 12 bytes from /proc/uptime
2021-03-06 14:23:48,620 - util.py[DEBUG]: cloud-init mode 'init' took 0.447 seconds (0.44)
2021-03-06 14:23:48,621 - handlers.py[DEBUG]: finish: init-local: SUCCESS: searching for local datasources
2021-03-06 14:23:50,009 - util.py[DEBUG]: Cloud-init v. 20.4.1-0ubuntu1~20.10.1 running 'init' at Sat, 06 Mar 2021 14:23:49 +0000. Up 15.03 seconds.
2021-03-06 14:23:50,009 - main.py[DEBUG]: No kernel command line url found.
2021-03-06 14:23:50,010 - main.py[DEBUG]: Closing stdin.
2021-03-06 14:23:50,014 - util.py[DEBUG]: Writing to /var/log/cloud-init.log - ab: [644] 0 bytes
2021-03-06 14:23:50,016 - util.py[DEBUG]: Changing the ownership of /var/log/cloud-init.log to 104:4
2021-03-06 14:23:50,017 - subp.py[DEBUG]: Running command ['ip', 'addr', 'show'] with allowed return codes [0] (shell=False, capture=True)
2021-03-06 14:23:50,055 - subp.py[DEBUG]: Running command ['ip', '-o', 'route', 'list'] with allowed return codes [0] (shell=False, capture=True)
2021-03-06 14:23:50,065 - subp.py[DEBUG]: Running command ['ip', '--oneline', '-6', 'route', 'list', 'table', 'all'] with allowed return codes [0, 1] (shell=False, capture=True)
2021-03-06 14:23:50,076 - main.py[DEBUG]: Checking to see if files that we need already exist from a previous run that would allow us to stop early.
2021-03-06 14:23:50,076 - main.py[DEBUG]: Execution continuing, no previous run detected that would allow us to stop early.
2021-03-06 14:23:50,077 - handlers.py[DEBUG]: start: init-network/check-cache: attempting to read from cache [trust]
2021-03-06 14:23:50,077 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/obj.pkl (quiet=False)
2021-03-06 14:23:50,078 - util.py[DEBUG]: Read 7882 bytes from /var/lib/cloud/instance/obj.pkl
2021-03-06 14:23:50,083 - util.py[DEBUG]: Reading from /run/cloud-init/.instance-id (quiet=False)
2021-03-06 14:23:50,084 - util.py[DEBUG]: Read 8 bytes from /run/cloud-init/.instance-id
2021-03-06 14:23:50,084 - stages.py[DEBUG]: restored from cache with run check: DataSourceNoCloud [seed=/dev/mmcblk0p1][dsmode=net]
2021-03-06 14:23:50,084 - handlers.py[DEBUG]: finish: init-network/check-cache: SUCCESS: restored from cache with run check: DataSourceNoCloud [seed=/dev/mmcblk0p1][dsmode=net]
2021-03-06 14:23:50,085 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg (quiet=False)
2021-03-06 14:23:50,085 - util.py[DEBUG]: Read 3618 bytes from /etc/cloud/cloud.cfg
2021-03-06 14:23:50,085 - util.py[DEBUG]: Attempting to load yaml from string of length 3618 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,115 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/99-fake_cloud.cfg (quiet=False)
2021-03-06 14:23:50,115 - util.py[DEBUG]: Read 119 bytes from /etc/cloud/cloud.cfg.d/99-fake_cloud.cfg
2021-03-06 14:23:50,115 - util.py[DEBUG]: Attempting to load yaml from string of length 119 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,117 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg.cfg (quiet=False)
2021-03-06 14:23:50,117 - util.py[DEBUG]: Read 285 bytes from /etc/cloud/cloud.cfg.d/90_dpkg.cfg
2021-03-06 14:23:50,117 - util.py[DEBUG]: Attempting to load yaml from string of length 285 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,121 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/05_logging.cfg (quiet=False)
2021-03-06 14:23:50,121 - util.py[DEBUG]: Read 2070 bytes from /etc/cloud/cloud.cfg.d/05_logging.cfg
2021-03-06 14:23:50,121 - util.py[DEBUG]: Attempting to load yaml from string of length 2070 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,129 - util.py[DEBUG]: Reading from /run/cloud-init/cloud.cfg (quiet=False)
2021-03-06 14:23:50,129 - util.py[DEBUG]: Read 35 bytes from /run/cloud-init/cloud.cfg
2021-03-06 14:23:50,129 - util.py[DEBUG]: Attempting to load yaml from string of length 35 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,130 - util.py[DEBUG]: Attempting to load yaml from string of length 0 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,130 - util.py[DEBUG]: loaded blob returned None, returning default.
2021-03-06 14:23:50,131 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/cloud-config.txt (quiet=False)
2021-03-06 14:23:50,131 - util.py[DEBUG]: Read 124 bytes from /var/lib/cloud/instance/cloud-config.txt
2021-03-06 14:23:50,131 - util.py[DEBUG]: Attempting to load yaml from string of length 124 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,134 - util.py[DEBUG]: Attempting to remove /var/lib/cloud/instance
2021-03-06 14:23:50,134 - util.py[DEBUG]: Creating symbolic link from '/var/lib/cloud/instance' => '/var/lib/cloud/instances/nocloud'
2021-03-06 14:23:50,135 - util.py[DEBUG]: Reading from /var/lib/cloud/instances/nocloud/datasource (quiet=False)
2021-03-06 14:23:50,136 - util.py[DEBUG]: Read 71 bytes from /var/lib/cloud/instances/nocloud/datasource
2021-03-06 14:23:50,136 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/nocloud/datasource - wb: [644] 71 bytes
2021-03-06 14:23:50,137 - util.py[DEBUG]: Writing to /var/lib/cloud/data/previous-datasource - wb: [644] 71 bytes
2021-03-06 14:23:50,138 - util.py[DEBUG]: Reading from /var/lib/cloud/data/instance-id (quiet=False)
2021-03-06 14:23:50,139 - util.py[DEBUG]: Read 8 bytes from /var/lib/cloud/data/instance-id
2021-03-06 14:23:50,139 - stages.py[DEBUG]: previous iid found to be nocloud
2021-03-06 14:23:50,139 - util.py[DEBUG]: Writing to /var/lib/cloud/data/instance-id - wb: [644] 8 bytes
2021-03-06 14:23:50,140 - util.py[DEBUG]: Writing to /run/cloud-init/.instance-id - wb: [644] 8 bytes
2021-03-06 14:23:50,141 - util.py[DEBUG]: Writing to /var/lib/cloud/data/previous-instance-id - wb: [644] 8 bytes
2021-03-06 14:23:50,143 - util.py[DEBUG]: Writing to /var/lib/cloud/instance/obj.pkl - wb: [400] 7934 bytes
2021-03-06 14:23:50,145 - main.py[DEBUG]: [net] init will now be targeting instance id: nocloud. new=False
2021-03-06 14:23:50,145 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg (quiet=False)
2021-03-06 14:23:50,146 - util.py[DEBUG]: Read 3618 bytes from /etc/cloud/cloud.cfg
2021-03-06 14:23:50,146 - util.py[DEBUG]: Attempting to load yaml from string of length 3618 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,172 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/99-fake_cloud.cfg (quiet=False)
2021-03-06 14:23:50,173 - util.py[DEBUG]: Read 119 bytes from /etc/cloud/cloud.cfg.d/99-fake_cloud.cfg
2021-03-06 14:23:50,173 - util.py[DEBUG]: Attempting to load yaml from string of length 119 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,174 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg.cfg (quiet=False)
2021-03-06 14:23:50,175 - util.py[DEBUG]: Read 285 bytes from /etc/cloud/cloud.cfg.d/90_dpkg.cfg
2021-03-06 14:23:50,175 - util.py[DEBUG]: Attempting to load yaml from string of length 285 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,179 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/05_logging.cfg (quiet=False)
2021-03-06 14:23:50,179 - util.py[DEBUG]: Read 2070 bytes from /etc/cloud/cloud.cfg.d/05_logging.cfg
2021-03-06 14:23:50,179 - util.py[DEBUG]: Attempting to load yaml from string of length 2070 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,186 - util.py[DEBUG]: Reading from /run/cloud-init/cloud.cfg (quiet=False)
2021-03-06 14:23:50,186 - util.py[DEBUG]: Read 35 bytes from /run/cloud-init/cloud.cfg
2021-03-06 14:23:50,187 - util.py[DEBUG]: Attempting to load yaml from string of length 35 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,188 - util.py[DEBUG]: Attempting to load yaml from string of length 0 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,188 - util.py[DEBUG]: loaded blob returned None, returning default.
2021-03-06 14:23:50,188 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/cloud-config.txt (quiet=False)
2021-03-06 14:23:50,189 - util.py[DEBUG]: Read 124 bytes from /var/lib/cloud/instance/cloud-config.txt
2021-03-06 14:23:50,189 - util.py[DEBUG]: Attempting to load yaml from string of length 124 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,193 - util.py[DEBUG]: Reading from /sys/class/net/wlan0/address (quiet=False)
2021-03-06 14:23:50,193 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/wlan0/address
2021-03-06 14:23:50,193 - util.py[DEBUG]: Reading from /sys/class/net/lo/address (quiet=False)
2021-03-06 14:23:50,194 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/lo/address
2021-03-06 14:23:50,194 - util.py[DEBUG]: Reading from /sys/class/net/eth0/address (quiet=False)
2021-03-06 14:23:50,194 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/eth0/address
2021-03-06 14:23:50,194 - __init__.py[DEBUG]: Datasource DataSourceNoCloud [seed=/dev/mmcblk0p1][dsmode=net] not updated for events: System boot
2021-03-06 14:23:50,194 - stages.py[DEBUG]: No network config applied. Neither a new instance nor datasource network update on 'System boot' event
2021-03-06 14:23:50,195 - stages.py[DEBUG]: applying net config names for {'version': 2, 'ethernets': {'eth0': {'match': {'driver': 'bcmgenet smsc95xx lan78xx'}, 'set-name': 'eth0', 'dhcp4': True, 'optional': True}}}
2021-03-06 14:23:50,196 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.ubuntu.Distro'>
2021-03-06 14:23:50,196 - __init__.py[DEBUG]: no interfaces to rename
2021-03-06 14:23:50,197 - handlers.py[DEBUG]: start: init-network/setup-datasource: setting up datasource
2021-03-06 14:23:50,197 - handlers.py[DEBUG]: finish: init-network/setup-datasource: SUCCESS: setting up datasource
2021-03-06 14:23:50,197 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/nocloud/user-data.txt - wb: [600] 2114 bytes
2021-03-06 14:23:50,199 - util.py[DEBUG]: Attempting to load yaml from string of length 2114 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,210 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/nocloud/user-data.txt.i - wb: [600] 2419 bytes
2021-03-06 14:23:50,212 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/nocloud/vendor-data.txt - wb: [600] 0 bytes
2021-03-06 14:23:50,214 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/nocloud/vendor-data.txt.i - wb: [600] 308 bytes
2021-03-06 14:23:50,218 - helpers.py[DEBUG]: consume_data already ran (freq=once-per-instance)
2021-03-06 14:23:50,218 - handlers.py[DEBUG]: start: init-network/consume-user-data: reading and applying user-data
2021-03-06 14:23:50,220 - stages.py[DEBUG]: Added default handler for {'text/cloud-config', 'text/cloud-config-jsonp'} from CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']]
2021-03-06 14:23:50,221 - stages.py[DEBUG]: Added default handler for {'text/x-shellscript'} from ShellScriptPartHandler: [['text/x-shellscript']]
2021-03-06 14:23:50,221 - stages.py[DEBUG]: Added default handler for {'text/cloud-boothook'} from BootHookPartHandler: [['text/cloud-boothook']]
2021-03-06 14:23:50,221 - stages.py[DEBUG]: Added default handler for {'text/upstart-job'} from UpstartJobPartHandler: [['text/upstart-job']]
2021-03-06 14:23:50,221 - stages.py[DEBUG]: Added default handler for {'text/jinja2'} from JinjaTemplatePartHandler: [['text/jinja2']]
2021-03-06 14:23:50,221 - __init__.py[DEBUG]: Calling handler CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']] (__begin__, None, 3) with frequency always
2021-03-06 14:23:50,222 - __init__.py[DEBUG]: Calling handler ShellScriptPartHandler: [['text/x-shellscript']] (__begin__, None, 2) with frequency always
2021-03-06 14:23:50,222 - __init__.py[DEBUG]: Calling handler BootHookPartHandler: [['text/cloud-boothook']] (__begin__, None, 2) with frequency always
2021-03-06 14:23:50,222 - __init__.py[DEBUG]: Calling handler JinjaTemplatePartHandler: [['text/jinja2']] (__begin__, None, 3) with frequency always
2021-03-06 14:23:50,222 - __init__.py[DEBUG]: {'MIME-Version': '1.0', 'Content-Type': 'text/cloud-config', 'Content-Disposition': 'attachment; filename="part-001"'}
2021-03-06 14:23:50,222 - __init__.py[DEBUG]: Calling handler CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']] (text/cloud-config, part-001, 3) with frequency always
2021-03-06 14:23:50,222 - util.py[DEBUG]: Attempting to load yaml from string of length 2114 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,229 - cloud_config.py[DEBUG]: Merging by applying [('dict', ['replace']), ('list', []), ('str', [])]
2021-03-06 14:23:50,230 - __init__.py[DEBUG]: Calling handler CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']] (__end__, None, 3) with frequency always
2021-03-06 14:23:50,231 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/nocloud/cloud-config.txt - wb: [600] 124 bytes
2021-03-06 14:23:50,234 - __init__.py[DEBUG]: Calling handler ShellScriptPartHandler: [['text/x-shellscript']] (__end__, None, 2) with frequency always
2021-03-06 14:23:50,234 - __init__.py[DEBUG]: Calling handler BootHookPartHandler: [['text/cloud-boothook']] (__end__, None, 2) with frequency always
2021-03-06 14:23:50,234 - __init__.py[DEBUG]: Calling handler JinjaTemplatePartHandler: [['text/jinja2']] (__end__, None, 3) with frequency always
2021-03-06 14:23:50,234 - handlers.py[DEBUG]: finish: init-network/consume-user-data: SUCCESS: reading and applying user-data
2021-03-06 14:23:50,234 - handlers.py[DEBUG]: start: init-network/consume-vendor-data: reading and applying vendor-data
2021-03-06 14:23:50,235 - stages.py[DEBUG]: no vendordata from datasource
2021-03-06 14:23:50,235 - handlers.py[DEBUG]: finish: init-network/consume-vendor-data: SUCCESS: reading and applying vendor-data
2021-03-06 14:23:50,235 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg (quiet=False)
2021-03-06 14:23:50,236 - util.py[DEBUG]: Read 3618 bytes from /etc/cloud/cloud.cfg
2021-03-06 14:23:50,236 - util.py[DEBUG]: Attempting to load yaml from string of length 3618 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,263 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/99-fake_cloud.cfg (quiet=False)
2021-03-06 14:23:50,263 - util.py[DEBUG]: Read 119 bytes from /etc/cloud/cloud.cfg.d/99-fake_cloud.cfg
2021-03-06 14:23:50,263 - util.py[DEBUG]: Attempting to load yaml from string of length 119 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,265 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg.cfg (quiet=False)
2021-03-06 14:23:50,265 - util.py[DEBUG]: Read 285 bytes from /etc/cloud/cloud.cfg.d/90_dpkg.cfg
2021-03-06 14:23:50,265 - util.py[DEBUG]: Attempting to load yaml from string of length 285 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,269 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/05_logging.cfg (quiet=False)
2021-03-06 14:23:50,269 - util.py[DEBUG]: Read 2070 bytes from /etc/cloud/cloud.cfg.d/05_logging.cfg
2021-03-06 14:23:50,270 - util.py[DEBUG]: Attempting to load yaml from string of length 2070 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,277 - util.py[DEBUG]: Reading from /run/cloud-init/cloud.cfg (quiet=False)
2021-03-06 14:23:50,277 - util.py[DEBUG]: Read 35 bytes from /run/cloud-init/cloud.cfg
2021-03-06 14:23:50,277 - util.py[DEBUG]: Attempting to load yaml from string of length 35 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,278 - util.py[DEBUG]: Attempting to load yaml from string of length 0 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,278 - util.py[DEBUG]: loaded blob returned None, returning default.
2021-03-06 14:23:50,279 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/cloud-config.txt (quiet=False)
2021-03-06 14:23:50,279 - util.py[DEBUG]: Read 124 bytes from /var/lib/cloud/instance/cloud-config.txt
2021-03-06 14:23:50,279 - util.py[DEBUG]: Attempting to load yaml from string of length 124 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,283 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/cloud-config.txt (quiet=False)
2021-03-06 14:23:50,283 - util.py[DEBUG]: Read 124 bytes from /var/lib/cloud/instance/cloud-config.txt
2021-03-06 14:23:50,283 - util.py[DEBUG]: Attempting to load yaml from string of length 124 with allowed root types (<class 'dict'>,)
2021-03-06 14:23:50,290 - handlers.py[DEBUG]: start: init-network/activate-datasource: activating datasource
2021-03-06 14:23:50,292 - util.py[DEBUG]: Writing to /var/lib/cloud/instance/obj.pkl - wb: [400] 11634 bytes
2021-03-06 14:23:50,294 - handlers.py[DEBUG]: finish: init-network/activate-datasource: SUCCESS: activating datasource
2021-03-06 14:23:50,295 - main.py[DEBUG]: no di_report found in config.
2021-03-06 14:23:50,341 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.ubuntu.Distro'>
2021-03-06 14:23:50,343 - stages.py[DEBUG]: Running module migrator (<module 'cloudinit.config.cc_migrator' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_migrator.py'>) with frequency always
2021-03-06 14:23:50,343 - handlers.py[DEBUG]: start: init-network/config-migrator: running config-migrator with frequency always
2021-03-06 14:23:50,343 - helpers.py[DEBUG]: Running config-migrator using lock (<cloudinit.helpers.DummyLock object at 0xffffa91bd4f0>)
2021-03-06 14:23:50,346 - cc_migrator.py[DEBUG]: Migrated 0 semaphore files to there canonicalized names
2021-03-06 14:23:50,348 - handlers.py[DEBUG]: finish: init-network/config-migrator: SUCCESS: config-migrator ran successfully
2021-03-06 14:23:50,348 - stages.py[DEBUG]: Running module seed_random (<module 'cloudinit.config.cc_seed_random' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_seed_random.py'>) with frequency once-per-instance
2021-03-06 14:23:50,348 - handlers.py[DEBUG]: start: init-network/config-seed_random: running config-seed_random with frequency once-per-instance
2021-03-06 14:23:50,349 - helpers.py[DEBUG]: config-seed_random already ran (freq=once-per-instance)
2021-03-06 14:23:50,349 - handlers.py[DEBUG]: finish: init-network/config-seed_random: SUCCESS: config-seed_random previously ran
2021-03-06 14:23:50,349 - stages.py[DEBUG]: Running module bootcmd (<module 'cloudinit.config.cc_bootcmd' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_bootcmd.py'>) with frequency always
2021-03-06 14:23:50,349 - handlers.py[DEBUG]: start: init-network/config-bootcmd: running config-bootcmd with frequency always
2021-03-06 14:23:50,349 - helpers.py[DEBUG]: Running config-bootcmd using lock (<cloudinit.helpers.DummyLock object at 0xffffa91bd940>)
2021-03-06 14:23:50,350 - cc_bootcmd.py[DEBUG]: Skipping module named bootcmd, no 'bootcmd' key in configuration
2021-03-06 14:23:50,350 - handlers.py[DEBUG]: finish: init-network/config-bootcmd: SUCCESS: config-bootcmd ran successfully
2021-03-06 14:23:50,350 - stages.py[DEBUG]: Running module write-files (<module 'cloudinit.config.cc_write_files' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_write_files.py'>) with frequency once-per-instance
2021-03-06 14:23:50,350 - handlers.py[DEBUG]: start: init-network/config-write-files: running config-write-files with frequency once-per-instance
2021-03-06 14:23:50,350 - helpers.py[DEBUG]: config-write-files already ran (freq=once-per-instance)
2021-03-06 14:23:50,351 - handlers.py[DEBUG]: finish: init-network/config-write-files: SUCCESS: config-write-files previously ran
2021-03-06 14:23:50,351 - stages.py[DEBUG]: Running module growpart (<module 'cloudinit.config.cc_growpart' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_growpart.py'>) with frequency always
2021-03-06 14:23:50,351 - handlers.py[DEBUG]: start: init-network/config-growpart: running config-growpart with frequency always
2021-03-06 14:23:50,351 - helpers.py[DEBUG]: Running config-growpart using lock (<cloudinit.helpers.DummyLock object at 0xffffa91bd4f0>)
2021-03-06 14:23:50,351 - cc_growpart.py[DEBUG]: No 'growpart' entry in cfg. Using default: {'mode': 'auto', 'devices': ['/'], 'ignore_growroot_disabled': False}
2021-03-06 14:23:50,352 - subp.py[DEBUG]: Running command ['growpart', '--help'] with allowed return codes [0] (shell=False, capture=True)
2021-03-06 14:23:50,364 - util.py[DEBUG]: Reading from /proc/1671/mountinfo (quiet=False)
2021-03-06 14:23:50,365 - util.py[DEBUG]: Read 3543 bytes from /proc/1671/mountinfo
2021-03-06 14:23:50,365 - util.py[DEBUG]: Reading from /sys/class/block/mmcblk0p2/partition (quiet=False)
2021-03-06 14:23:50,366 - util.py[DEBUG]: Read 2 bytes from /sys/class/block/mmcblk0p2/partition
2021-03-06 14:23:50,366 - util.py[DEBUG]: Reading from /sys/devices/platform/emmc2bus/fe340000.emmc2/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/dev (quiet=False)
2021-03-06 14:23:50,366 - util.py[DEBUG]: Read 6 bytes from /sys/devices/platform/emmc2bus/fe340000.emmc2/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/dev
2021-03-06 14:23:50,367 - subp.py[DEBUG]: Running command ['growpart', '--dry-run', '/dev/mmcblk0', '2'] with allowed return codes [0] (shell=False, capture=True)
2021-03-06 14:23:50,518 - util.py[DEBUG]: resize_devices took 0.154 seconds
2021-03-06 14:23:50,518 - cc_growpart.py[DEBUG]: '/' NOCHANGE: no change necessary (/dev/mmcblk0, 2)
2021-03-06 14:23:50,519 - handlers.py[DEBUG]: finish: init-network/config-growpart: SUCCESS: config-growpart ran successfully
2021-03-06 14:23:50,519 - stages.py[DEBUG]: Running module resizefs (<module 'cloudinit.config.cc_resizefs' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_resizefs.py'>) with frequency always
2021-03-06 14:23:50,519 - handlers.py[DEBUG]: start: init-network/config-resizefs: running config-resizefs with frequency always
2021-03-06 14:23:50,520 - helpers.py[DEBUG]: Running config-resizefs using lock (<cloudinit.helpers.DummyLock object at 0xffffa91bdc40>)
2021-03-06 14:23:50,632 - util.py[DEBUG]: Reading from /proc/1671/mountinfo (quiet=False)
2021-03-06 14:23:50,632 - util.py[DEBUG]: Read 3543 bytes from /proc/1671/mountinfo
2021-03-06 14:23:50,633 - cc_resizefs.py[DEBUG]: resize_info: dev=/dev/mmcblk0p2 mnt_point=/ path=/
2021-03-06 14:23:50,633 - cc_resizefs.py[DEBUG]: Resizing / (ext4) using resize2fs /dev/mmcblk0p2
2021-03-06 14:23:50,633 - subp.py[DEBUG]: Running command ('resize2fs', '/dev/mmcblk0p2') with allowed return codes [0] (shell=False, capture=True)
2021-03-06 14:23:50,687 - util.py[DEBUG]: Resizing took 0.053 seconds
2021-03-06 14:23:50,687 - cc_resizefs.py[DEBUG]: Resized root filesystem (type=ext4, val=True)
2021-03-06 14:23:50,688 - handlers.py[DEBUG]: finish: init-network/config-resizefs: SUCCESS: config-resizefs ran successfully
2021-03-06 14:23:50,689 - stages.py[DEBUG]: Running module disk_setup (<module 'cloudinit.config.cc_disk_setup' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_disk_setup.py'>) with frequency once-per-instance
2021-03-06 14:23:50,690 - handlers.py[DEBUG]: start: init-network/config-disk_setup: running config-disk_setup with frequency once-per-instance
2021-03-06 14:23:50,691 - helpers.py[DEBUG]: config-disk_setup already ran (freq=once-per-instance)
2021-03-06 14:23:50,691 - handlers.py[DEBUG]: finish: init-network/config-disk_setup: SUCCESS: config-disk_setup previously ran
2021-03-06 14:23:50,691 - stages.py[DEBUG]: Running module mounts (<module 'cloudinit.config.cc_mounts' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_mounts.py'>) with frequency once-per-instance
2021-03-06 14:23:50,692 - handlers.py[DEBUG]: start: init-network/config-mounts: running config-mounts with frequency once-per-instance
2021-03-06 14:23:50,692 - helpers.py[DEBUG]: config-mounts already ran (freq=once-per-instance)
2021-03-06 14:23:50,693 - handlers.py[DEBUG]: finish: init-network/config-mounts: SUCCESS: config-mounts previously ran
2021-03-06 14:23:50,693 - stages.py[DEBUG]: Running module set_hostname (<module 'cloudinit.config.cc_set_hostname' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_set_hostname.py'>) with frequency once-per-instance
2021-03-06 14:23:50,694 - handlers.py[DEBUG]: start: init-network/config-set_hostname: running config-set_hostname with frequency once-per-instance
2021-03-06 14:23:50,694 - helpers.py[DEBUG]: config-set_hostname already ran (freq=once-per-instance)
2021-03-06 14:23:50,694 - handlers.py[DEBUG]: finish: init-network/config-set_hostname: SUCCESS: config-set_hostname previously ran
2021-03-06 14:23:50,695 - stages.py[DEBUG]: Running module update_hostname (<module 'cloudinit.config.cc_update_hostname' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_update_hostname.py'>) with frequency always
2021-03-06 14:23:50,695 - handlers.py[DEBUG]: start: init-network/config-update_hostname: running config-update_hostname with frequency always
2021-03-06 14:23:50,696 - helpers.py[DEBUG]: Running config-update_hostname using lock (<cloudinit.helpers.DummyLock object at 0xffffa91bd640>)
2021-03-06 14:23:50,696 - cc_update_hostname.py[DEBUG]: Configuration option 'preserve_hostname' is set, not updating the hostname in module update_hostname
2021-03-06 14:23:50,697 - handlers.py[DEBUG]: finish: init-network/config-update_hostname: SUCCESS: config-update_hostname ran successfully
2021-03-06 14:23:50,697 - stages.py[DEBUG]: Running module update_etc_hosts (<module 'cloudinit.config.cc_update_etc_hosts' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_update_etc_hosts.py'>) with frequency always
2021-03-06 14:23:50,698 - handlers.py[DEBUG]: start: init-network/config-update_etc_hosts: running config-update_etc_hosts with frequency always
2021-03-06 14:23:50,698 - helpers.py[DEBUG]: Running config-update_etc_hosts using lock (<cloudinit.helpers.DummyLock object at 0xffffa91bd4f0>)
2021-03-06 14:23:50,698 - cc_update_etc_hosts.py[DEBUG]: Configuration option 'manage_etc_hosts' is not set, not managing /etc/hosts in module update_etc_hosts
2021-03-06 14:23:50,698 - handlers.py[DEBUG]: finish: init-network/config-update_etc_hosts: SUCCESS: config-update_etc_hosts ran successfully
2021-03-06 14:23:50,699 - stages.py[DEBUG]: Running module ca-certs (<module 'cloudinit.config.cc_ca_certs' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_ca_certs.py'>) with frequency once-per-instance
2021-03-06 14:23:50,699 - handlers.py[DEBUG]: start: init-network/config-ca-certs: running config-ca-certs with frequency once-per-instance
2021-03-06 14:23:50,700 - helpers.py[DEBUG]: config-ca-certs already ran (freq=once-per-instance)
2021-03-06 14:23:50,700 - handlers.py[DEBUG]: finish: init-network/config-ca-certs: SUCCESS: config-ca-certs previously ran
2021-03-06 14:23:50,700 - stages.py[DEBUG]: Running module rsyslog (<module 'cloudinit.config.cc_rsyslog' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_rsyslog.py'>) with frequency once-per-instance
2021-03-06 14:23:50,701 - handlers.py[DEBUG]: start: init-network/config-rsyslog: running config-rsyslog with frequency once-per-instance
2021-03-06 14:23:50,701 - helpers.py[DEBUG]: config-rsyslog already ran (freq=once-per-instance)
2021-03-06 14:23:50,702 - handlers.py[DEBUG]: finish: init-network/config-rsyslog: SUCCESS: config-rsyslog previously ran
2021-03-06 14:23:50,702 - stages.py[DEBUG]: Running module users-groups (<module 'cloudinit.config.cc_users_groups' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_users_groups.py'>) with frequency once-per-instance
2021-03-06 14:23:50,702 - handlers.py[DEBUG]: start: init-network/config-users-groups: running config-users-groups with frequency once-per-instance
2021-03-06 14:23:50,702 - helpers.py[DEBUG]: config-users-groups already ran (freq=once-per-instance)
2021-03-06 14:23:50,702 - handlers.py[DEBUG]: finish: init-network/config-users-groups: SUCCESS: config-users-groups previously ran
2021-03-06 14:23:50,702 - stages.py[DEBUG]: Running module ssh (<module 'cloudinit.config.cc_ssh' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_ssh.py'>) with frequency once-per-instance
2021-03-06 14:23:50,703 - handlers.py[DEBUG]: start: init-network/config-ssh: running config-ssh with frequency once-per-instance
2021-03-06 14:23:50,703 - helpers.py[DEBUG]: config-ssh already ran (freq=once-per-instance)
2021-03-06 14:23:50,703 - handlers.py[DEBUG]: finish: init-network/config-ssh: SUCCESS: config-ssh previously ran
2021-03-06 14:23:50,703 - main.py[DEBUG]: Ran 15 modules with 0 failures
2021-03-06 14:23:50,704 - atomic_helper.py[DEBUG]: Atomically writing to file /var/lib/cloud/data/status.json (via temporary file /var/lib/cloud/data/tmpdnv5j8dw) - w: [644] 552 bytes/chars
2021-03-06 14:23:50,705 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2021-03-06 14:23:50,705 - util.py[DEBUG]: Read 12 bytes from /proc/uptime
2021-03-06 14:23:50,706 - util.py[DEBUG]: cloud-init mode 'init' took 0.799 seconds (0.80)
2021-03-06 14:23:50,706 - handlers.py[DEBUG]: finish: init-network: SUCCESS: searching for network datasources
2021-03-06 14:24:20,684 - util.py[DEBUG]: Cloud-init v. 20.4.1-0ubuntu1~20.10.1 running 'modules:config' at Sat, 06 Mar 2021 14:24:20 +0000. Up 45.60 seconds.
2021-03-06 14:24:20,752 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.ubuntu.Distro'>
2021-03-06 14:24:20,753 - stages.py[DEBUG]: Running module emit_upstart (<module 'cloudinit.config.cc_emit_upstart' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_emit_upstart.py'>) with frequency always
2021-03-06 14:24:20,754 - handlers.py[DEBUG]: start: modules-config/config-emit_upstart: running config-emit_upstart with frequency always
2021-03-06 14:24:20,755 - helpers.py[DEBUG]: Running config-emit_upstart using lock (<cloudinit.helpers.DummyLock object at 0xffffa59ba370>)
2021-03-06 14:24:20,755 - cc_emit_upstart.py[DEBUG]: no /sbin/initctl located
2021-03-06 14:24:20,755 - cc_emit_upstart.py[DEBUG]: not upstart system, 'emit_upstart' disabled
2021-03-06 14:24:20,755 - handlers.py[DEBUG]: finish: modules-config/config-emit_upstart: SUCCESS: config-emit_upstart ran successfully
2021-03-06 14:24:20,756 - stages.py[DEBUG]: Running module snap (<module 'cloudinit.config.cc_snap' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_snap.py'>) with frequency once-per-instance
2021-03-06 14:24:20,756 - handlers.py[DEBUG]: start: modules-config/config-snap: running config-snap with frequency once-per-instance
2021-03-06 14:24:20,757 - helpers.py[DEBUG]: config-snap already ran (freq=once-per-instance)
2021-03-06 14:24:20,757 - handlers.py[DEBUG]: finish: modules-config/config-snap: SUCCESS: config-snap previously ran
2021-03-06 14:24:20,757 - stages.py[DEBUG]: Running module ssh-import-id (<module 'cloudinit.config.cc_ssh_import_id' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_ssh_import_id.py'>) with frequency once-per-instance
2021-03-06 14:24:20,758 - handlers.py[DEBUG]: start: modules-config/config-ssh-import-id: running config-ssh-import-id with frequency once-per-instance
2021-03-06 14:24:20,758 - helpers.py[DEBUG]: config-ssh-import-id already ran (freq=once-per-instance)
2021-03-06 14:24:20,758 - handlers.py[DEBUG]: finish: modules-config/config-ssh-import-id: SUCCESS: config-ssh-import-id previously ran
2021-03-06 14:24:20,758 - stages.py[DEBUG]: Running module locale (<module 'cloudinit.config.cc_locale' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_locale.py'>) with frequency once-per-instance
2021-03-06 14:24:20,759 - handlers.py[DEBUG]: start: modules-config/config-locale: running config-locale with frequency once-per-instance
2021-03-06 14:24:20,759 - helpers.py[DEBUG]: config-locale already ran (freq=once-per-instance)
2021-03-06 14:24:20,759 - handlers.py[DEBUG]: finish: modules-config/config-locale: SUCCESS: config-locale previously ran
2021-03-06 14:24:20,759 - stages.py[DEBUG]: Running module set-passwords (<module 'cloudinit.config.cc_set_passwords' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_set_passwords.py'>) with frequency once-per-instance
2021-03-06 14:24:20,760 - handlers.py[DEBUG]: start: modules-config/config-set-passwords: running config-set-passwords with frequency once-per-instance
2021-03-06 14:24:20,760 - helpers.py[DEBUG]: config-set-passwords already ran (freq=once-per-instance)
2021-03-06 14:24:20,761 - handlers.py[DEBUG]: finish: modules-config/config-set-passwords: SUCCESS: config-set-passwords previously ran
2021-03-06 14:24:20,761 - stages.py[DEBUG]: Running module grub-dpkg (<module 'cloudinit.config.cc_grub_dpkg' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_grub_dpkg.py'>) with frequency once-per-instance
2021-03-06 14:24:20,761 - handlers.py[DEBUG]: start: modules-config/config-grub-dpkg: running config-grub-dpkg with frequency once-per-instance
2021-03-06 14:24:20,761 - helpers.py[DEBUG]: config-grub-dpkg already ran (freq=once-per-instance)
2021-03-06 14:24:20,762 - handlers.py[DEBUG]: finish: modules-config/config-grub-dpkg: SUCCESS: config-grub-dpkg previously ran
2021-03-06 14:24:20,762 - stages.py[DEBUG]: Running module apt-pipelining (<module 'cloudinit.config.cc_apt_pipelining' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_apt_pipelining.py'>) with frequency once-per-instance
2021-03-06 14:24:20,762 - handlers.py[DEBUG]: start: modules-config/config-apt-pipelining: running config-apt-pipelining with frequency once-per-instance
2021-03-06 14:24:20,763 - helpers.py[DEBUG]: config-apt-pipelining already ran (freq=once-per-instance)
2021-03-06 14:24:20,763 - handlers.py[DEBUG]: finish: modules-config/config-apt-pipelining: SUCCESS: config-apt-pipelining previously ran
2021-03-06 14:24:20,763 - stages.py[DEBUG]: Running module apt-configure (<module 'cloudinit.config.cc_apt_configure' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_apt_configure.py'>) with frequency once-per-instance
2021-03-06 14:24:20,763 - handlers.py[DEBUG]: start: modules-config/config-apt-configure: running config-apt-configure with frequency once-per-instance
2021-03-06 14:24:20,764 - helpers.py[DEBUG]: config-apt-configure already ran (freq=once-per-instance)
2021-03-06 14:24:20,764 - handlers.py[DEBUG]: finish: modules-config/config-apt-configure: SUCCESS: config-apt-configure previously ran
2021-03-06 14:24:20,764 - stages.py[DEBUG]: Running module ubuntu-advantage (<module 'cloudinit.config.cc_ubuntu_advantage' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_ubuntu_advantage.py'>) with frequency once-per-instance
2021-03-06 14:24:20,765 - handlers.py[DEBUG]: start: modules-config/config-ubuntu-advantage: running config-ubuntu-advantage with frequency once-per-instance
2021-03-06 14:24:20,765 - helpers.py[DEBUG]: config-ubuntu-advantage already ran (freq=once-per-instance)
2021-03-06 14:24:20,766 - handlers.py[DEBUG]: finish: modules-config/config-ubuntu-advantage: SUCCESS: config-ubuntu-advantage previously ran
2021-03-06 14:24:20,766 - stages.py[DEBUG]: Running module ntp (<module 'cloudinit.config.cc_ntp' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_ntp.py'>) with frequency once-per-instance
2021-03-06 14:24:20,766 - handlers.py[DEBUG]: start: modules-config/config-ntp: running config-ntp with frequency once-per-instance
2021-03-06 14:24:20,767 - helpers.py[DEBUG]: config-ntp already ran (freq=once-per-instance)
2021-03-06 14:24:20,767 - handlers.py[DEBUG]: finish: modules-config/config-ntp: SUCCESS: config-ntp previously ran
2021-03-06 14:24:20,767 - stages.py[DEBUG]: Running module timezone (<module 'cloudinit.config.cc_timezone' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_timezone.py'>) with frequency once-per-instance
2021-03-06 14:24:20,767 - handlers.py[DEBUG]: start: modules-config/config-timezone: running config-timezone with frequency once-per-instance
2021-03-06 14:24:20,768 - helpers.py[DEBUG]: config-timezone already ran (freq=once-per-instance)
2021-03-06 14:24:20,768 - handlers.py[DEBUG]: finish: modules-config/config-timezone: SUCCESS: config-timezone previously ran
2021-03-06 14:24:20,768 - stages.py[DEBUG]: Running module disable-ec2-metadata (<module 'cloudinit.config.cc_disable_ec2_metadata' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_disable_ec2_metadata.py'>) with frequency always
2021-03-06 14:24:20,769 - handlers.py[DEBUG]: start: modules-config/config-disable-ec2-metadata: running config-disable-ec2-metadata with frequency always
2021-03-06 14:24:20,769 - helpers.py[DEBUG]: Running config-disable-ec2-metadata using lock (<cloudinit.helpers.DummyLock object at 0xffffa59bf430>)
2021-03-06 14:24:20,769 - cc_disable_ec2_metadata.py[DEBUG]: Skipping module named disable-ec2-metadata, disabling the ec2 route not enabled
2021-03-06 14:24:20,770 - handlers.py[DEBUG]: finish: modules-config/config-disable-ec2-metadata: SUCCESS: config-disable-ec2-metadata ran successfully
2021-03-06 14:24:20,770 - stages.py[DEBUG]: Running module runcmd (<module 'cloudinit.config.cc_runcmd' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_runcmd.py'>) with frequency once-per-instance
2021-03-06 14:24:20,770 - handlers.py[DEBUG]: start: modules-config/config-runcmd: running config-runcmd with frequency once-per-instance
2021-03-06 14:24:20,771 - helpers.py[DEBUG]: config-runcmd already ran (freq=once-per-instance)
2021-03-06 14:24:20,771 - handlers.py[DEBUG]: finish: modules-config/config-runcmd: SUCCESS: config-runcmd previously ran
2021-03-06 14:24:20,771 - stages.py[DEBUG]: Running module byobu (<module 'cloudinit.config.cc_byobu' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_byobu.py'>) with frequency once-per-instance
2021-03-06 14:24:20,772 - handlers.py[DEBUG]: start: modules-config/config-byobu: running config-byobu with frequency once-per-instance
2021-03-06 14:24:20,772 - helpers.py[DEBUG]: config-byobu already ran (freq=once-per-instance)
2021-03-06 14:24:20,772 - handlers.py[DEBUG]: finish: modules-config/config-byobu: SUCCESS: config-byobu previously ran
2021-03-06 14:24:20,772 - main.py[DEBUG]: Ran 14 modules with 0 failures
2021-03-06 14:24:20,773 - atomic_helper.py[DEBUG]: Atomically writing to file /var/lib/cloud/data/status.json (via temporary file /var/lib/cloud/data/tmpz75vz1c_) - w: [644] 580 bytes/chars
2021-03-06 14:24:20,774 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2021-03-06 14:24:20,775 - util.py[DEBUG]: Read 13 bytes from /proc/uptime
2021-03-06 14:24:20,775 - util.py[DEBUG]: cloud-init mode 'modules' took 0.267 seconds (0.27)
2021-03-06 14:24:20,775 - handlers.py[DEBUG]: finish: modules-config: SUCCESS: running modules for config
2021-03-06 14:25:04,043 - util.py[DEBUG]: Cloud-init v. 20.4.1-0ubuntu1~20.10.1 running 'modules:final' at Sat, 06 Mar 2021 14:25:03 +0000. Up 58.58 seconds.
2021-03-06 14:25:04,093 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.ubuntu.Distro'>
2021-03-06 14:25:04,095 - stages.py[DEBUG]: Running module package-update-upgrade-install (<module 'cloudinit.config.cc_package_update_upgrade_install' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_package_update_upgrade_install.py'>) with frequency once-per-instance
2021-03-06 14:25:04,096 - handlers.py[DEBUG]: start: modules-final/config-package-update-upgrade-install: running config-package-update-upgrade-install with frequency once-per-instance
2021-03-06 14:25:04,096 - helpers.py[DEBUG]: config-package-update-upgrade-install already ran (freq=once-per-instance)
2021-03-06 14:25:04,096 - handlers.py[DEBUG]: finish: modules-final/config-package-update-upgrade-install: SUCCESS: config-package-update-upgrade-install previously ran
2021-03-06 14:25:04,096 - stages.py[DEBUG]: Running module fan (<module 'cloudinit.config.cc_fan' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_fan.py'>) with frequency once-per-instance
2021-03-06 14:25:04,097 - handlers.py[DEBUG]: start: modules-final/config-fan: running config-fan with frequency once-per-instance
2021-03-06 14:25:04,097 - helpers.py[DEBUG]: config-fan already ran (freq=once-per-instance)
2021-03-06 14:25:04,097 - handlers.py[DEBUG]: finish: modules-final/config-fan: SUCCESS: config-fan previously ran
2021-03-06 14:25:04,097 - stages.py[DEBUG]: Running module landscape (<module 'cloudinit.config.cc_landscape' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_landscape.py'>) with frequency once-per-instance
2021-03-06 14:25:04,098 - handlers.py[DEBUG]: start: modules-final/config-landscape: running config-landscape with frequency once-per-instance
2021-03-06 14:25:04,098 - helpers.py[DEBUG]: config-landscape already ran (freq=once-per-instance)
2021-03-06 14:25:04,098 - handlers.py[DEBUG]: finish: modules-final/config-landscape: SUCCESS: config-landscape previously ran
2021-03-06 14:25:04,098 - stages.py[DEBUG]: Running module lxd (<module 'cloudinit.config.cc_lxd' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_lxd.py'>) with frequency once-per-instance
2021-03-06 14:25:04,099 - handlers.py[DEBUG]: start: modules-final/config-lxd: running config-lxd with frequency once-per-instance
2021-03-06 14:25:04,099 - helpers.py[DEBUG]: config-lxd already ran (freq=once-per-instance)
2021-03-06 14:25:04,099 - handlers.py[DEBUG]: finish: modules-final/config-lxd: SUCCESS: config-lxd previously ran
2021-03-06 14:25:04,099 - stages.py[DEBUG]: Running module ubuntu-drivers (<module 'cloudinit.config.cc_ubuntu_drivers' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_ubuntu_drivers.py'>) with frequency once-per-instance
2021-03-06 14:25:04,099 - handlers.py[DEBUG]: start: modules-final/config-ubuntu-drivers: running config-ubuntu-drivers with frequency once-per-instance
2021-03-06 14:25:04,100 - helpers.py[DEBUG]: config-ubuntu-drivers already ran (freq=once-per-instance)
2021-03-06 14:25:04,100 - handlers.py[DEBUG]: finish: modules-final/config-ubuntu-drivers: SUCCESS: config-ubuntu-drivers previously ran
2021-03-06 14:25:04,100 - stages.py[DEBUG]: Running module puppet (<module 'cloudinit.config.cc_puppet' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_puppet.py'>) with frequency once-per-instance
2021-03-06 14:25:04,100 - handlers.py[DEBUG]: start: modules-final/config-puppet: running config-puppet with frequency once-per-instance
2021-03-06 14:25:04,100 - helpers.py[DEBUG]: config-puppet already ran (freq=once-per-instance)
2021-03-06 14:25:04,101 - handlers.py[DEBUG]: finish: modules-final/config-puppet: SUCCESS: config-puppet previously ran
2021-03-06 14:25:04,101 - stages.py[DEBUG]: Running module chef (<module 'cloudinit.config.cc_chef' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_chef.py'>) with frequency always
2021-03-06 14:25:04,101 - handlers.py[DEBUG]: start: modules-final/config-chef: running config-chef with frequency always
2021-03-06 14:25:04,101 - helpers.py[DEBUG]: Running config-chef using lock (<cloudinit.helpers.DummyLock object at 0xffffa26a0430>)
2021-03-06 14:25:04,101 - cc_chef.py[DEBUG]: Skipping module named chef, no 'chef' key in configuration
2021-03-06 14:25:04,102 - handlers.py[DEBUG]: finish: modules-final/config-chef: SUCCESS: config-chef ran successfully
2021-03-06 14:25:04,102 - stages.py[DEBUG]: Running module mcollective (<module 'cloudinit.config.cc_mcollective' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_mcollective.py'>) with frequency once-per-instance
2021-03-06 14:25:04,102 - handlers.py[DEBUG]: start: modules-final/config-mcollective: running config-mcollective with frequency once-per-instance
2021-03-06 14:25:04,102 - helpers.py[DEBUG]: config-mcollective already ran (freq=once-per-instance)
2021-03-06 14:25:04,103 - handlers.py[DEBUG]: finish: modules-final/config-mcollective: SUCCESS: config-mcollective previously ran
2021-03-06 14:25:04,103 - stages.py[DEBUG]: Running module salt-minion (<module 'cloudinit.config.cc_salt_minion' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_salt_minion.py'>) with frequency once-per-instance
2021-03-06 14:25:04,103 - handlers.py[DEBUG]: start: modules-final/config-salt-minion: running config-salt-minion with frequency once-per-instance
2021-03-06 14:25:04,103 - helpers.py[DEBUG]: config-salt-minion already ran (freq=once-per-instance)
2021-03-06 14:25:04,103 - handlers.py[DEBUG]: finish: modules-final/config-salt-minion: SUCCESS: config-salt-minion previously ran
2021-03-06 14:25:04,104 - stages.py[DEBUG]: Running module reset_rmc (<module 'cloudinit.config.cc_reset_rmc' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_reset_rmc.py'>) with frequency once-per-instance
2021-03-06 14:25:04,104 - handlers.py[DEBUG]: start: modules-final/config-reset_rmc: running config-reset_rmc with frequency once-per-instance
2021-03-06 14:25:04,104 - helpers.py[DEBUG]: config-reset_rmc already ran (freq=once-per-instance)
2021-03-06 14:25:04,104 - handlers.py[DEBUG]: finish: modules-final/config-reset_rmc: SUCCESS: config-reset_rmc previously ran
2021-03-06 14:25:04,104 - stages.py[DEBUG]: Running module refresh_rmc_and_interface (<module 'cloudinit.config.cc_refresh_rmc_and_interface' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_refresh_rmc_and_interface.py'>) with frequency always
2021-03-06 14:25:04,105 - handlers.py[DEBUG]: start: modules-final/config-refresh_rmc_and_interface: running config-refresh_rmc_and_interface with frequency always
2021-03-06 14:25:04,105 - helpers.py[DEBUG]: Running config-refresh_rmc_and_interface using lock (<cloudinit.helpers.DummyLock object at 0xffffa262d580>)
2021-03-06 14:25:04,106 - cc_refresh_rmc_and_interface.py[DEBUG]: No 'rmcctrl' in path, disabled
2021-03-06 14:25:04,106 - handlers.py[DEBUG]: finish: modules-final/config-refresh_rmc_and_interface: SUCCESS: config-refresh_rmc_and_interface ran successfully
2021-03-06 14:25:04,106 - stages.py[DEBUG]: Running module rightscale_userdata (<module 'cloudinit.config.cc_rightscale_userdata' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_rightscale_userdata.py'>) with frequency once-per-instance
2021-03-06 14:25:04,106 - handlers.py[DEBUG]: start: modules-final/config-rightscale_userdata: running config-rightscale_userdata with frequency once-per-instance
2021-03-06 14:25:04,107 - helpers.py[DEBUG]: config-rightscale_userdata already ran (freq=once-per-instance)
2021-03-06 14:25:04,107 - handlers.py[DEBUG]: finish: modules-final/config-rightscale_userdata: SUCCESS: config-rightscale_userdata previously ran
2021-03-06 14:25:04,107 - stages.py[DEBUG]: Running module scripts-vendor (<module 'cloudinit.config.cc_scripts_vendor' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_vendor.py'>) with frequency once-per-instance
2021-03-06 14:25:04,107 - handlers.py[DEBUG]: start: modules-final/config-scripts-vendor: running config-scripts-vendor with frequency once-per-instance
2021-03-06 14:25:04,108 - helpers.py[DEBUG]: config-scripts-vendor already ran (freq=once-per-instance)
2021-03-06 14:25:04,108 - handlers.py[DEBUG]: finish: modules-final/config-scripts-vendor: SUCCESS: config-scripts-vendor previously ran
2021-03-06 14:25:04,108 - stages.py[DEBUG]: Running module scripts-per-once (<module 'cloudinit.config.cc_scripts_per_once' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_per_once.py'>) with frequency once
2021-03-06 14:25:04,108 - handlers.py[DEBUG]: start: modules-final/config-scripts-per-once: running config-scripts-per-once with frequency once
2021-03-06 14:25:04,108 - helpers.py[DEBUG]: config-scripts-per-once already ran (freq=once)
2021-03-06 14:25:04,108 - handlers.py[DEBUG]: finish: modules-final/config-scripts-per-once: SUCCESS: config-scripts-per-once previously ran
2021-03-06 14:25:04,108 - stages.py[DEBUG]: Running module scripts-per-boot (<module 'cloudinit.config.cc_scripts_per_boot' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_per_boot.py'>) with frequency always
2021-03-06 14:25:04,109 - handlers.py[DEBUG]: start: modules-final/config-scripts-per-boot: running config-scripts-per-boot with frequency always
2021-03-06 14:25:04,109 - helpers.py[DEBUG]: Running config-scripts-per-boot using lock (<cloudinit.helpers.DummyLock object at 0xffffa2662130>)
2021-03-06 14:25:04,110 - handlers.py[DEBUG]: finish: modules-final/config-scripts-per-boot: SUCCESS: config-scripts-per-boot ran successfully
2021-03-06 14:25:04,111 - stages.py[DEBUG]: Running module scripts-per-instance (<module 'cloudinit.config.cc_scripts_per_instance' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_per_instance.py'>) with frequency once-per-instance
2021-03-06 14:25:04,111 - handlers.py[DEBUG]: start: modules-final/config-scripts-per-instance: running config-scripts-per-instance with frequency once-per-instance
2021-03-06 14:25:04,112 - helpers.py[DEBUG]: config-scripts-per-instance already ran (freq=once-per-instance)
2021-03-06 14:25:04,112 - handlers.py[DEBUG]: finish: modules-final/config-scripts-per-instance: SUCCESS: config-scripts-per-instance previously ran
2021-03-06 14:25:04,112 - stages.py[DEBUG]: Running module scripts-user (<module 'cloudinit.config.cc_scripts_user' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_user.py'>) with frequency once-per-instance
2021-03-06 14:25:04,112 - handlers.py[DEBUG]: start: modules-final/config-scripts-user: running config-scripts-user with frequency once-per-instance
2021-03-06 14:25:04,112 - helpers.py[DEBUG]: config-scripts-user already ran (freq=once-per-instance)
2021-03-06 14:25:04,113 - handlers.py[DEBUG]: finish: modules-final/config-scripts-user: SUCCESS: config-scripts-user previously ran
2021-03-06 14:25:04,113 - stages.py[DEBUG]: Running module ssh-authkey-fingerprints (<module 'cloudinit.config.cc_ssh_authkey_fingerprints' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_ssh_authkey_fingerprints.py'>) with frequency once-per-instance
2021-03-06 14:25:04,113 - handlers.py[DEBUG]: start: modules-final/config-ssh-authkey-fingerprints: running config-ssh-authkey-fingerprints with frequency once-per-instance
2021-03-06 14:25:04,113 - helpers.py[DEBUG]: config-ssh-authkey-fingerprints already ran (freq=once-per-instance)
2021-03-06 14:25:04,114 - handlers.py[DEBUG]: finish: modules-final/config-ssh-authkey-fingerprints: SUCCESS: config-ssh-authkey-fingerprints previously ran
2021-03-06 14:25:04,114 - stages.py[DEBUG]: Running module keys-to-console (<module 'cloudinit.config.cc_keys_to_console' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_keys_to_console.py'>) with frequency once-per-instance
2021-03-06 14:25:04,114 - handlers.py[DEBUG]: start: modules-final/config-keys-to-console: running config-keys-to-console with frequency once-per-instance
2021-03-06 14:25:04,114 - helpers.py[DEBUG]: config-keys-to-console already ran (freq=once-per-instance)
2021-03-06 14:25:04,114 - handlers.py[DEBUG]: finish: modules-final/config-keys-to-console: SUCCESS: config-keys-to-console previously ran
2021-03-06 14:25:04,114 - stages.py[DEBUG]: Running module phone-home (<module 'cloudinit.config.cc_phone_home' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_phone_home.py'>) with frequency once-per-instance
2021-03-06 14:25:04,115 - handlers.py[DEBUG]: start: modules-final/config-phone-home: running config-phone-home with frequency once-per-instance
2021-03-06 14:25:04,115 - helpers.py[DEBUG]: config-phone-home already ran (freq=once-per-instance)
2021-03-06 14:25:04,115 - handlers.py[DEBUG]: finish: modules-final/config-phone-home: SUCCESS: config-phone-home previously ran
2021-03-06 14:25:04,115 - stages.py[DEBUG]: Running module final-message (<module 'cloudinit.config.cc_final_message' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_final_message.py'>) with frequency always
2021-03-06 14:25:04,116 - handlers.py[DEBUG]: start: modules-final/config-final-message: running config-final-message with frequency always
2021-03-06 14:25:04,116 - helpers.py[DEBUG]: Running config-final-message using lock (<cloudinit.helpers.DummyLock object at 0xffffa2662070>)
2021-03-06 14:25:04,116 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2021-03-06 14:25:04,116 - util.py[DEBUG]: Read 13 bytes from /proc/uptime
2021-03-06 14:25:04,123 - util.py[DEBUG]: Cloud-init v. 20.4.1-0ubuntu1~20.10.1 finished at Sat, 06 Mar 2021 14:25:04 +0000. Datasource DataSourceNoCloud [seed=/dev/mmcblk0p1][dsmode=net]. Up 58.81 seconds
2021-03-06 14:25:04,123 - util.py[DEBUG]: Writing to /var/lib/cloud/instance/boot-finished - wb: [644] 69 bytes
2021-03-06 14:25:04,125 - handlers.py[DEBUG]: finish: modules-final/config-final-message: SUCCESS: config-final-message ran successfully
2021-03-06 14:25:04,125 - stages.py[DEBUG]: Running module power-state-change (<module 'cloudinit.config.cc_power_state_change' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_power_state_change.py'>) with frequency once-per-instance
2021-03-06 14:25:04,125 - handlers.py[DEBUG]: start: modules-final/config-power-state-change: running config-power-state-change with frequency once-per-instance
2021-03-06 14:25:04,125 - helpers.py[DEBUG]: config-power-state-change already ran (freq=once-per-instance)
2021-03-06 14:25:04,126 - handlers.py[DEBUG]: finish: modules-final/config-power-state-change: SUCCESS: config-power-state-change previously ran
2021-03-06 14:25:04,126 - main.py[DEBUG]: Ran 22 modules with 0 failures
2021-03-06 14:25:04,128 - atomic_helper.py[DEBUG]: Atomically writing to file /var/lib/cloud/data/status.json (via temporary file /var/lib/cloud/data/tmpbbaccxk7) - w: [644] 608 bytes/chars
2021-03-06 14:25:04,129 - atomic_helper.py[DEBUG]: Atomically writing to file /var/lib/cloud/data/result.json (via temporary file /var/lib/cloud/data/tmpri5q02ge) - w: [644] 102 bytes/chars
2021-03-06 14:25:04,130 - util.py[DEBUG]: Creating symbolic link from '/run/cloud-init/result.json' => '../../var/lib/cloud/data/result.json'
2021-03-06 14:25:04,130 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2021-03-06 14:25:04,130 - util.py[DEBUG]: Read 13 bytes from /proc/uptime
2021-03-06 14:25:04,130 - util.py[DEBUG]: cloud-init mode 'modules' took 0.240 seconds (0.24)
2021-03-06 14:25:04,130 - handlers.py[DEBUG]: finish: modules-final: SUCCESS: running modules for final
