LXD 5.4 has been released
The LXD team is very excited to announce the release of LXD 5.4!
This should be the beginning of us pushing out quite a few new features over the next few releases with this one coming with one major new feature and the foundation needed for more to come.
Enjoy!
Upgrade notes
Changes to vsock API (LXD VMs)
As part of the work on the bi-directional vsock interface (see below), we noticed the our TLS arrangement for host to guest communications inside of LXD VMs was quite broken.
Nothing that would be a concern from a security standpoint as the server and client authentication were all done correctly, but for some reason we were doing TLS over TLS which doubled the overhead for no good reason and actually prevented the REST/HTTP layer from accessing details about the client.
This release fixes this issue by updating both LXD and the VM agent to only do a single layer of TLS. Unfortunately, this isn’t something we could handle in a backwards compatible way…
As a result, upon upgrading to LXD 5.4, agent communication will break with all running virtual machines. This will affect lxc exec and lxc file. Restarting the affected VMs with lxc restart will correct this by having the VM restart with an updated version of the agent.
New features and highlights
Load-balancers (OVN)
The biggest new feature in this release. This introduces the concept of network load balancers to LXD.
Similar in concept to the existing network forwards feature, load-balancers differ in that a particular address or port can have multiple target with OVN handling load-balancing by hashing the source and destination addresses.
This is all handled through lxc network load-balancer and is currently restricted to OVN networks.
Documentation: Linux Containers - LXD - Has been moved to Canonical
Specification: [LXD] Network load-balancers (OVN)
Bi-directional vsock interface (VM)
For LXD VMs, the LXD daemon interacts with an agent (lxd-agent) running inside of the virtual machine. This allows for things like lxc exec and lxc file to work in a similar way with a VM as they would a container.
This is done through each VM listening on vsock and the host connecting to the agent.
However until this release, there was no way for the agent to connect to the host.
This was mostly fine with the only side effect of this being some missing features over the /dev/lxd guest API. But with more planned work for VM features, we really needed a way for the agent to directly connect to the host.
This is now possible with this release as LXD will itself listen on vsock and allow VMs to connect to it. Similarly to our normal agent connections, this is all authenticated through TLS certificates so LXD can tell what VM is talking to it and ensure that it is in fact the agent (or something having access to the agent keys) talking to it.
Specification: [LXD] Bidirectional vsock interface for VMs
Reworked storage documentation
Following our recent rework of the networking documentation, in this release, it’s the storage documentation that got significantly reworked and reorganized.
This brings in a much clearer structure, some new content and will keep evolving over the next few releases.
Consistent storage volume configuration
As part of the documentation effort above, we discovered some inconsistencies in how storage volume configurations were applied to storage volumes.
Specifically, storage pools can have configuration keys with the following pattern volume.XYZ. Those keys should then be applied to any newly created volume, effectively acting as a default value.
Where things weren’t consistent is that not all volume keys were supported and moreover, when supported, in some cases the key would be correctly copied into the volume config but in other cases, it would not and instead be propagated from the pool to the volumes, leading to issues should the pool configuration be modified.
LXD 5.4 makes all of this consistent by having all storage volumes keys be supported and by having them all only get copied from pool to volume at creation time.
Project support in lxd-benchmark
The built-in benchmarking tool, lxd-benchmark (lxd.benchmark for snap users) hasn’t been touched in quite a few years. While dusting it off recently, we noticed that its lack of project support was problematic for us and trivial to add.
So now, it’s been added and lxd-benchmark will now accept a --project NAME argument.
Complete changelog
Full commit list
  • doc: storage: clarify moving of storage volumes
  • doc: fix version switcher to work for latest
  • lxd/network/openvswitch: Use %s so that delimiting quotes are not escaped.
  • shared/subprocess/manager: Improve errors in ImportProcess
  • doc: storage: clarify that most docs are about custom volumes
  • doc: fix typo
  • gomod: Switch to github for go-lxc
  • gomod: Update dependencies
  • lxd: Update to github path for go-lxc
  • lxc-to-lxd: Update to github path for go-lxc
  • lxd: Use liblxc’s RuntimeLiblxcVersionAtLeast
  • shared/api: Fix typo in event name
  • shared/api: Add missing events
  • shared/api: Sort events
  • doc/events: Add missing events
  • doc/events: Sort entries
  • lxd/lifecycle: Use event names from api package
  • client: End all function comments with a full-stop.
  • client: Fixes imports.
  • lxc/config: End comments with a full-stop.
  • lxc/utils: End comments with a full-stop.
  • lxc/utils: Fix import order.
  • lxc: End comments with a full-stop.
  • lxc: Fixes import order.
  • lxc: Removes unnecessary whitespace.
  • lxc-to-lxd: Ends all comments with a full-stop.
  • lxd/apparmor: Ends all comments with a full-stop.
  • lxd/cgroup: Ends all comments with a full-stop.
  • lxd/bgp: Fixes import order.
  • lxd/cluster/config: Ends all comments with a full-stop.
  • lxd/cluster/config: Removes unnecessary whitespace.
  • lxd/cluster/config: Fixes imports.
  • lxd/cluster: Ends all comments with a full-stop.
  • lxd/cluster: Removes unnecessary whitespace.
  • lxd/cluster: Fixes imports.
  • lxd/config: Fixes imports.
  • lxd/config: Ends all comments with a full-stop.
  • lxd-generate: Ensure generated comments end with a full-stop.
  • lxd/db/cluster: Ends all comments with a full-stop.
  • lxd/db/cluster: Fixes imports.
  • lxd/db/generate/db: Removes unnecessary whitespace.
  • lxd/db/generate/db: Fixes imports.
  • lxd/db/generate/db: Ends all comments with a full-stop.
  • lxd/db/generate/lex: Ends all comments with a full-stop.
  • lxd/db/generate/lex: Fixes imports.
  • lxd/db/generate: Removes unnecessary whitespace.
  • lxd/db/generate: Fixes imports.
  • lxd/db/operationtype: Ends all comments with a full-stop.
  • lxd/db/query: Fixes imports.
  • lxd/db/schema: Ends all comments with a full-stop.
  • lxd/db: Removes unnecessary whitespace.
  • lxd/db: Fixes imports.
  • lxd/db: Ends all comments with a full-stop.
  • lxd/device/nictype: Removes unnecessary whitespace.
  • lxd/device: Ends all comments with a full-stop.
  • lxd/device: Removes unnecessary whitespace.
  • lxd/device: Fixes imports.
  • lxd/dnsmasq: Removes unnecessary whitespace.
  • lxd/endpoints: Fixes imports.
  • lxd/endpoints: Ends all comments with a full-stop.
  • lxd/filter: Fixes imports.
  • lxd/filter: Removes unnecessary whitespace.
  • lxd/firewall/drivers: Ends all comments with a full-stop.
  • lxd/firewall/drivers: Removes unnecessary whitespace.
  • lxd/fsmonitor/drivers: Ends all comments with a full-stop.
  • lxd/instance/drivers/qmp: Ends all comments with a full-stop.
  • lxd/instance/drivers/qmp: Removes unnecessary whitespace.
  • lxd/instance/drivers: Removes unnecessary whitespace.
  • lxd/instance/drivers: Fixes imports.
  • lxd/instance/drivers: Ends all comments with a full-stop.
  • lxd/instance: Ends all comments with a full-stop.
  • lxd/ip: Ends all comments with a full-stop.
  • lxd/lifecycle: Ends all comments with a full-stop.
  • lxd/maas: Ends all comments with a full-stop.
  • lxd/metrics: Ends all comments with a full-stop.
  • lxd/migration: Ends all comments with a full-stop.
  • lxd/network/acl: Removes unnecessary whitespace.
  • lxd/network/openvswitch: Removes unnecessary whitespace.
  • lxd/network/zone: Fixes imports.
  • lxd/network: Removes unnecessary whitespace.
  • lxd/network: Ends all comments with a full-stop.
  • lxd/node: Ends all comments with a full-stop.
  • lxd/node: Fixes imports.
  • lxd/operations: Ends all comments with a full-stop.
  • lxd/operations: Removes unnecessary whitespace.
  • lxd/project: Removes unnecessary whitespace.
  • lxd/project: Ends all comments with a full-stop.
  • lxd/rbac: Ends all comments with a full-stop.
  • lxd/request: Ends all comments with a full-stop.
  • lxd/resources: Ends all comments with a full-stop.
  • lxd/response: Ends all comments with a full-stop.
  • lxd/seccomp: Removes unnecessary whitespace.
  • lxd/seccomp: Fixes imports.
  • lxd/storage/drivers: Ends all comments with a full-stop.
  • lxd/storage/drivers: Removes unnecessary whitespace.
  • lxd/storage/memorypipe: Ends all comments with a full-stop.
  • lxd/storage: Removes unnecessary whitespace.
  • lxd/storage: Ends all comments with a full-stop.
  • lxd/sys: Ends all comments with a full-stop.
  • lxd/sys: Fixes imports.
  • lxd/task: Removes unnecessary whitespace.
  • lxd/task: Fixes imports.
  • lxd/template: Ends all comments with a full-stop.
  • lxd/util: Fixes imports.
  • lxd/util: Ends all comments with a full-stop.
  • lxd/util: Removes unnecessary whitespace.
  • lxd: Fixes imports.
  • lxd: Removes unnecessary whitespace.
  • lxd: Ends all comments with a full-stop.
  • lxd: Fixes misspelling.
  • lxd-agent: Fixes imports.
  • lxd-agent: Removes unnecessary whitespace.
  • lxd-agent: Ends all comments with a full-stop.
  • lxd-benchmark/benchmark: Removes unnecessary whitespace.
  • lxd-migrate: Ends all comments with a full-stop.
  • shared/api: Ends all comments with a full-stop.
  • shared/cancel: Ends all comments with a full-stop.
  • shared/cmd: Ends all comments with a full-stop.
  • shared/dnsutil: Ends all comments with a full-stop.
  • shared/eagain: Ends all comments with a full-stop.
  • shared/i18n: Ends all comments with a full-stop.
  • shared/idmap: Ends all comments with a full-stop.
  • shared/idmap: Fixes imports.
  • shared/ioprogress: Ends all comments with a full-stop.
  • shared/logger: Ends all comments with a full-stop.
  • shared/osarch: Ends all comments with a full-stop.
  • shared/simplestreams: Ends all comments with a full-stop.
  • shared/subprocess: Ends all comments with a full-stop.
  • shared/subprocess: Fixes imports.
  • shared/units: Ends all comments with a full-stop.
  • shared/version: Ends all comments with a full-stop.
  • shared: Ends all comments with a full-stop.
  • shared: Fixes imports.
  • shared: Removes unnecessary whitespace.
  • test/macaroon-identity: Fixes imports.
  • test/macaroon-identity: Ends all comments with a full-stop.
  • golangci: Adds golangci-lint configuration file.
  • doc: add link to YouTube video about image handling
  • lxd/instance/lxc: Don’t fail on missing apparmor
  • client: Inserts newlines after blocks.
  • fuidshift: Inserts newlines after blocks.
  • lxc: Inserts newlines after blocks.
  • lxc-to-lxd: Inserts newlines after blocks.
  • lxd-agent: Inserts newlines after blocks.
  • lxd-benchmark: Inserts newlines after blocks.
  • lxd-migrate: Inserts newlines after blocks.
  • lxd-user: Inserts newlines after blocks.
  • shared: Inserts newlines after blocks.
  • test: Inserts newlines after blocks.
  • lxd/archive: Inserts newlines after blocks.
  • lxd/backup: Inserts newlines after blocks.
  • lxd/bgp: Inserts newlines after blocks.
  • lxd/cgroup: Inserts newlines after blocks.
  • lxd/cluster: Inserts newlines after blocks.
  • lxd/config: Inserts newlines after blocks.
  • lxd/db: Inserts newlines after blocks.
  • lxd/device: Inserts newlines after blocks.
  • lxd/dns: Inserts newlines after blocks.
  • lxd/dnsmasq: Inserts newlines after blocks.
  • lxd/endpoints: Inserts newlines after blocks.
  • lxd/events: Inserts newlines after blocks.
  • lxd/filter: Inserts newlines after blocks.
  • lxd/firewall/drivers: Inserts newlines after blocks.
  • lxd/fsmonitor/drivers: Inserts newlines after blocks.
  • lxd/instance: Inserts newlines after blocks.
  • lxd/ip: Inserts newlines after blocks.
  • lxd/maas: Inserts newlines after blocks.
  • lxd/metrics: Inserts newlines after blocks.
  • lxd/migration: Inserts newlines after blocks.
  • lxd/network: Inserts newlines after blocks.
  • lxd/operations: Inserts newlines after blocks.
  • lxd/project: Inserts newlines after blocks.
  • lxd/rbac: Inserts newlines after blocks.
  • lxd/request: Inserts newlines after blocks.
  • lxd/resources: Inserts newlines after blocks.
  • lxd/response: Inserts newlines after blocks.
  • lxd/rsync: Inserts newlines after blocks.
  • lxd/seccomp: Inserts newlines after blocks.
  • lxd/storage: Inserts newlines after blocks.
  • lxd/sys: Inserts newlines after blocks.
  • lxd/task: Inserts newlines after blocks.
  • lxd/util: Inserts newlines after blocks.
  • lxd/vsock: Inserts newlines after blocks.
  • lxd: Inserts newlines after blocks.
  • lxc: Removes all one-line assign and check statements.
  • lxc-to-lxd: Removes all one-line assign and check statements.
  • lxd/backup: Removes all one-line assign and check statements.
  • lxd/cluster: Removes all one-line assign and check statements.
  • lxd-generate: One-line assign and check statements.
  • lxd/db/generate: Removes all one-line assign and check statements.
  • lxd/db/generate: Use multiline import syntax.
  • lxd/db: Removes all one-line assign and check statements.
  • lxd/db: Use multiline import syntax.
  • lxd/config: Use multiline import syntax.
  • lxd/device: Removes all one-line assign and check statements.
  • lxd/device: Use multiline import syntax.
  • lxd/dnsmasq: Removes all one-line assign and check statements.
  • lxd/firewall/drivers: Removes all one-line assign and check statements.
  • lxd/firewall/drivers: Use multiline import syntax.
  • lxd/fsmonitor/drivers: Use multiline import syntax.
  • lxd/instance/drivers: Removes all one-line assign and check statements.
  • lxd/network/acl: Removes all one-line assign and check statements.
  • lxd/network/openvswitch: Removes all one-line assign and check statements.
  • lxd/network: Removes all one-line assign and check statements.
  • lxd/refcount: Removes all one-line assign and check statements.
  • lxd/resources: Removes all one-line assign and check statements.
  • lxd/response: Removes all one-line assign and check statements.
  • lxd/rsync: Removes all one-line assign and check statements.
  • lxd/seccomp: Removes all one-line assign and check statements.
  • lxd/storage/drivers: Removes all one-line assign and check statements.
  • lxd/storage: Removes all one-line assign and check statements.
  • lxd/util: Removes all one-line assign and check statements.
  • lxd/util: Use multiline import syntax.
  • lxd: Removes all one-line assign and check statements.
  • lxd-agent: Removes all one-line assign and check statements.
  • lxd-migrate: Removes all one-line assign and check statements.
  • shared/api: Use multiline import syntax.
  • shared/cancel: Use multiline import syntax.
  • shared/idmap: Removes all one-line assign and check statements.
  • shared/instancewriter: Removes all one-line assign and check statements.
  • shared/termios: Removes all one-line assign and check statements.
  • shared/usbid: Removes all one-line assign and check statements.
  • shared: Removes all one-line assign and check statements.
  • test: Removes all one-line assign and check statements.
  • test/lint: Adds shell based linters.
  • Makefile: Updates static-analysis target.
  • test/suites: Removes static analysis suite.
  • workflows: Adds static analysis job.
  • lxd/network/driver/common: Fix comment typos
  • lxd/db/network/forwards: Fix error handling in GetNetworkForward
  • lxd/network/driver/common: Adds forwardTarget type
  • lxd/network/driver/bridge: Update forwardConvertToFirewallForwards to support new forward target type
  • lxd/network/driver/common: Adds usageType field to externalSubnetUsage
  • lxd/network/driver/common: Update forwardValidate to use forwardTarget type
  • lxd/network/driver/bridge: Update subnet usage to use usageType
  • lxd/network/driver/ovn: Updates to support subnet use usageType field
  • lxd/network/openvswitch/ovn: Updates LoadBalancerApply to support multiple targets via OVNLoadBalancerTarget
  • lxd/network/driver/ovn: Update forwardFlattenVIPs to support updated openvswitch.OVNLoadBalancerVIP
  • lxd/network/driver/ovn: Fix network ForwardUpdate revert
  • test/lint/client-imports: grep for fixed string before sorting
  • test/lint/i18n-up-to-date: move lxd.pot instead of copying it
  • test/lint/mixed-whitespace: only process files with .sh extention
  • test/lint/negated-is-bool: use git grep and only check .go files
  • test/lint/newline-after-block: use git ls-files instead of find
  • test/lint/no-short-form-imports: use git grep and avoid early exit
  • test/lint/trailing-space: use git grep and only check .sh files
  • Makefile: use run-parts to run test/lint
  • test/lint: tell git grep to consider tracked and untracked files
  • test/lint: tell git ls-files to consider tracked and untracked files
  • lxd/network/driver/ovn: Inserts newlines after blocks.
  • test/lint/i18n-up-to-date: don’t leave dirty .po files behind
  • workflows: Removes unit tests and reinstates ubuntu client tests.
  • lxd/db/generate/lex: Use cases.Title instead of deprecated strings.Title.
  • lxd/db/generate/db/method/v2: Fix config error handling
  • lxd/db/cluster/mapper: Update generated code
  • doc/ovn: fix steps for OVN cluster setup
  • doc: fix nested ordered lists
  • test: Update test_container_devices_disk_socket to test both start time and hotplug
  • test: Adds test_container_devices_disk_char to check passing char devices as disks
  • workflows/static-analysis: Download but do not update dependencies.
  • client: Move to bakery.v3
  • lxc: Move to bakery.v3
  • lxd-migrate: Move to bakery.v3
  • lxd: Move to bakery.v3
  • test: Move to bakery.v3
  • gomod: Update dependenies
  • lxd/resources: Handle invalid VPD lengths
  • lxd/response: Fix swagger structs
  • lxd/db/cluster/projects: Improve error in ToAPI
  • lxd/db/instances: Optimise query pattern for InstanceList
  • lxd/db/instance: Remove profiles arg from instanceFunc in InstanceList
  • lxd: InstanceList updated usage
  • lxd-benchmark: Add --project flag
  • lxd/db/instances/test: Specify expected and actual order correctly in TestInstanceList
  • lxd/db/instances: InstanceList
  • lxd/db/instances: Adds InstanceListOpts type to allow retrieving config and devices optional for InstanceList
  • lxd: Update InstanceList usage
  • api: Adds network_load_balancer API extension
  • shared/api: Adds network load balancer types
  • shared/api/event/lifecycle: Adds network load balancer lifecycle constants
  • lxd/lifecycle/network/load/balancer: Adds network load balancer lifecycle helper
  • lxd/db/cluster: Adds networks_load_balancers and networks_load_balancers_config tables
  • lxd/db/network/load/balancers: Adds network load balancer DB functions
  • lxd/network: Adds LoadBalancers field to Info and enables it for OVN networks
  • lxd/network/driver/common: Adds loadBalancerPortMap type
  • lxd/network/driver/common: Adds subnetUsageNetworkLoadBalancer constant
  • lxd/network: Add load balancer functions to interface and common driver
  • lxd/network/driver/ovn: Updates getExternalSubnetInUse to account for load balancers
  • lxd/network/driver/ovn: Load balancer management functions
  • lxd/network/load/balancers: Adds load balancer API endpoints
  • client/lxd/server: Adds CheckExtension function
  • client: Adds network load balancer functions
  • lxc: Adds network load balancer commands
  • doc: Add missing network forward delete section
  • doc: Adds network load balancer documentation
  • lxd/storage/drivers/volume: Don’t use short arguments in NewVolume
  • lxd/storage/backend/lxd: Improve logging in CreateInstanceFromBackup
  • doc/storage: structure configuration options section
  • doc/storage: structure driver notes
  • lxd/instance/qemu: Fix qemuCPU template broken numa section
  • lxd/storage/backend/lxd: Add missing size.state check to UpdateInstance
  • lxd/storage/backend/lxd: Replaces instanceEffectiveRootVolume with applyInstanceRootDiskOverrides
  • lxd/storage/backend/lxd: b.applyInstanceRootDiskOverrides usage
  • lxd/storage/backend: Update b.applyInstanceRootDiskOverrides usage in CreateInstanceFromCopy
  • test: Updates tests to check for instance root disk size not leaking into storage volume DB record
  • lxd-agent: Remove legacy code
  • lxd/vsock: Undo double TLS
  • lxd-agent: Undo double TLS
  • lxd/instance/operationlock: Allow InstanceOperation.Action() to be called on nil InstanceOperation
  • lxd/instance/drivers/driver/lxc: Don’t wait for update operation to complete when removing disk from running container
  • Revert “lxd/db/instances: Adds InstanceListOpts type to allow retrieving config and devices optional for InstanceList”
  • Revert “lxd: Update InstanceList usage”
  • test: Fixes lint errors for shellcheck 0.8.0.
  • workflows: Installs shellcheck version 0.8.0.
  • Makefile: Warns if shellcheck version is not 0.8.0.
  • doc/storage: add introductions for storage drivers
  • doc/storage: clean up terminology
  • doc/storage: clean up driver notes
  • doc/storage: clean up tables
  • doc/storage/ceph: add information about remote storage
  • doc/storage/cephfs: clarify that the file system must exist
  • doc/instances: add link to NVIDIA video
  • lxd: Replace use of cluster “node” with “member” in user facing text
  • doc: add a more complete prometheus.yaml example
  • doc/networks: move load balancers documentation under OVN
  • lxd/db/generate/db/method/v2: Properly attach package name for external calls
  • lxd/db/generate/db/stmt: Allow overriding table name with config key
  • lxd/db/generate/db/method/v2: Limit generated method references to same package
  • doc/networks: small fixes to load balancer docs
  • lxd/resources: Better handle invalid VPD
  • doc/storage: add tip about volume.* configuration
  • doc/storage: remove limitation about XFS as file system for Ceph
  • doc/storage: remove mentions of ceph.osd.force_reuse
  • doc: Fix use of setup/set up
  • lxd-agent: Always close file
  • lxd-agent: Introduce CONNECTED state
  • shared/api: Add API10Put
  • lxd-agent: Add PUT /1.0 endpoint
  • lxd/endpoints: Add vsock endpoint
  • lxd/vsock: Add port argument to HTTPClient
  • lxd/instance: Add VM interface
  • lxd/instance/drivers: Add advertiseVsockAddress
  • lxd/instance/drivers: Add AgentCertificate
  • lxd/db/instances: Add GetLocalInstanceWithVsockID
  • shared/api: Add VsockServerGet
  • lxd/response: Add devLxdResponse
  • lxd/devlxd: Use response.DevLxdResponse
  • lxd/devlxd: Allow setting hoist function for devlxd server
  • lxd: Add vsock server
  • lxd-agent: Use vsock interface for devlxd
  • lxd/instance/drivers/qemu: Handle LXD-AGENT-READY event
  • lxd/instance/drivers/qmp: Call event handler if lxd-agent becomes ready
  • lxd/instance/drivers/qemu: Remove instance-data file
  • api: Add vsock_api
  • lxd/instance/drivers: Handle security.devlxd config change
  • lxd/endpoints: Update endpoints test
  • lxd/storage: Add poolAndVolumeCommonRules function
  • lxd/storage/drivers: Support common pool and volume configuration options
  • lxd/storage/drivers: Support for propagation of the volume.* configuration options to the new storage volume
  • doc: Update storage config keys propagation
  • tests: Test propagation volume.* config keys for new storage volumes
  • lxd/storage/drivers/driver/ceph: Mark ceph.osd.force_reuse as deprecated
  • scripts/bash/lxd-client: Remove ceph.osd.force_reuse
  • lxc/monitor: Clarify that --log-level can only be used with pretty formatting mode
  • doc/storage: add a howto for launching instances in a specific pool
  • doc/storage: add howto for resizing storage
  • doc/storage: “size” option missing for Btrfs & LVM storage pools
  • lxd/storage/drivers/driver/lvm/utils: Fix parse errors when instance not running
  • doc/storage: move content from FAQ to storage section
  • lxd/resources: Better handle ethtool errors
  • lxd/instance/drivers: Handle QEMU I/O errors
  • lxd/db/cluster: Make config table value fields NOT NULL
  • client: Use 30s HTTP header timeout in GetImageFile and GetPrivateImageFile
  • lxd/daemon/images: Use 30s HTTP header timeout in ImageDownload
  • lxd/db/node: Make config table value fields NOT NULL
  • lxd/instance/drivers/driver/qemu: Fix instance reference leak in getMonitorEventHandler
  • doc: Update cloud-init.md with user-data examples
  • lxd/instance/drivers: Rename LXD-AGENT-READY to LXD-AGENT-STARTED
  • lxd/instance/drivers/qmp: Rename agentReady to agentStarted
  • lxd/instance/drivers: Rename AgenReady to AgentStarted
  • lxd/db/generate/db/method: Fix v1 generator code style
  • lxd/devices: Improve comments in devicesRegister
  • lxd/db/instances: Add support for instancetype.Any to InstanceList
  • lxd/instance/instance/utils: Updates LoadNodeAll to use InstanceList
  • lxd/instance: Updates instanceLoadNodeProjectAll to use InstanceList
  • lxd/cluster/config/config: Adds InstancesNICHostname function
  • lxd/device/device/common: Updates generateHostName to use d.state.GlobalConfig.InstancesNICHostname
  • lxd/cluster/config/config: Adds BackupsCompressionAlgorithm function
  • lxd/backup: Use s.GlobalConfig.BackupsCompressionAlgorithm
  • lxd/certificates: Updates certificatesPost to use config.TrustPassword
  • lxd/cluster/config/config: Adds NetworkOVNIntegrationBridge function
  • lxd/device/nic/ovn: Use d.state.GlobalConfig.NetworkOVNIntegrationBridge
  • lxd/cluster/config/config: Adds ImagesCompressionAlgorithm function
  • lxd/images: Updates imgPostInstanceInfo to use d.State().GlobalConfig.ImagesCompressionAlgorithm
  • lxd/cluster/config/config: Adds NetworkOVNNorthboundConnection function
  • lxd/network/openvswitch/ovn: Updates NewOVN to use s.GlobalConfig.NetworkOVNNorthboundConnection
  • lxd/instance/drivers/driver/common: Updates MAAS functions to use d.state.GlobalConfig.MAASController
  • lxd/cluster/config/config: Removes unused GetString function
  • lxd/cluster/config/config: Adds ImagesAutoUpdateCached function
  • lxd/instances/post: Updates createFromImage to use GlobalConfig.ImagesAutoUpdateCached
  • lxd/cluster/config/config: Removes unused GetBool function
  • lxd/cluster/config/config: Adds ImagesAutoUpdateIntervalHours function
  • lxd/daemon/images: Updates ImageDownload to use GlobalConfig.ImagesAutoUpdateIntervalHours
  • lxd/images: Updates autoUpdateImage to use GlobalConfig.ImagesAutoUpdateIntervalHours
  • lxd/cluster/config/config: Adds ImagesRemoteCacheExpiryDays function
  • lxd/images: Updates pruneExpiredImagesInProject to use GlobalConfig.ImagesRemoteCacheExpiryDays
  • lxd/cluster/config/config: Removes unused GetInt64 function
  • lxd/cluster/config/config: Removes unused configGet function
  • lxd/storage/utils: Remove unnecessary tx.GetLocalNodeName from VolumeUsedByExclusiveRemoteInstancesWithProfiles
  • lxd/network/network/utils/sriov: Remove unnecessary tx.GetLocalNodeName from SRIOVGetHostDevicesInUse
  • lxd/network/driver/bridge: Remove unnecessary tx.GetLocalNodeName from ForwardCreate
  • lxd/api/cluster: Remove unnecessary tx.GetLocalNodeName from clusterGet
  • lxd/db/node: Adds comment about usage to GetLocalNodeName
  • lxd/events: Remove unnecessary tx.GetLocalNodeName from eventsSocket
  • lxd/instance/instance/utils: Remove unnecessary tx.GetLocalNodeName from CreateInternal
  • lxd/instances/post: Remove unnecessary tx.GetLocalNodeName from createFromCopy
  • lxd/profiles/utils: Remove unnecessary tx.GetLocalNodeName from doProfileUpdate
  • lxd/profiles/utils: Remove unnecessary tx.GetLocalNodeName from doProfileUpdateCluster
  • lxd/storage/backend/lxd: Remove unnecessary tx.GetLocalNodeName from ImportInstance
  • lxd/storage/pools: Remove unnecessary tx.GetLocalNodeName from storagePoolsPostCluster
  • shared/api: Remove non-API structs
  • lxd-agent: Add API package
  • lxd-agent: Update for new API structs
  • lxd: Update for new API structs
  • i18n: Update translations from weblate
Try it for yourself
This new LXD release is already available for you to try on our demo service.
Downloads
The release tarballs can be found on our download page.
Binary builds are also available for:
  • Linux: snap install lxd
  • MacOS: brew install lxc
  • Windows: choco install lxc
LXD 5.4 is available in latest/candidate for our snap users and should hit latest/stable over the coming 2-3 days.
The traditional release live stream is scheduled for 2pm Eastern on Monday:
https://youtu.be/JhUk5QDo1rs
