LXD and Docker Firewall Redux - How to deal with FORWARD policy set to drop
All:
While there are a lot of discussions regards LXD problems associated with Docker setting the FORWARD policy to drop and thus preventing the container from being to access the internet, there isn’t - or I haven’t found - a working example of how to fix the problems.
One solution is to add the following rule: iptables -I DOCKER-USER -i src_if -o dst_if -j ACCEPT
But I have no idea on how to determine the src_if or the dst_if.
I’ve seen other posts with other solutions which either don’t work or don’t make sense if one is not well versed in iptables.
Can someone post a canonical answer including an real world example using real world interfaces?
Thanks in advance,
-steve
I agree it would be useful to have a firewall guide for manual setup.
The network documentation is rather generic (set it to trusted zone: https://github.com/lxc/lxd/blob/master/doc/networks.md#allow-dhcp-dns-with-firewalld ) and includes only firewalld.
The docker manual has some information on preventing their default behaviour of preventing the host operating as a router (which LXD needs).
In your case the -i <src_if> src_if would be your lxdbr0 interface and -o dst_if would be your external interface.
However you could relax this further and just use:
 iptables -I DOCKER-USER  -j ACCEPT
To allow all traffic.
However the reason there isn’t a canonical answer for this is that it all depends on your particular networking setup and your security stance (allowing all traffic maybe not what you want for example).
I’ve just tried installing LXD and Docker side by side in a fresh Ubuntu Focal VM:
Install LXD and test connectivity from a container:
apt install snapd -y; snap install lxd
lxd init --auto
lxc launch images:ubuntu/focal c1
lxc exec c1 -- ping 8.8.8.8
Install docker via instructions at https://docs.docker.com/engine/install/ubuntu/
Then reboot so both are using iptables rather than nftables.
Take a look at iptables rules:
iptables-save
# Generated by iptables-save v1.8.4 on Mon Jan 18 12:45:12 2021
*mangle
:PREROUTING ACCEPT [119:46747]
:INPUT ACCEPT [107:45739]
:FORWARD ACCEPT [12:1008]
:OUTPUT ACCEPT [132:15000]
:POSTROUTING ACCEPT [144:16008]
-A POSTROUTING -o lxdbr0 -p udp -m udp --dport 68 -m comment --comment "generated for LXD network lxdbr0" -j CHECKSUM --checksum-fill
COMMIT
# Completed on Mon Jan 18 12:45:12 2021
*filter
:INPUT ACCEPT [105:45123]
:FORWARD DROP [0:0]
:OUTPUT ACCEPT [130:14342]
:DOCKER - [0:0]
:DOCKER-ISOLATION-STAGE-1 - [0:0]
:DOCKER-ISOLATION-STAGE-2 - [0:0]
:DOCKER-USER - [0:0]
-A INPUT -i lxdbr0 -p tcp -m tcp --dport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A INPUT -i lxdbr0 -p udp -m udp --dport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A INPUT -i lxdbr0 -p udp -m udp --dport 67 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A FORWARD -o lxdbr0 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A FORWARD -i lxdbr0 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A FORWARD -j DOCKER-USER
-A FORWARD -j DOCKER-ISOLATION-STAGE-1
-A FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -o docker0 -j DOCKER
-A FORWARD -i docker0 ! -o docker0 -j ACCEPT
-A FORWARD -i docker0 -o docker0 -j ACCEPT
-A OUTPUT -o lxdbr0 -p tcp -m tcp --sport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A OUTPUT -o lxdbr0 -p udp -m udp --sport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A OUTPUT -o lxdbr0 -p udp -m udp --sport 67 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A DOCKER-ISOLATION-STAGE-1 -i docker0 ! -o docker0 -j DOCKER-ISOLATION-STAGE-2
-A DOCKER-ISOLATION-STAGE-1 -j RETURN
-A DOCKER-ISOLATION-STAGE-2 -o docker0 -j DROP
-A DOCKER-ISOLATION-STAGE-2 -j RETURN
-A DOCKER-USER -j RETURN
COMMIT
*nat
:PREROUTING ACCEPT [3:470]
:INPUT ACCEPT [1:302]
:OUTPUT ACCEPT [27:2228]
:POSTROUTING ACCEPT [26:2188]
:DOCKER - [0:0]
-A PREROUTING -m addrtype --dst-type LOCAL -j DOCKER
-A OUTPUT ! -d 127.0.0.0/8 -m addrtype --dst-type LOCAL -j DOCKER
-A POSTROUTING -s 10.249.25.0/24 ! -d 10.249.25.0/24 -m comment --comment "generated for LXD network lxdbr0" -j MASQUERADE
-A POSTROUTING -s 172.17.0.0/16 ! -o docker0 -j MASQUERADE
-A DOCKER -i docker0 -j RETURN
COMMIT
They key lines here are:
This is where docker has modified the FORWARD policy to drop all unmatched traffic:
:FORWARD DROP [0:0]
But here we can see that docker has added a catch-all jump into the DOCKER-USER chain, but before that LXD has added allow rules for traffic for lxdbr0.
In my case this means that networking is running OK. So it may just be a case of ensuring LXD starts before Docker. However it would be interesting to see the output of iptables-save in your case when it isn’t working. I suspect there may be a race between docker and LXD rule ordering that can affect it.
Hey Tomp,
I just had my internet access from lxc containers stop working today. I also have docker installed along on the host as well as the lxc container
For comparison sake here’s my iptables-save
# Generated by iptables-save v1.8.4 on Mon Jan 18 22:44:14 2021
*raw
:PREROUTING ACCEPT [201740:677885538]
:OUTPUT ACCEPT [185859:40757442]
COMMIT
# Completed on Mon Jan 18 22:44:14 2021
*mangle
:INPUT ACCEPT [187316:675198813]
:FORWARD ACCEPT [14424:2686725]
:POSTROUTING ACCEPT [195032:43368572]
COMMIT
*nat
:PREROUTING ACCEPT [9589:1101723]
:INPUT ACCEPT [435:108059]
:OUTPUT ACCEPT [12875:886050]
:POSTROUTING ACCEPT [13417:909427]
:DOCKER - [0:0]
-A POSTROUTING -s 10.5.0.0/16 ! -o br-59f076e4cabf -j MASQUERADE
-A POSTROUTING -s 10.5.0.2/32 -d 10.5.0.2/32 -p tcp -m tcp --dport 5053 -j MASQUERADE
-A POSTROUTING -s 10.5.0.2/32 -d 10.5.0.2/32 -p udp -m udp --dport 5053 -j MASQUERADE
-A POSTROUTING -s 10.5.0.4/32 -d 10.5.0.4/32 -p udp -m udp --dport 51820 -j MASQUERADE
-A POSTROUTING -s 10.5.0.3/32 -d 10.5.0.3/32 -p tcp -m tcp --dport 443 -j MASQUERADE
-A POSTROUTING -s 10.5.0.3/32 -d 10.5.0.3/32 -p tcp -m tcp --dport 80 -j MASQUERADE
-A POSTROUTING -s 10.5.0.3/32 -d 10.5.0.3/32 -p tcp -m tcp --dport 53 -j MASQUERADE
-A POSTROUTING -s 10.5.0.3/32 -d 10.5.0.3/32 -p udp -m udp --dport 53 -j MASQUERADE
-A DOCKER -i br-59f076e4cabf -j RETURN
-A DOCKER ! -i br-59f076e4cabf -p tcp -m tcp --dport 5053 -j DNAT --to-destination 10.5.0.2:5053
-A DOCKER ! -i br-59f076e4cabf -p udp -m udp --dport 5053 -j DNAT --to-destination 10.5.0.2:5053
-A DOCKER ! -i br-59f076e4cabf -p udp -m udp --dport 51820 -j DNAT --to-destination 10.5.0.4:51820
-A DOCKER ! -i br-59f076e4cabf -p tcp -m tcp --dport 4430 -j DNAT --to-destination 10.5.0.3:443
-A DOCKER ! -i br-59f076e4cabf -p tcp -m tcp --dport 8000 -j DNAT --to-destination 10.5.0.3:80
-A DOCKER ! -i br-59f076e4cabf -p tcp -m tcp --dport 5054 -j DNAT --to-destination 10.5.0.3:53
-A DOCKER ! -i br-59f076e4cabf -p udp -m udp --dport 5054 -j DNAT --to-destination 10.5.0.3:53
COMMIT
*filter
:INPUT ACCEPT [187287:675196231]
:FORWARD DROP [7588:383127]
:OUTPUT ACCEPT [185829:40755044]
:DOCKER - [0:0]
-A FORWARD -o br-59f076e4cabf -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -o br-59f076e4cabf -j DOCKER
-A FORWARD -i br-59f076e4cabf ! -o br-59f076e4cabf -j ACCEPT
-A FORWARD -i br-59f076e4cabf -o br-59f076e4cabf -j ACCEPT
-A DOCKER -d 10.5.0.2/32 ! -i br-59f076e4cabf -o br-59f076e4cabf -p tcp -m tcp --dport 5053 -j ACCEPT
-A DOCKER -d 10.5.0.2/32 ! -i br-59f076e4cabf -o br-59f076e4cabf -p udp -m udp --dport 5053 -j ACCEPT
-A DOCKER -d 10.5.0.4/32 ! -i br-59f076e4cabf -o br-59f076e4cabf -p udp -m udp --dport 51820 -j ACCEPT
-A DOCKER -d 10.5.0.3/32 ! -i br-59f076e4cabf -o br-59f076e4cabf -p tcp -m tcp --dport 443 -j ACCEPT
-A DOCKER -d 10.5.0.3/32 ! -i br-59f076e4cabf -o br-59f076e4cabf -p tcp -m tcp --dport 80 -j ACCEPT
-A DOCKER -d 10.5.0.3/32 ! -i br-59f076e4cabf -o br-59f076e4cabf -p tcp -m tcp --dport 53 -j ACCEPT
-A DOCKER -d 10.5.0.3/32 ! -i br-59f076e4cabf -o br-59f076e4cabf -p udp -m udp --dport 53 -j ACCEPT
-A DOCKER-ISOLATION-STAGE-1 -i br-59f076e4cabf ! -o br-59f076e4cabf -j DOCKER-ISOLATION-STAGE-2
-A DOCKER-ISOLATION-STAGE-2 -o br-59f076e4cabf -j DROP
COMMIT
I’m not very familiar with IP tables, so not much if I can comment on what’s going here.
It looks like something (docker perhaps) has refreshed the firewall rules and removed the ones LXD added.
Assuming your LXD bridge is lxdbr0 then you’re missing these lines:
before the line:
Great information.
Thanks much!
-steve
I really hate iptables so I use nftables wherever possible. However I found this gist.
Not happy with Docker modifying your precious firewall rules?
Prerequisites
Install Docker CE and nftables:
$ sudo apt-get install nftables
$ sudo systemctl --now enable nftables
Installing
Manually (create/modify daemon.json before starting docker.service):
$ sudo systemctl start docker
$ sudo systemctl stop docker containerd
$ sudo iptables-save > iptables-docker.conf
$ sudo iptables-restore-translate -f iptable-docker.conf > docker.nft
$ sudo nft flush ruleset
$ sudo nft -f docker.nft
$ sudo nft -s list ruleset > /etc/nftables-docker.conf
tl;dr
$ curl -fsSLO https://gist.github.com/goll/bdd6b43c2023f82d15729e9b0067de60/raw/nftables-docker.sh
$ sudo bash -x nftables-docker.sh
For a persistent config just overwrite /etc/nftables.conf with /etc/nftables-docker.conf
If you prefer manual start/stop you can create an alias for example:
alias dock-on='sudo nft -f /etc/nftables-docker.conf && sudo systemctl start docker'
alias dock-off='sudo systemctl stop docker containerd && sudo nft -f /etc/nftables.conf && sudo ip l d docker0'
Then they provide a way to prevent docker from changing firewall settings.
#!/bin/bash
tee /etc/docker/daemon.json << EOF
  "iptables": false
EOF
curl -fsSLO https://gist.github.com/goll/bdd6b43c2023f82d15729e9b0067de60/raw/nftables-docker.conf -o /etc/nftables-docker.conf && nft -f /etc/nftables-docker.conf
So I did this and combined it with the above rule that @tomp wrote giving a ruleset like this:
table ip nat {
	chain PREROUTING {
		type nat hook prerouting priority dstnat; policy accept;
		fib daddr type local counter jump DOCKER
	chain INPUT {
		type nat hook input priority 100; policy accept;
	chain OUTPUT {
		type nat hook output priority -100; policy accept;
		ip daddr != 127.0.0.0/8 fib daddr type local counter jump DOCKER
	chain POSTROUTING {
		type nat hook postrouting priority srcnat; policy accept;
		oifname != "docker0" ip saddr 172.17.0.0/16 counter masquerade
	chain DOCKER {
		iifname "docker0" counter return
table ip filter {
	chain INPUT {
		type filter hook input priority filter; policy accept;
	chain FORWARD {
		type filter hook forward priority filter; policy drop;
		oifname "lxdbr0" counter accept comment "generated for LXD network lxdbr0"
		iifname "lxdbr0" counter accept comment "generated for LXD network lxdbr0"
		counter jump DOCKER-USER
		counter jump DOCKER-ISOLATION-STAGE-1
		oifname "docker0" ct state established,related counter accept
		oifname "docker0" counter jump DOCKER
		iifname "docker0" oifname != "docker0" counter accept
		iifname "docker0" oifname "docker0" counter accept
	chain OUTPUT {
		type filter hook output priority filter; policy accept;
	chain DOCKER {
	chain DOCKER-ISOLATION-STAGE-1 {
		iifname "docker0" oifname != "docker0" counter jump DOCKER-ISOLATION-STAGE-2
		counter return
	chain DOCKER-ISOLATION-STAGE-2 {
		oifname "docker0" counter drop
		counter return
	chain DOCKER-USER {
		counter return
Note that the rules @tomp mentions:
are these in nftables syntax:
These rules must be above the JUMP rules in the FORWARD chain.
We now have a section in our docs covering this:
Note that the current solution in the docs does not work on Debian (bookworm). What worked is making it bi-directional. I documented it in the github issue.
Would you be able to open a pull request to update the docs? Thanks
Sure - would you prefer an additional debian-specific paragraph in the docs, leaving the existing instruction as is, or adding the reverse direction to the existing instruction?
When I had to run docker on a router some time ago I ended up putting the docker daemon into it’s own network namespace so it can’t mess anything up and you don’t have to disable iptables management for the docker daemon which might cause other issues.
With that you simply get a veth interface on the host that you can configure using your favorite firewall(e.g. plain nftables)
Here’s an arch Linux wiki entry about that: nftables - ArchWiki
Thanks – but note that the above doesn’t “disable iptables management for the docker daemon”.
Thanks! I’ve left a comment on the PR.
for anyone hitting this… docker looks for net.ipv4.ip_forward=1 and if that is set it doesn’t touch the default FORWARD policy… there is a detailled discussion about the issue here: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=865975
Thanks for this info.
LXD does enable that on bridge networks, but if Docker has started before LXD and that setting isn’t enabled at the system level then that could explain why Docker is not detecting it set at the time it starts and is modifying the FORWARD policy.
Can you please update your link ? It is redirecting to a letter by the Linux Containers team.
