LXD doesn't start snap.lxd.device: Directory nonexistent
Since Today, lxd doesn’t start on one of my server, there is the error I get from
journalctl -u snap.lxd.daemon -n 50
I have lxd installed with snapd
snap info lxd:
installed: 6.3-a85d6a5 (33246) 116MB -
snap --version:
snap 2.61.4
snapd 2.61.4
series 16
debian 11
kernel 5.10.0-34-amd64
Apr 23 19:00:25 runbot01 systemd[1]: Stopped Service for snap application lxd.daemon.
Apr 23 19:00:25 runbot01 systemd[1]: Started Service for snap application lxd.daemon.
Apr 23 19:00:25 runbot01 lxd.daemon[3086]: INFO: the gpu-2404 interface isn’t connected. Skipping gpu-2404 wrapper.
Apr 23 19:00:25 runbot01 lxd.daemon[3086]: => Preparing the system (33246)
Apr 23 19:00:25 runbot01 lxd.daemon[3135]: grep: /var/lib/snapd/hostfs/var/lib/snapd/cgroup/snap.lxd.device: No such file or directory
Apr 23 19:00:25 runbot01 lxd.daemon[3086]: /snap/lxd/33246/commands/daemon.start: 46: cannot create /var/lib/snapd/hostfs/var/lib/snapd/cgroup/snap.lxd.device: Directory nonexistent
Apr 23 19:00:25 runbot01 systemd[1]: snap.lxd.daemon.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Apr 23 19:00:25 runbot01 systemd[1]: snap.lxd.daemon.service: Failed with result ‘exit-code’.
Apr 23 19:00:25 runbot01 systemd[1]: snap.lxd.daemon.service: Scheduled restart job, restart counter is at 5.
Apr 23 19:00:25 runbot01 systemd[1]: snap.lxd.daemon.service: Start request repeated too quickly.
Apr 23 19:00:25 runbot01 systemd[1]: Failed to start Service for snap application lxd.daemon.
Can you help me to fix the error ?
Thanks
This topic was automatically closed 30 days after the last reply. New replies are no longer allowed.
