LXD has been moved to Canonical
Canonical has requested that the LXD project be moved from LinuxContainers to Canonical’s own infrastructure. This means that starting now, LXD related resources can be found at:
Website: Canonical LXD
Github: GitHub - canonical/lxd: Powerful system container and virtual machine manager
Forum: https://discourse.ubuntu.com/c/lxd/
Documentation: LXD
When it comes to this forum, the LXD section will be reconfigured to not allow new topics.
Existing topics will remain active and replies can be posted inside of them. New topics related to LXD posted to other sections of the forum will be redirected to the Ubuntu Discourse instead.
Linux Containers project statement
Source: Linux Containers - LXD - Has been moved to Canonical
Date: 4th of July 2023
Canonical, the creator and main contributor of the LXD project has decided that after over 8 years as part of the Linux Containers community, the project would now be better served directly under Canonical’s own set of projects.
While the team behind Linux Containers regrets that decision and will be missing LXD as one of its projects, it does respect Canonical’s decision and is now in the process of moving the project over.
Concretely, the expected changes are:
- GitHub - lxc/incus: Powerful system container and virtual machine manager will now become GitHub - canonical/lxd: Powerful system container and virtual machine manager
- Linux Containers - LXD - Has been moved to Canonical will disappear and be replaced with a mention directing users to https://ubuntu.com/lxd
- The LXD YouTube channel will be handed over to the Canonical team
- The LXD section on the LinuxContainers community forum will slowly be sunset in favor of the Ubuntu Discourse forum run by Canonical
- The LXD CI infrastructure will be moved under Canonical’s care
- Image building for Linux Containers will no longer be relying on systems provided by Canonical, limiting image building to
x86_64andaarch64.What will not be changing:
- The rest of the Linux Containers projects remain unaffected
- The image server, currently used by both LXC and LXD will keep operating as normal, though with less architectures available as mentioned above
Those changes will likely all happen pretty rapidly as everything is relatively tightly integrated together. As a result, you may notice a bit of bumpiness while Canonical sets up the replacement infrastructure.
Sincerely,
The Linux Containers team
Christian Brauner
Serge Hallyn
Stéphane Graber
