root@lxd:~# sudo snap info lxd and ps aux | grep lxd
store-url: https://snapcraft.io/lxd
contact: Issues · lxc/incus · GitHub
Supported configuration options for the snap (snap set lxd
[default=lxd]
- daemon.preseed: Pass a YAML configuration to lxd init on initial
/var/snap/lxd/common/global-conf/ (config.yml and servercerts)
summary: LXD - container and VM manager
publisher: Canonical✓
license: unset
description: |
LXD is a system container and virtual machine manager.
It offers a simple CLI and REST API to manage local or remote instances,
uses an image based workflow and support for a variety of advanced features.
Images are available for all Ubuntu releases and architectures as well
as for a wide number of other Linux distributions. Existing
integrations with many deployment and operation tools, makes it work
just like a public cloud, except everything is under your control.
LXD containers are lightweight, secure by default and a great
alternative to virtual machines when running Linux on Linux.
LXD virtual machines are modern and secure, using UEFI and secure-boot
by default and a great choice when a different kernel or operating
system is needed.
With clustering, up to 50 LXD servers can be easily joined and managed
together with the same tools and APIs and without needing any external
dependencies.
Supported configuration options for the snap (snap set lxd [=…]):
- ceph.builtin: Use snap-specific Ceph configuration [default=false]
- ceph.external: Use the system's ceph tools (ignores ceph.builtin) [default=false]
- criu.enable: Enable experimental live-migration support [default=false]
- daemon.debug: Increase logging to debug level [default=false]
- daemon.group: Set group of users that can interact with LXD [default=lxd]
- daemon.preseed: Pass a YAML configuration to `lxd init` on initial start
- daemon.syslog: Send LXD log events to syslog [default=false]
- lvm.external: Use the system's LVM tools [default=false]
- lxcfs.pidfd: Start per-container process tracking [default=false]
- lxcfs.loadavg: Start tracking per-container load average [default=false]
- lxcfs.cfs: Consider CPU shares for CPU usage [default=false]
- openvswitch.builtin: Run a snap-specific OVS daemon [default=false]
- shiftfs.enable: Enable shiftfs support [default=auto]
For system-wide configuration of the CLI, place your configuration in
commands:
root@lxd1:~# sudo journalctl -r -n 200 -b -g lxd
– Logs begin at Wed 2019-05-29 05:15:35 +06, end at Wed 2021-10-06 14:55:49 +06. –
Oct 06 14:55:49 lxd1 sudo[1808579]: root : TTY=pts/1 ; PWD=/root ; USER=root ; COMMAND=/bin/journalctl -r -n 200 -b -g lxd
Oct 06 14:55:48 lxd1 lxd.daemon[1808406]: => Starting LXD
Oct 06 14:55:48 lxd1 systemd[1]: Started Service for snap application lxd.daemon.
Oct 06 14:55:48 lxd1 systemd[1]: Stopped Service for snap application lxd.daemon.
Oct 06 14:55:48 lxd1 systemd[1]: snap.lxd.daemon.service: Scheduled restart job, restart counter is at 22930.
Oct 06 14:55:48 lxd1 systemd[1]: snap.lxd.daemon.service: Failed with result ‘exit-code’.
Oct 06 14:55:48 lxd1 systemd[1]: snap.lxd.daemon.service: Main process exited, code=exited, status=1/FAILURE
Oct 06 14:55:48 lxd1 lxd.daemon[1808064]: => LXD failed to start
Oct 06 14:55:46 lxd1 lxd.daemon[1808064]: => Starting LXD
Oct 06 14:55:45 lxd1 systemd[1]: Started Service for snap application lxd.daemon.
Oct 06 14:55:45 lxd1 systemd[1]: Stopped Service for snap application lxd.daemon.
Oct 06 14:55:45 lxd1 systemd[1]: snap.lxd.daemon.service: Scheduled restart job, restart counter is at 22929.
Oct 06 14:55:45 lxd1 systemd[1]: snap.lxd.daemon.service: Failed with result ‘exit-code’.
Oct 06 14:55:45 lxd1 systemd[1]: snap.lxd.daemon.service: Main process exited, code=exited, status=1/FAILURE
Oct 06 14:55:45 lxd1 lxd.daemon[1807763]: => LXD failed to start
Oct 06 14:55:43 lxd1 lxd.daemon[1807763]: => Starting LXD
Oct 06 14:55:42 lxd1 systemd[1]: Started Service for snap application lxd.daemon.
Oct 06 14:55:42 lxd1 systemd[1]: Stopped Service for snap application lxd.daemon.
Oct 06 14:55:42 lxd1 systemd[1]: snap.lxd.daemon.service: Scheduled restart job, restart counter is at 22928.
Oct 06 14:55:42 lxd1 systemd[1]: snap.lxd.daemon.service: Failed with result ‘exit-code’.
Oct 06 14:55:42 lxd1 systemd[1]: snap.lxd.daemon.service: Main process exited, code=exited, status=1/FAILURE
Oct 06 14:55:42 lxd1 lxd.daemon[1807552]: => LXD failed to start
Oct 06 14:55:40 lxd1 lxd.daemon[1807552]: => Starting LXD
Oct 06 14:55:39 lxd1 systemd[1]: Started Service for snap application lxd.daemon.
Oct 06 14:55:39 lxd1 systemd[1]: Stopped Service for snap application lxd.daemon.
Oct 06 14:55:39 lxd1 systemd[1]: snap.lxd.daemon.service: Scheduled restart job, restart counter is at 22927.
Oct 06 14:55:39 lxd1 systemd[1]: snap.lxd.daemon.service: Failed with result ‘exit-code’.
Oct 06 14:55:39 lxd1 systemd[1]: snap.lxd.daemon.service: Main process exited, code=exited, status=1/FAILURE
Oct 06 14:55:39 lxd1 lxd.daemon[1807235]: => LXD failed to start
Oct 06 14:55:37 lxd1 lxd.daemon[1807235]: => Starting LXD
Oct 06 14:55:36 lxd1 systemd[1]: Started Service for snap application lxd.daemon.
Oct 06 14:55:36 lxd1 systemd[1]: Stopped Service for snap application lxd.daemon.
Oct 06 14:55:36 lxd1 systemd[1]: snap.lxd.daemon.service: Scheduled restart job, restart counter is at 22926.
Oct 06 14:55:36 lxd1 systemd[1]: snap.lxd.daemon.service: Failed with result ‘exit-code’.
Oct 06 14:55:36 lxd1 systemd[1]: snap.lxd.daemon.service: Main process exited, code=exited, status=1/FAILURE
Oct 06 14:55:36 lxd1 lxd.daemon[1807031]: => LXD failed to start
Oct 06 14:55:34 lxd1 lxd.daemon[1807031]: => Starting LXD
Oct 06 14:55:33 lxd1 systemd[1]: Started Service for snap application lxd.daemon.
Oct 06 14:55:33 lxd1 systemd[1]: Stopped Service for snap application lxd.daemon.
Oct 06 14:55:33 lxd1 systemd[1]: snap.lxd.daemon.service: Scheduled restart job, restart counter is at 22925.
Oct 06 14:55:33 lxd1 systemd[1]: snap.lxd.daemon.service: Failed with result ‘exit-code’.
Oct 06 14:55:33 lxd1 systemd[1]: snap.lxd.daemon.service: Main process exited, code=exited, status=1/FAILURE
Oct 06 14:55:33 lxd1 lxd.daemon[1806660]: => LXD failed to start
Oct 06 14:55:31 lxd1 lxd.daemon[1806660]: => Starting LXD
Oct 06 14:55:30 lxd1 systemd[1]: Started Service for snap application lxd.daemon.
root@lxd1:~# sudo snap info lxd
store-url: Install lxd on Linux | Snap Store
contact: https://github.com/lxc/lxd/issues
license: unset
description: |
system is needed.
dependencies.
commands:
