I´m trying to migrate a Sangoma 7 distro to a container. Sangoma is a derivative of CentOS and is the default way of getting a FreePBX system up and running with commercial modules support.
After successfully running lxd-p2c, the vm was migrated but a lot of things were broken.
After wiping out /etc/fstab, the system appears to be working better, but I still have a few failed services.
[root@freepbx ~]# systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
dev-hugepages.mount loaded failed failed Huge Pages File System
sys-kernel-config.mount loaded failed failed Configuration File System
auditd.service loaded failed failed Security Auditing Service
chronyd.service loaded failed failed NTP client/server
kdump.service loaded failed failed Crash recovery kernel arming
lm_sensors.service loaded failed failed Initialize hardware monitoring sensors
plymouth-start.service loaded failed failed Show Plymouth Boot Screen
systemd-sysctl.service loaded failed failed Apply Kernel Variables
wpa_supplicant.service loaded failed failed WPA Supplicant daemon
lm_sensors and wpa_supplicant are not really necessary, but I don´t know about the others.
I´m trying to get the container to a state as near as possible to the working vm.
What would be the recommended way of sorting this out?
Thanks a lot.
