I was trying to install let’s encrypt on my unprivileged containers using the snap package, but it fails installer snap “core” package:
● snap-core-10583.mount - Mount unit for core Loaded: loaded (/etc/systemd/system/snap-core-10583.mount; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Wed 2021-01-13 08:42:15 CET; 1min 44s ago Where: /snap/core/10583 What: /var/lib/snapd/snaps/core_10583.snap Process: 6500 ExecMount=/bin/mount /var/lib/snapd/snaps/core_10583.snap /snap/core/10583 -t squashfs (code=exited, status=32) Jan 13 08:42:15 instance systemd[1]: snap-core-10583.mount: Failed to reset devices.list: Operation not permitted Jan 13 08:42:15 instance systemd[1]: snap-core-10583.mount: Failed to set invocation ID on control group /system.slice/snap-core-10583.mount, ignoring: Operation not permitted Jan 13 08:42:15 instance systemd[1]: Mounting Mount unit for core... Jan 13 08:42:15 instance systemd[1]: snap-core-10583.mount: Mount process exited, code=exited status=32 Jan 13 08:42:15 instance systemd[1]: Failed to mount Mount unit for core. Jan 13 08:42:15 instance systemd[1]: snap-core-10583.mount: Unit entered failed state.
I read that I need to install squashfuse, but this package is not available since the containers are under Debian 9, and this package is only available since Buster release.
Does it exist an alternative way to make it working ?
Thanks for you answers
