Note:
In recent kernels (>5.12) a new approach called “idmapped mounts” is directly included in the Linux kernel.
It acts as a replacement/sucessor of shiftfs and uses all the below mentioned commands as well.
It only supports ext4, xfs, vfat and btrfs (>5.15) for the underlying filesystems of LXD for now, but ZFS and cephfs are planned to be included as well.
If you use unsupported filesystems or older kernels, stick with shiftfs for now.
Usecases:
- General Advantages:
- faster startup of containers
- easier and less risky setup of uid/gid-shifting
sharing disk-devices:
If you want to share e.g. a folder between host & container or between containers. -
sharing volumes:
If you want to share volumes between isolated containers.
For instructions, see further below.
In case you want to use shiftfs, follow the below steps:
What is shiftfs?
See @stgraber’s post.
How to get shiftfs:
- For Ubuntu Users: It is already included in the standard Ubuntu Kernel.
- For other Distros: It is not included in the mainline kernel, but you can add it via dkms.
I created a github repo for this: https://github.com/toby63/shiftfs-dkms/
Instructions:
1. General use:
“Idmapped mounts” should be enabled by default, if a kernel that supports it is in use.
For the alternative with shiftfs, see @stgraber’s post on how to enable shiftfs in LXD.
2. Sharing disk-devices:
If you want to share a disk device (for example a folder) between host/container or between containers, so that both parties can have full access (rwx) to it.
You only need to add this key to your device-configuration in the container/profile-config:
shift: true
For example:
folder1:
path: /home/user1/folder1
source: /home/hostuser1/folder1
shift: true
Note:
This will match the hosts uid/gid (of the folder owner) with the container uid/gid.
So if the hosts uid is 1000, the user in the container also needs to have the uid 1000 to be able to access it.
See forum post by stgraber.
3. Sharing volumes:
If you want to share a volume between isolated containers.
First add this key to your volume-configuration:
security.shifted=true
Then attach the volume to both containers:
lxc storage volume attach POOL-NAME VOLUME-NAME container1 DEVICENAME /PATH
lxc storage volume attach POOL-NAME VOLUME-NAME container2 DEVICENAME /PATH
Recommendations:
If you don’t want LXD to remap (the UIDs/GIDs of) your container when shiftfs is not available (for example because of a failed dkms update), you can apply the following config key to your container (profile):
security.protection.shift: "true"
"Prevents the instance's filesystem from being uid/gid shifted on startup"
(See: Instances | LXD )Related error report: Container error after changing shiftfs (false/true)
Security Notes:
If you use shiftfs for disk devices it is possible for root or sudo users inside the container to setuid on a file that can be used by unpriviledged users on the host to get root access.
Details (comment 48): Trying out `shiftfs` - #48 by stgraber
How to prevent (comment 54): addnosuid,nodev
to the mount options, see: Trying out `shiftfs` - #54 by stgraber
Sources:
- Trying out `shiftfs`
- https://lxd.readthedocs.io/en/latest/storage/#storage-volume-configuration
- https://lxd.readthedocs.io/en/latest/instances/#type-disk
Tags:
share folder
share volume
:rw
