I am trying to mount a samba share on a debian 12 (6.1.0-16-amd64) host inside a Ubuntu 22.04 Container.
dpkg -l | grep lxd
ii lxd 5.0.2-5 amd64 Powerful system container and virtual machine manager - daemon
ii lxd-agent 5.0.2-5 amd64 LXD guest agent
ii lxd-client 5.0.2-5 amd64 Powerful system container and virtual machine manager - client
I am following the guides that worked on older versions.
But with id shifting on newer kernels I am a bit lost. When I try to add the mounted smb share, I get the following error.
lxc config device add name lxdshare disk shift=true source=/mnt/path/ path=/mnt/test
Error: Failed to start device "lxdshare": Required idmapping abilities not available
I can add the device without the shift parameter. But then I don’t have write permissions.
Do I have to disable id shifting completely to make it work?
Regards
