I am new to Incus and have a little experience with containers, but not much. I am attempting to get some OCI containers working in Incus. For whatever reason, when I attempt to launch the container, it fails immediately. I am using Void Linux on my host machine.
/etc/rc.conf
CGROUP_MODE=unified
I have also enabled the incus service and added my user to the _incus-admin group.
Here’s the Podman / Docker Compose equivalent of what I’m trying to run:
version: "1.0"
services:
arangodb:
image: docker.io/arangodb:3.11.8
environment:
ARANGO_ROOT_PASSWORD: "${ARANGO_ROOT_PASSWORD}"
ports:
- 9529:8529
volumes:
- ../repositories/d2/arango-data/arangodb3:/var/lib/arangodb3
- ../repositories/d2/arango-data/arangodb3-apps:/var/lib/arangodb3-apps
- ../repositories/d2/arango-data/dump:/dump:rw
# I will attempt to get static IP assignment working after I can get the container running normally
# networks:
# datacenter:
# ipv4_address: 10.134.200.223
networks:
datacenter:
driver: bridge
ipam:
driver: host-local
- subnet: 10.134.0.0/16
Here’s what I’ve run on the command line to get to this point:
#!/usr/bin/env bash
if [[ $BASH_SOURCE = */* ]]; then
scriptdir=${BASH_SOURCE%/*}/
else
scriptdir=./
fi
parentdir=$(dirname $(realpath $scriptdir))
### Root ###
# set up incus
incus admin init --preseed < incus-admin-init.yaml
# set up docker remove for pulling down containers
incus remote add docker https://docker.io --protocol=oci
# set up project
incus project create mini-d2-v1
incus project switch mini-d2-v1
# set up network
incus network create datacenter < network-datacenter.yaml
incus network attach-profile datacenter default
# set up storage
incus storage create pool-btrfs btrfs size=9GiB
### ArangoDB ###
# instance + environment variable setting
incus create docker:arangodb:3.11.8 arangodb \
--storage pool-btrfs
incus config set arangodb environment.ARANGO_ROOT_PASSWORD=$ARANGO_ROOT_PASSWORD
# storage
incus config device add arangodb arangodb3 disk \
source="$parentdir/repositories/d2/arango-data/arangodb3" \
path=/var/lib/arangodb3 \
shift=true
incus config device add arangodb arangodb3-apps disk \
source="$parentdir/repositories/d2/arango-data/arangodb3-apps" \
path=/var/lib/arangodb3-apps \
shift=true
incus config device add arangodb dump disk \
source="$parentdir/repositories/d2/arango-data/dump" \
path=/dump
# port proxy
incus config device add arangodb interface-proxy proxy \
connect="tcp:127.0.0.1:8529" \
listen="tcp:0.0.0.0:9529"
config: {}
networks:
- config:
ipv4.address: auto
ipv6.address: none
type: bridge
storage_pools:
- config:
source: /var/lib/incus/storage-pools/default
driver: dir
storage_volumes: []
- config: {}
incusbr0:
network: incusbr0
project: ""
type: bridge
ipv6.address: none
ipv4.address: 10.134.0.1/16
I then try to run incus start arangodb, and it fails almost immediately.
Here is the output of incus info --show-log arangodb :
derek@patu ~/s/s/mini-d2-v1-incus> incus info --show-log arangodb
Description:
Status: STOPPED
Type: container (application)
Created: 2025/09/18 18:23 PDT
Last Used: 2025/09/19 01:06 PDT
Log:
lxc mini-d2-v1_arangodb 20250919080636.444 INFO lxccontainer - ../src/lxc/lxccontainer.c:do_lxcapi_start:959 - Set process title to [lxc monitor] /var/lib/incus/containers mini-d2-v1_arangodb
lxc mini-d2-v1_arangodb 20250919080636.444 INFO start - ../src/lxc/start.c:lxc_check_inherited:326 - Closed inherited fd 4
lxc mini-d2-v1_arangodb 20250919080636.444 INFO start - ../src/lxc/start.c:lxc_check_inherited:326 - Closed inherited fd 5
lxc mini-d2-v1_arangodb 20250919080636.444 INFO start - ../src/lxc/start.c:lxc_check_inherited:326 - Closed inherited fd 14
lxc mini-d2-v1_arangodb 20250919080636.444 INFO lsm - ../src/lxc/lsm/lsm.c:lsm_init_static:38 - Initialized LSM security driver nop
lxc mini-d2-v1_arangodb 20250919080636.444 INFO utils - ../src/lxc/utils.c:run_script_argv:590 - Executing script "/proc/697/exe callhook /var/lib/incus "mini-d2-v1" "arangodb" start" for container "mini-d2-v1_arangodb"
lxc mini-d2-v1_arangodb 20250919080636.466 INFO cgfsng - ../src/lxc/cgroups/cgfsng.c:unpriv_systemd_create_scope:1498 - Running privileged, not using a systemd unit
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "[all]"
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "reject_force_umount # comment this to allow umount -f; not recommended"
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:532 - Set seccomp rule to reject force umounts
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "kexec_load errno 38"
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding native rule for syscall[246:kexec_load] action[327718:errno] arch[0]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[246:kexec_load] action[327718:errno] arch[1073741827]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[246:kexec_load] action[327718:errno] arch[1073741886]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "open_by_handle_at errno 38"
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding native rule for syscall[304:open_by_handle_at] action[327718:errno] arch[0]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[304:open_by_handle_at] action[327718:errno] arch[1073741827]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[304:open_by_handle_at] action[327718:errno] arch[1073741886]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "init_module errno 38"
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding native rule for syscall[175:init_module] action[327718:errno] arch[0]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[175:init_module] action[327718:errno] arch[1073741827]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[175:init_module] action[327718:errno] arch[1073741886]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "finit_module errno 38"
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding native rule for syscall[313:finit_module] action[327718:errno] arch[0]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[313:finit_module] action[327718:errno] arch[1073741827]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[313:finit_module] action[327718:errno] arch[1073741886]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "delete_module errno 38"
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding native rule for syscall[176:delete_module] action[327718:errno] arch[0]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[176:delete_module] action[327718:errno] arch[1073741827]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[176:delete_module] action[327718:errno] arch[1073741886]
lxc mini-d2-v1_arangodb 20250919080636.466 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:1036 - Merging compat seccomp contexts into main context
lxc mini-d2-v1_arangodb 20250919080636.466 INFO start - ../src/lxc/start.c:lxc_init:882 - Container "mini-d2-v1_arangodb" is initialized
lxc mini-d2-v1_arangodb 20250919080636.466 INFO cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_create:1669 - The monitor process uses "lxc.monitor.mini-d2-v1_arangodb" as cgroup
lxc mini-d2-v1_arangodb 20250919080636.477 INFO cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_payload_create:1777 - The container process uses "lxc.payload.mini-d2-v1_arangodb" as inner and "lxc.payload.mini-d2-v1_arangodb" as limit cgroup
lxc mini-d2-v1_arangodb 20250919080636.486 INFO start - ../src/lxc/start.c:lxc_spawn:1769 - Cloned CLONE_NEWUSER
lxc mini-d2-v1_arangodb 20250919080636.486 INFO start - ../src/lxc/start.c:lxc_spawn:1769 - Cloned CLONE_NEWNS
lxc mini-d2-v1_arangodb 20250919080636.486 INFO start - ../src/lxc/start.c:lxc_spawn:1769 - Cloned CLONE_NEWPID
lxc mini-d2-v1_arangodb 20250919080636.486 INFO start - ../src/lxc/start.c:lxc_spawn:1769 - Cloned CLONE_NEWUTS
lxc mini-d2-v1_arangodb 20250919080636.486 INFO start - ../src/lxc/start.c:lxc_spawn:1769 - Cloned CLONE_NEWIPC
lxc mini-d2-v1_arangodb 20250919080636.486 INFO start - ../src/lxc/start.c:lxc_spawn:1769 - Cloned CLONE_NEWCGROUP
lxc mini-d2-v1_arangodb 20250919080636.495 INFO idmap_utils - ../src/lxc/idmap_utils.c:lxc_map_ids:176 - Caller maps host root. Writing mapping directly
lxc mini-d2-v1_arangodb 20250919080636.495 NOTICE utils - ../src/lxc/utils.c:lxc_drop_groups:1477 - Dropped supplimentary groups
lxc mini-d2-v1_arangodb 20250919080636.497 INFO start - ../src/lxc/start.c:do_start:1105 - Unshared CLONE_NEWNET
lxc mini-d2-v1_arangodb 20250919080636.497 NOTICE utils - ../src/lxc/utils.c:lxc_drop_groups:1477 - Dropped supplimentary groups
lxc mini-d2-v1_arangodb 20250919080636.497 NOTICE utils - ../src/lxc/utils.c:lxc_switch_uid_gid:1453 - Switched to gid 0
lxc mini-d2-v1_arangodb 20250919080636.497 NOTICE utils - ../src/lxc/utils.c:lxc_switch_uid_gid:1462 - Switched to uid 0
lxc mini-d2-v1_arangodb 20250919080636.511 INFO conf - ../src/lxc/conf.c:setup_utsname:683 - Set hostname to "arangodb"
lxc mini-d2-v1_arangodb 20250919080636.512 INFO network - ../src/lxc/network.c:lxc_setup_network_in_child_namespaces:4064 - Finished setting up network devices with caller assigned names
lxc mini-d2-v1_arangodb 20250919080636.512 INFO conf - ../src/lxc/conf.c:mount_autodev:1027 - Preparing "/dev"
lxc mini-d2-v1_arangodb 20250919080636.512 INFO conf - ../src/lxc/conf.c:mount_autodev:1088 - Prepared "/dev"
lxc mini-d2-v1_arangodb 20250919080636.529 INFO conf - ../src/lxc/conf.c:lxc_fill_autodev:1125 - Populating "/dev"
lxc mini-d2-v1_arangodb 20250919080636.529 INFO conf - ../src/lxc/conf.c:lxc_fill_autodev:1213 - Populated "/dev"
lxc mini-d2-v1_arangodb 20250919080636.529 INFO conf - ../src/lxc/conf.c:lxc_transient_proc:3311 - Caller's PID is 1; /proc/self points to 1
lxc mini-d2-v1_arangodb 20250919080636.529 INFO conf - ../src/lxc/conf.c:setup_personality:1724 - Set personality to "0lx0"
lxc mini-d2-v1_arangodb 20250919080636.529 NOTICE conf - ../src/lxc/conf.c:lxc_setup:4018 - The container "mini-d2-v1_arangodb" is set up
lxc mini-d2-v1_arangodb 20250919080636.530 INFO utils - ../src/lxc/utils.c:run_script_argv:590 - Executing script "/proc/697/exe forknet dhcp /var/lib/incus/containers/mini-d2-v1_arangodb/network /var/log/incus/mini-d2-v1_arangodb/forknet-dhcp.log" for container "mini-d2-v1_arangodb"
lxc mini-d2-v1_arangodb 20250919080636.543 NOTICE execute - ../src/lxc/execute.c:execute_post_start:34 - '/entrypoint.sh' started with pid '3662'
lxc mini-d2-v1_arangodb 20250919080636.543 NOTICE start - ../src/lxc/start.c:signal_handler:447 - Received 17 from pid 3663 instead of container init 3662
lxc mini-d2-v1_arangodb 20250919080636.559 INFO error - ../src/lxc/error.c:lxc_error_set_and_log:31 - Child <3662> ended on error (1)
lxc mini-d2-v1_arangodb 20250919080636.560 INFO utils - ../src/lxc/utils.c:run_script_argv:590 - Executing script "/usr/libexec/incus/incusd callhook /var/lib/incus "mini-d2-v1" "arangodb" stopns" for container "mini-d2-v1_arangodb"
lxc mini-d2-v1_arangodb 20250919080636.609 INFO utils - ../src/lxc/utils.c:run_script_argv:590 - Executing script "/usr/libexec/incus/incusd callhook /var/lib/incus "mini-d2-v1" "arangodb" stop" for container "mini-d2-v1_arangodb"
I can’t really tell what I’m doing wrong here; is there a step I missed somewhere? I am really new to this stuff. Thank you!
