I’m trying to launch Postgres as an OCI container and am facing the issue that the app container directly stops again. I attached the trace log below.
lxc postgres 20250821223428.578 TRACE commands - ../src/lxc/commands.c:lxc_cmd_timeout:525 - Connection refused - Command "get_state" failed to connect command socket
lxc postgres 20250821223428.578 TRACE start - ../src/lxc/start.c:lxc_init_handler:739 - Created anonymous pair {3,6} of unix sockets
lxc postgres 20250821223428.578 TRACE commands - ../src/lxc/commands.c:lxc_server_init:2138 - Created abstract unix socket "/var/lib/incus/containers/postgres/command"
lxc postgres 20250821223428.579 TRACE start - ../src/lxc/start.c:lxc_init_handler:755 - Unix domain socket 8 for command server is ready
lxc postgres 20250821223428.590 INFO lxccontainer - ../src/lxc/lxccontainer.c:do_lxcapi_start:954 - Set process title to [lxc monitor] /var/lib/incus/containers postgres
lxc postgres 20250821223428.601 INFO start - ../src/lxc/start.c:lxc_check_inherited:326 - Closed inherited fd 4
lxc postgres 20250821223428.601 INFO start - ../src/lxc/start.c:lxc_check_inherited:326 - Closed inherited fd 5
lxc postgres 20250821223428.601 INFO start - ../src/lxc/start.c:lxc_check_inherited:326 - Closed inherited fd 11
lxc postgres 20250821223428.602 TRACE execute - ../src/lxc/execute.c:lxc_execute:49 - Doing lxc_execute
lxc postgres 20250821223428.603 INFO lsm - ../src/lxc/lsm/lsm.c:lsm_init_static:38 - Initialized LSM security driver AppArmor
lxc postgres 20250821223428.603 TRACE start - ../src/lxc/start.c:lxc_init:779 - Initialized LSM
lxc postgres 20250821223428.603 TRACE start - ../src/lxc/start.c:lxc_serve_state_clients:484 - Set container state to STARTING
lxc postgres 20250821223428.604 TRACE start - ../src/lxc/start.c:lxc_serve_state_clients:487 - No state clients registered
lxc postgres 20250821223428.604 TRACE start - ../src/lxc/start.c:lxc_init:785 - Set container state to "STARTING"
lxc postgres 20250821223428.604 TRACE start - ../src/lxc/start.c:lxc_init:841 - Set environment variables
lxc postgres 20250821223428.604 INFO utils - ../src/lxc/utils.c:run_script_argv:590 - Executing script "/proc/32403/exe callhook /var/lib/incus "default" "postgres" start" for container "postgres"
lxc postgres 20250821223428.604 TRACE utils - ../src/lxc/utils.c:run_script_argv:633 - Set environment variable: LXC_HOOK_TYPE=pre-start
lxc postgres 20250821223428.604 TRACE utils - ../src/lxc/utils.c:run_script_argv:638 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc postgres 20250821223428.606 DEBUG lxccontainer - ../src/lxc/lxccontainer.c:wait_on_daemonized_start:813 - First child 56805 exited
lxc postgres 20250821223428.958 TRACE start - ../src/lxc/start.c:lxc_init:846 - Ran pre-start hooks
lxc postgres 20250821223428.958 TRACE start - ../src/lxc/start.c:setup_signal_fd:371 - Created signal file descriptor 5
lxc postgres 20250821223428.958 TRACE start - ../src/lxc/start.c:lxc_init:859 - Set up signal fd
lxc postgres 20250821223428.958 INFO cgfsng - ../src/lxc/cgroups/cgfsng.c:unpriv_systemd_create_scope:1508 - Running privileged, not using a systemd unit
lxc postgres 20250821223428.959 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_hierarchy_add:462 - Adding cgroup hierarchy mounted at and base cgroup (null)
lxc postgres 20250821223428.959 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_hierarchy_add:465 - The hierarchy contains the cpuset controller
lxc postgres 20250821223428.959 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_hierarchy_add:465 - The hierarchy contains the cpu controller
lxc postgres 20250821223428.959 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_hierarchy_add:465 - The hierarchy contains the io controller
lxc postgres 20250821223428.959 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_hierarchy_add:465 - The hierarchy contains the memory controller
lxc postgres 20250821223428.959 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_hierarchy_add:465 - The hierarchy contains the hugetlb controller
lxc postgres 20250821223428.960 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_hierarchy_add:465 - The hierarchy contains the pids controller
lxc postgres 20250821223428.960 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_hierarchy_add:465 - The hierarchy contains the rdma controller
lxc postgres 20250821223428.960 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_hierarchy_add:465 - The hierarchy contains the misc controller
lxc postgres 20250821223428.961 TRACE cgroup2_devices - ../src/lxc/cgroups/cgroup2_devices.c:bpf_program_load_kernel:335 - Loaded bpf program: func#0 @0
0: R1=ctx() R10=fp0
0: (61) r2 = *(u32 *)(r1 +0) ; R1=ctx() R2_w=scalar(smin=0,smax=umax=0xffffffff,var_off=(0x0; 0xffffffff))
1: (54) w2 &= 65535 ; R2_w=scalar(smin=smin32=0,smax=umax=smax32=umax32=0xffff,var_off=(0x0; 0xffff))
2: (61) r3 = *(u32 *)(r1 +0) ; R1=ctx() R3_w=scalar(smin=0,smax=umax=0xffffffff,var_off=(0x0; 0xffffffff))
3: (74) w3 >>= 16 ; R3_w=scalar(smin=smin32=0,smax=umax=smax32=umax32=0xffff,var_off=(0x0; 0xffff))
4: (61) r4 = *(u32 *)(r1 +4) ; R1=ctx() R4_w=scalar(smin=0,smax=umax=0xffffffff,var_off=(0x0; 0xffffffff))
5: (61) r5 = *(u32 *)(r1 +8) ; R1=ctx() R5_w=scalar(smin=0,smax=umax=0xffffffff,var_off=(0x0; 0xffffffff))
6: (b7) r0 = 1 ; R0_w=1
7: (95) exit
mark_precise: frame0: last_idx 7 first_idx 0 subseq_idx -1
mark_precise: frame0: regs=r0 stack= before 6: (b7) r0 = 1
processed 8 insns (limit 1000000) max_states_per_insn 0 total_states 0 peak_states 0 mark_read 0
lxc postgres 20250821223428.961 TRACE cgroup2_devices - ../src/lxc/cgroups/cgroup2_devices.c:bpf_devices_cgroup_supported:553 - The bpf device cgroup is supported
lxc postgres 20250821223428.961 TRACE cgroup - ../src/lxc/cgroups/cgroup.c:cgroup_init:41 - Initialized cgroup driver cgfsng
lxc postgres 20250821223428.961 TRACE cgroup - ../src/lxc/cgroups/cgroup.c:cgroup_init:48 - Unified cgroup layout
lxc postgres 20250821223428.962 TRACE start - ../src/lxc/start.c:lxc_init:866 - Initialized cgroup driver
lxc postgres 20250821223428.963 DEBUG seccomp - ../src/lxc/seccomp.c:parse_config_v2:664 - Host native arch is [3221225534]
lxc postgres 20250821223428.963 TRACE seccomp - ../src/lxc/seccomp.c:get_new_ctx:478 - Added arch 2 to main seccomp context
lxc postgres 20250821223428.963 TRACE seccomp - ../src/lxc/seccomp.c:get_new_ctx:486 - Removed native arch from main seccomp context
lxc postgres 20250821223428.963 TRACE seccomp - ../src/lxc/seccomp.c:get_new_ctx:478 - Added arch 3 to main seccomp context
lxc postgres 20250821223428.963 TRACE seccomp - ../src/lxc/seccomp.c:get_new_ctx:491 - Arch 4 already present in main seccomp context
lxc postgres 20250821223428.963 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "[all]"
lxc postgres 20250821223428.963 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "reject_force_umount # comment this to allow umount -f; not recommended"
lxc postgres 20250821223428.963 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:532 - Set seccomp rule to reject force umounts
lxc postgres 20250821223428.963 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "kexec_load errno 38"
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding native rule for syscall[246:kexec_load] action[327718:errno] arch[0]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[246:kexec_load] action[327718:errno] arch[1073741827]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[246:kexec_load] action[327718:errno] arch[1073741886]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "open_by_handle_at errno 38"
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding native rule for syscall[304:open_by_handle_at] action[327718:errno] arch[0]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[304:open_by_handle_at] action[327718:errno] arch[1073741827]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[304:open_by_handle_at] action[327718:errno] arch[1073741886]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "init_module errno 38"
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding native rule for syscall[175:init_module] action[327718:errno] arch[0]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[175:init_module] action[327718:errno] arch[1073741827]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[175:init_module] action[327718:errno] arch[1073741886]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "finit_module errno 38"
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding native rule for syscall[313:finit_module] action[327718:errno] arch[0]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[313:finit_module] action[327718:errno] arch[1073741827]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[313:finit_module] action[327718:errno] arch[1073741886]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:815 - Processing "delete_module errno 38"
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding native rule for syscall[176:delete_module] action[327718:errno] arch[0]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[176:delete_module] action[327718:errno] arch[1073741827]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:do_resolve_add_rule:572 - Adding compat rule for syscall[176:delete_module] action[327718:errno] arch[1073741886]
lxc postgres 20250821223428.964 INFO seccomp - ../src/lxc/seccomp.c:parse_config_v2:1036 - Merging compat seccomp contexts into main context
lxc postgres 20250821223428.964 TRACE seccomp - ../src/lxc/seccomp.c:parse_config_v2:1046 - Merged first compat seccomp context into main context
lxc postgres 20250821223428.964 TRACE seccomp - ../src/lxc/seccomp.c:parse_config_v2:1062 - Merged second compat seccomp context into main context
lxc postgres 20250821223428.964 TRACE start - ../src/lxc/start.c:lxc_init:873 - Read seccomp policy
lxc postgres 20250821223428.965 TRACE start - ../src/lxc/start.c:lxc_init:880 - Initialized LSM
lxc postgres 20250821223428.965 INFO start - ../src/lxc/start.c:lxc_init:882 - Container "postgres" is initialized
lxc postgres 20250821223428.965 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:726 - Reusing 10(lxc.monitor.postgres) cgroup
lxc postgres 20250821223428.965 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:741 - Opened cgroup lxc.monitor.postgres as 11
lxc postgres 20250821223428.965 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:747 - File exists - Creating the final cgroup 10(lxc.monitor.postgres) failed
lxc postgres 20250821223428.965 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:807 - File exists - Failed to create monitor cgroup 10(lxc.monitor.postgres)
lxc postgres 20250821223428.965 DEBUG cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_create:1665 - Failed to create cgroup lxc.monitor.postgres)
lxc postgres 20250821223428.965 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:726 - Reusing 10(lxc.monitor.postgres-1) cgroup
lxc postgres 20250821223428.965 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:741 - Opened cgroup lxc.monitor.postgres-1 as 11
lxc postgres 20250821223428.965 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:747 - File exists - Creating the final cgroup 10(lxc.monitor.postgres-1) failed
lxc postgres 20250821223428.965 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:807 - File exists - Failed to create monitor cgroup 10(lxc.monitor.postgres-1)
lxc postgres 20250821223428.965 DEBUG cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_create:1665 - Failed to create cgroup lxc.monitor.postgres-1)
lxc postgres 20250821223428.965 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:726 - Reusing 10(lxc.monitor.postgres-2) cgroup
lxc postgres 20250821223428.965 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:741 - Opened cgroup lxc.monitor.postgres-2 as 11
lxc postgres 20250821223428.965 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:747 - File exists - Creating the final cgroup 10(lxc.monitor.postgres-2) failed
lxc postgres 20250821223428.965 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:807 - File exists - Failed to create monitor cgroup 10(lxc.monitor.postgres-2)
lxc postgres 20250821223428.965 DEBUG cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_create:1665 - Failed to create cgroup lxc.monitor.postgres-2)
lxc postgres 20250821223428.965 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:726 - Reusing 10(lxc.monitor.postgres-3) cgroup
lxc postgres 20250821223428.966 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:741 - Opened cgroup lxc.monitor.postgres-3 as 11
lxc postgres 20250821223428.966 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:747 - File exists - Creating the final cgroup 10(lxc.monitor.postgres-3) failed
lxc postgres 20250821223428.966 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:807 - File exists - Failed to create monitor cgroup 10(lxc.monitor.postgres-3)
lxc postgres 20250821223428.966 DEBUG cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_create:1665 - Failed to create cgroup lxc.monitor.postgres-3)
lxc postgres 20250821223428.966 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:726 - Reusing 10(lxc.monitor.postgres-4) cgroup
lxc postgres 20250821223428.966 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:741 - Opened cgroup lxc.monitor.postgres-4 as 11
lxc postgres 20250821223428.966 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:747 - File exists - Creating the final cgroup 10(lxc.monitor.postgres-4) failed
lxc postgres 20250821223428.966 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:807 - File exists - Failed to create monitor cgroup 10(lxc.monitor.postgres-4)
lxc postgres 20250821223428.966 DEBUG cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_create:1665 - Failed to create cgroup lxc.monitor.postgres-4)
lxc postgres 20250821223428.966 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:726 - Reusing 10(lxc.monitor.postgres-5) cgroup
lxc postgres 20250821223428.966 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:741 - Opened cgroup lxc.monitor.postgres-5 as 11
lxc postgres 20250821223428.966 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:747 - File exists - Creating the final cgroup 10(lxc.monitor.postgres-5) failed
lxc postgres 20250821223428.966 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:807 - File exists - Failed to create monitor cgroup 10(lxc.monitor.postgres-5)
lxc postgres 20250821223428.966 DEBUG cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_create:1665 - Failed to create cgroup lxc.monitor.postgres-5)
lxc postgres 20250821223428.966 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:726 - Reusing 10(lxc.monitor.postgres-6) cgroup
lxc postgres 20250821223428.966 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:741 - Opened cgroup lxc.monitor.postgres-6 as 11
lxc postgres 20250821223428.966 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:747 - File exists - Creating the final cgroup 10(lxc.monitor.postgres-6) failed
lxc postgres 20250821223428.966 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:807 - File exists - Failed to create monitor cgroup 10(lxc.monitor.postgres-6)
lxc postgres 20250821223428.966 DEBUG cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_create:1665 - Failed to create cgroup lxc.monitor.postgres-6)
lxc postgres 20250821223428.966 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:726 - Reusing 10(lxc.monitor.postgres-7) cgroup
lxc postgres 20250821223428.966 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:741 - Opened cgroup lxc.monitor.postgres-7 as 11
lxc postgres 20250821223428.966 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:747 - File exists - Creating the final cgroup 10(lxc.monitor.postgres-7) failed
lxc postgres 20250821223428.966 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:807 - File exists - Failed to create monitor cgroup 10(lxc.monitor.postgres-7)
lxc postgres 20250821223428.966 DEBUG cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_create:1665 - Failed to create cgroup lxc.monitor.postgres-7)
lxc postgres 20250821223428.966 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:726 - Reusing 10(lxc.monitor.postgres-8) cgroup
lxc postgres 20250821223428.967 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:741 - Opened cgroup lxc.monitor.postgres-8 as 11
lxc postgres 20250821223428.967 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:747 - File exists - Creating the final cgroup 10(lxc.monitor.postgres-8) failed
lxc postgres 20250821223428.967 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:807 - File exists - Failed to create monitor cgroup 10(lxc.monitor.postgres-8)
lxc postgres 20250821223428.967 DEBUG cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_create:1665 - Failed to create cgroup lxc.monitor.postgres-8)
lxc postgres 20250821223428.968 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:726 - Created 10(lxc.monitor.postgres-9) cgroup
lxc postgres 20250821223428.968 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:741 - Opened newly created cgroup lxc.monitor.postgres-9 as 11
lxc postgres 20250821223428.968 INFO cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_create:1679 - The monitor process uses "lxc.monitor.postgres-9" as cgroup
lxc postgres 20250821223428.969 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgfsng_delegate_controllers:3630 - Enabled "+cpuset +cpu +io +memory +hugetlb +pids +rdma +misc" controllers in the unified cgroup 10
lxc postgres 20250821223428.143 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_enter:1829 - Moved monitor (56806) into cgroup 11
lxc postgres 20250821223428.143 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_enter:1843 - Moved transient process into cgroup 11
lxc postgres 20250821223428.143 DEBUG storage - ../src/lxc/storage/storage.c:get_storage_by_name:209 - Detected rootfs type "dir"
lxc postgres 20250821223428.143 TRACE conf - ../src/lxc/conf.c:lxc_rootfs_init:353 - Not pinning because container runs in user namespace
lxc postgres 20250821223428.143 TRACE sync - ../src/lxc/sync.c:lxc_sync_init:139 - Initialized synchronization infrastructure
lxc postgres 20250821223428.143 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:726 - Created 10(lxc.payload.postgres) cgroup
lxc postgres 20250821223428.143 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:741 - Opened newly created cgroup lxc.payload.postgres as 16
lxc postgres 20250821223428.143 INFO cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_payload_create:1787 - The container process uses "lxc.payload.postgres" as inner and "lxc.payload.postgres" as limit cgroup
lxc postgres 20250821223428.145 TRACE start - ../src/lxc/start.c:lxc_spawn:1714 - Spawned container directly into target cgroup via cgroup2 fd 16
lxc postgres 20250821223428.145 TRACE start - ../src/lxc/start.c:lxc_spawn:1754 - Cloned child process 56826
lxc postgres 20250821223428.145 TRACE start - ../src/lxc/start.c:core_scheduling:1572 - No new core scheduling domain requested
lxc postgres 20250821223428.145 TRACE utils - ../src/lxc/utils.c:lxc_can_use_pidfd:1935 - Kernel supports pidfds
lxc postgres 20250821223428.145 INFO start - ../src/lxc/start.c:lxc_spawn:1774 - Cloned CLONE_NEWUSER
lxc postgres 20250821223428.145 INFO start - ../src/lxc/start.c:lxc_spawn:1774 - Cloned CLONE_NEWNS
lxc postgres 20250821223428.145 INFO start - ../src/lxc/start.c:lxc_spawn:1774 - Cloned CLONE_NEWPID
lxc postgres 20250821223428.145 INFO start - ../src/lxc/start.c:lxc_spawn:1774 - Cloned CLONE_NEWUTS
lxc postgres 20250821223428.145 INFO start - ../src/lxc/start.c:lxc_spawn:1774 - Cloned CLONE_NEWIPC
lxc postgres 20250821223428.145 INFO start - ../src/lxc/start.c:lxc_spawn:1774 - Cloned CLONE_NEWCGROUP
lxc postgres 20250821223428.145 DEBUG start - ../src/lxc/start.c:lxc_try_preserve_namespace:140 - Preserved user namespace via fd 18 and stashed path as user:/proc/56806/fd/18
lxc postgres 20250821223428.145 DEBUG start - ../src/lxc/start.c:lxc_try_preserve_namespace:140 - Preserved mnt namespace via fd 19 and stashed path as mnt:/proc/56806/fd/19
lxc postgres 20250821223428.145 DEBUG start - ../src/lxc/start.c:lxc_try_preserve_namespace:140 - Preserved pid namespace via fd 20 and stashed path as pid:/proc/56806/fd/20
lxc postgres 20250821223428.145 DEBUG start - ../src/lxc/start.c:lxc_try_preserve_namespace:140 - Preserved uts namespace via fd 21 and stashed path as uts:/proc/56806/fd/21
lxc postgres 20250821223428.145 DEBUG start - ../src/lxc/start.c:lxc_try_preserve_namespace:140 - Preserved ipc namespace via fd 22 and stashed path as ipc:/proc/56806/fd/22
lxc postgres 20250821223428.145 DEBUG start - ../src/lxc/start.c:lxc_try_preserve_namespace:140 - Preserved cgroup namespace via fd 23 and stashed path as cgroup:/proc/56806/fd/23
lxc postgres 20250821223428.145 INFO idmap_utils - ../src/lxc/idmap_utils.c:lxc_map_ids:165 - newuidmap binary is missing
lxc postgres 20250821223428.145 INFO idmap_utils - ../src/lxc/idmap_utils.c:lxc_map_ids:171 - newgidmap binary is missing
lxc postgres 20250821223428.145 DEBUG idmap_utils - ../src/lxc/idmap_utils.c:lxc_map_ids:186 - No newuidmap and newgidmap binary found. Trying to write directly with euid 0
lxc postgres 20250821223428.145 TRACE idmap_utils - ../src/lxc/idmap_utils.c:lxc_map_ids:251 - Wrote mapping "0 1000000 1000000000
lxc postgres 20250821223428.145 TRACE sync - ../src/lxc/sync.c:lxc_sync_wait_parent:110 - Child waiting for parent with sequence startup
lxc postgres 20250821223428.145 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgfsng_delegate_controllers:3630 - Enabled "+cpuset +cpu +io +memory +hugetlb +pids +rdma +misc" controllers in the unified cgroup 10
lxc postgres 20250821223428.145 TRACE conf - ../src/lxc/conf.c:get_minimal_idmap:4469 - Allocated minimal idmapping for ns uid 0 and ns gid 0
lxc postgres 20250821223428.146 TRACE conf - ../src/lxc/conf.c:userns_exec_1:4533 - Establishing uid mapping for "56827" in new user namespace: nsuid 1000000000 - hostid 0 - range 1
lxc postgres 20250821223428.146 TRACE conf - ../src/lxc/conf.c:userns_exec_1:4533 - Establishing uid mapping for "56827" in new user namespace: nsuid 0 - hostid 1000000 - range 1000000000
lxc postgres 20250821223428.146 TRACE conf - ../src/lxc/conf.c:userns_exec_1:4533 - Establishing gid mapping for "56827" in new user namespace: nsuid 1000000000 - hostid 0 - range 1
lxc postgres 20250821223428.146 TRACE conf - ../src/lxc/conf.c:userns_exec_1:4533 - Establishing gid mapping for "56827" in new user namespace: nsuid 0 - hostid 1000000 - range 1000000000
lxc postgres 20250821223428.146 INFO idmap_utils - ../src/lxc/idmap_utils.c:lxc_map_ids:165 - newuidmap binary is missing
lxc postgres 20250821223428.146 INFO idmap_utils - ../src/lxc/idmap_utils.c:lxc_map_ids:171 - newgidmap binary is missing
lxc postgres 20250821223428.146 INFO idmap_utils - ../src/lxc/idmap_utils.c:lxc_map_ids:176 - Caller maps host root. Writing mapping directly
lxc postgres 20250821223428.146 TRACE idmap_utils - ../src/lxc/idmap_utils.c:lxc_map_ids:251 - Wrote mapping "1000000000 0 1
lxc postgres 20250821223428.146 TRACE conf - ../src/lxc/conf.c:run_userns_fn:4405 - Calling function "chown_cgroup_wrapper"
lxc postgres 20250821223428.146 NOTICE utils - ../src/lxc/utils.c:lxc_drop_groups:1481 - Dropped supplimentary groups
lxc postgres 20250821223428.146 TRACE sync - ../src/lxc/sync.c:lxc_sync_barrier_child:97 - Parent waking child with sequence startup and waiting with sequence configure
lxc postgres 20250821223428.147 INFO start - ../src/lxc/start.c:do_start:1105 - Unshared CLONE_NEWNET
lxc postgres 20250821223428.147 NOTICE utils - ../src/lxc/utils.c:lxc_drop_groups:1481 - Dropped supplimentary groups
lxc postgres 20250821223428.147 NOTICE utils - ../src/lxc/utils.c:lxc_switch_uid_gid:1457 - Switched to gid 0
lxc postgres 20250821223428.147 NOTICE utils - ../src/lxc/utils.c:lxc_switch_uid_gid:1466 - Switched to uid 0
lxc postgres 20250821223428.147 TRACE sync - ../src/lxc/sync.c:lxc_sync_wake_parent:104 - Child waking parent with sequence configure
lxc postgres 20250821223428.147 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: GOSU_VERSION=1.17
lxc postgres 20250821223428.147 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: PGDATA=/var/lib/postgresql/18/docker
lxc postgres 20250821223428.147 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/lib/postgresql/18/bin
lxc postgres 20250821223428.147 DEBUG start - ../src/lxc/start.c:lxc_try_preserve_namespace:140 - Preserved net namespace via fd 4 and stashed path as net:/proc/56806/fd/4
lxc postgres 20250821223428.147 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: PG_MAJOR=18
lxc postgres 20250821223428.147 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: LANG=en_US.utf8
lxc postgres 20250821223428.147 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: PG_VERSION=18~beta3-1.pgdg130+1
lxc postgres 20250821223428.147 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: TERM=xterm
lxc postgres 20250821223428.147 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: HOME=/root
lxc postgres 20250821223428.147 TRACE sync - ../src/lxc/sync.c:lxc_sync_wait_parent:110 - Child waiting for parent with sequence post-configure
lxc postgres 20250821223428.147 TRACE start - ../src/lxc/start.c:lxc_spawn:1846 - Allocated new network namespace id
lxc postgres 20250821223428.147 DEBUG network - ../src/lxc/network.c:netdev_configure_server_phys:1250 - Instantiated phys "veth4a1872fe" with ifindex "41"
lxc postgres 20250821223428.152 TRACE network - ../src/lxc/network.c:create_transient_name:3542 - Created transient name physoPQANl for network device
lxc postgres 20250821223428.196 DEBUG network - ../src/lxc/network.c:lxc_network_move_created_netdev_priv:3593 - Moved network device "veth4a1872fe" with ifindex 41 to network namespace of 56826 and renamed to physoPQANl
lxc postgres 20250821223428.196 TRACE sync - ../src/lxc/sync.c:lxc_sync_wake_child:122 - Parent waking child with sequence post-configure
lxc postgres 20250821223428.196 DEBUG storage - ../src/lxc/storage/storage.c:get_storage_by_name:209 - Detected rootfs type "dir"
lxc postgres 20250821223428.196 TRACE mount_utils - ../src/lxc/mount_utils.c:can_use_mount_api:582 - Kernel supports mount api
lxc postgres 20250821223428.196 TRACE mount_utils - ../src/lxc/mount_utils.c:can_use_bind_mounts:607 - Kernel supports bind mounts in the new mount api
lxc postgres 20250821223428.196 TRACE mount_utils - ../src/lxc/mount_utils.c:create_detached_idmapped_mount:286 - Idmapped mount "/var/lib/incus/storage-pools/incus/containers/postgres/rootfs" requested with user namespace fd 12
lxc postgres 20250821223428.196 TRACE conf - ../src/lxc/conf.c:lxc_rootfs_prepare_parent:450 - Created detached idmapped mount 24
lxc postgres 20250821223428.196 TRACE conf - ../src/lxc/conf.c:lxc_rootfs_prepare_child:3627 - Received detached idmapped mount 17
lxc postgres 20250821223428.196 TRACE network - ../src/lxc/network.c:lxc_network_send_to_child:4105 - Sent network device name "physoPQANl" to child
lxc postgres 20250821223428.196 TRACE sync - ../src/lxc/sync.c:lxc_sync_wait_child:116 - Parent waiting for child with sequence idmapped-mounts
lxc postgres 20250821223428.196 TRACE conf - ../src/lxc/conf.c:turn_into_dependent_mounts:3448 - Turned all mount table entries into dependent mount
lxc postgres 20250821223428.196 TRACE mount_utils - ../src/lxc/mount_utils.c:move_detached_mount:328 - Attach detached mount 17 to filesystem at 19
lxc postgres 20250821223428.196 TRACE dir - ../src/lxc/storage/dir.c:dir_mount:197 - Mounted "/var/lib/incus/storage-pools/incus/containers/postgres/rootfs" onto "/opt/incus/lib/lxc/rootfs"
lxc postgres 20250821223428.196 DEBUG conf - ../src/lxc/conf.c:lxc_mount_rootfs:1223 - Mounted rootfs "/var/lib/incus/storage-pools/incus/containers/postgres/rootfs" onto "/opt/incus/lib/lxc/rootfs" with options "idmap=container"
lxc postgres 20250821223428.196 TRACE conf - ../src/lxc/conf.c:lxc_mount_rootfs:1231 - Container uses separate rootfs. Opened container's rootfs
lxc postgres 20250821223428.196 INFO conf - ../src/lxc/conf.c:setup_utsname:671 - Set hostname to "postgres"
lxc postgres 20250821223428.196 TRACE network - ../src/lxc/network.c:lxc_network_recv_from_parent:4130 - Received network device name "physoPQANl" from parent
lxc postgres 20250821223428.196 TRACE network - ../src/lxc/network.c:__netdev_configure_container_common:1320 - Renamed network device from "physoPQANl" to "eth0"
lxc postgres 20250821223428.196 DEBUG network - ../src/lxc/network.c:setup_hw_addr:3866 - Mac address "10:66:6a:83:f0:49" on "eth0" has been setup
lxc postgres 20250821223428.197 DEBUG network - ../src/lxc/network.c:lxc_network_setup_in_child_namespaces_common:4007 - Network device "eth0" has been setup
lxc postgres 20250821223428.197 INFO network - ../src/lxc/network.c:lxc_setup_network_in_child_namespaces:4064 - Finished setting up network devices with caller assigned names
lxc postgres 20250821223428.197 INFO conf - ../src/lxc/conf.c:mount_autodev:1006 - Preparing "/dev"
lxc postgres 20250821223428.197 TRACE mount_utils - ../src/lxc/mount_utils.c:__fs_prepare:177 - Finished initializing new tmpfs filesystem context 20
lxc postgres 20250821223428.197 TRACE mount_utils - ../src/lxc/mount_utils.c:fs_set_property:215 - Set "mode" to "0755" on filesystem context 20
lxc postgres 20250821223428.197 TRACE mount_utils - ../src/lxc/mount_utils.c:fs_set_property:215 - Set "size" to "500000" on filesystem context 20
lxc postgres 20250821223428.197 TRACE mount_utils - ../src/lxc/mount_utils.c:fs_attach:266 - Mounted 22 onto 21
lxc postgres 20250821223428.197 INFO conf - ../src/lxc/conf.c:mount_autodev:1067 - Prepared "/dev"
lxc postgres 20250821223428.197 DEBUG conf - ../src/lxc/conf.c:lxc_mount_auto_mounts:531 - Invalid argument - Tried to ensure procfs is unmounted
lxc postgres 20250821223428.197 TRACE conf - ../src/lxc/conf.c:lxc_mount_auto_mounts:538 - Created procfs mountpoint under 19
lxc postgres 20250821223428.197 DEBUG conf - ../src/lxc/conf.c:lxc_mount_auto_mounts:554 - Invalid argument - Tried to ensure sysfs is unmounted
lxc postgres 20250821223428.197 TRACE conf - ../src/lxc/conf.c:lxc_mount_auto_mounts:561 - Created sysfs mountpoint under 19
lxc postgres 20250821223428.197 TRACE conf - ../src/lxc/conf.c:lxc_mount_auto_mounts:615 - Mounted automount "proc" on "/opt/incus/lib/lxc/rootfs/proc" read-write with flags 14
lxc postgres 20250821223428.197 TRACE conf - ../src/lxc/conf.c:lxc_mount_auto_mounts:615 - Mounted automount "sysfs" on "/opt/incus/lib/lxc/rootfs/sys" read-write with flags 0
lxc postgres 20250821223428.197 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/dev/fuse" on "/opt/incus/lib/lxc/rootfs/dev/fuse" to respect bind or remount options
lxc postgres 20250821223428.197 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/dev/fuse" were 4098, required extra flags are 2
lxc postgres 20250821223428.197 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/dev/fuse" on "/opt/incus/lib/lxc/rootfs/dev/fuse" with filesystem type "none"
lxc postgres 20250821223428.197 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/dev/net/tun" on "/opt/incus/lib/lxc/rootfs/dev/net/tun" to respect bind or remount options
lxc postgres 20250821223428.197 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/dev/net/tun" were 4098, required extra flags are 2
lxc postgres 20250821223428.197 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/dev/net/tun" on "/opt/incus/lib/lxc/rootfs/dev/net/tun" with filesystem type "none"
lxc postgres 20250821223428.197 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/sys/firmware/efi/efivars" on "/opt/incus/lib/lxc/rootfs/sys/firmware/efi/efivars" to respect bind or remount options
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/sys/firmware/efi/efivars" were 4110, required extra flags are 14
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/sys/firmware/efi/efivars" on "/opt/incus/lib/lxc/rootfs/sys/firmware/efi/efivars" with filesystem type "none"
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/sys/fs/fuse/connections" on "/opt/incus/lib/lxc/rootfs/sys/fs/fuse/connections" to respect bind or remount options
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/sys/fs/fuse/connections" were 4110, required extra flags are 14
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/sys/fs/fuse/connections" on "/opt/incus/lib/lxc/rootfs/sys/fs/fuse/connections" with filesystem type "none"
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/sys/fs/pstore" on "/opt/incus/lib/lxc/rootfs/sys/fs/pstore" to respect bind or remount options
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/sys/fs/pstore" were 4110, required extra flags are 14
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/sys/fs/pstore" on "/opt/incus/lib/lxc/rootfs/sys/fs/pstore" with filesystem type "none"
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/sys/kernel/config" on "/opt/incus/lib/lxc/rootfs/sys/kernel/config" to respect bind or remount options
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/sys/kernel/config" were 4110, required extra flags are 14
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/sys/kernel/config" on "/opt/incus/lib/lxc/rootfs/sys/kernel/config" with filesystem type "none"
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/sys/kernel/debug" on "/opt/incus/lib/lxc/rootfs/sys/kernel/debug" to respect bind or remount options
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/sys/kernel/debug" were 4110, required extra flags are 14
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/sys/kernel/debug" on "/opt/incus/lib/lxc/rootfs/sys/kernel/debug" with filesystem type "none"
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/sys/kernel/security" on "/opt/incus/lib/lxc/rootfs/sys/kernel/security" to respect bind or remount options
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/sys/kernel/security" were 4110, required extra flags are 14
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/sys/kernel/security" on "/opt/incus/lib/lxc/rootfs/sys/kernel/security" with filesystem type "none"
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/sys/kernel/tracing" on "/opt/incus/lib/lxc/rootfs/sys/kernel/tracing" to respect bind or remount options
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/sys/kernel/tracing" were 4110, required extra flags are 14
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/sys/kernel/tracing" on "/opt/incus/lib/lxc/rootfs/sys/kernel/tracing" with filesystem type "none"
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/dev/zfs" on "/opt/incus/lib/lxc/rootfs/dev/zfs" to respect bind or remount options
lxc postgres 20250821223428.198 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/dev/zfs" were 4098, required extra flags are 2
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/dev/zfs" on "/opt/incus/lib/lxc/rootfs/dev/zfs" with filesystem type "none"
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/dev/mqueue" on "/opt/incus/lib/lxc/rootfs/dev/mqueue" to respect bind or remount options
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/dev/mqueue" were 4110, required extra flags are 14
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/dev/mqueue" on "/opt/incus/lib/lxc/rootfs/dev/mqueue" with filesystem type "none"
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/var/lib/incus/guestapi" on "/opt/incus/lib/lxc/rootfs/dev/incus" to respect bind or remount options
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/var/lib/incus/guestapi" were 4096, required extra flags are 0
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2236 - Mountflags already were 4096, skipping remount
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/var/lib/incus/guestapi" on "/opt/incus/lib/lxc/rootfs/dev/incus" with filesystem type "none"
lxc postgres 20250821223428.199 TRACE conf - ../src/lxc/conf.c:parse_vfs_attr:2078 - Raising nosuid
lxc postgres 20250821223428.199 TRACE conf - ../src/lxc/conf.c:parse_vfs_attr:2078 - Raising noexec
lxc postgres 20250821223428.199 TRACE conf - ../src/lxc/conf.c:parse_vfs_attr:2078 - Raising nodev
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "shm" on "/opt/incus/lib/lxc/rootfs/dev/shm" with filesystem type "tmpfs"
lxc postgres 20250821223428.199 TRACE conf - ../src/lxc/conf.c:parse_vfs_attr:2074 - Lowering rw
lxc postgres 20250821223428.199 TRACE conf - ../src/lxc/conf.c:parse_vfs_attr:2078 - Raising relatime
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "none" on "/opt/incus/lib/lxc/rootfs/var/lib/postgresql" with filesystem type "tmpfs"
lxc postgres 20250821223428.199 ERROR utils - ../src/lxc/utils.c:safe_mount:1334 - Invalid argument - Failed to mount "none" onto "/opt/incus/lib/lxc/rootfs/run"
lxc postgres 20250821223428.199 INFO conf - ../src/lxc/conf.c:mount_entry:2199 - Invalid argument - Failed to mount "none" on "/opt/incus/lib/lxc/rootfs/run" (optional)
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/var/lib/incus/containers/postgres/network/hosts" on "/opt/incus/lib/lxc/rootfs/etc/hosts" to respect bind or remount options
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/var/lib/incus/containers/postgres/network/hosts" were 1024, required extra flags are 0
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/var/lib/incus/containers/postgres/network/hosts" on "/opt/incus/lib/lxc/rootfs/etc/hosts" with filesystem type "none"
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/var/lib/incus/containers/postgres/network/hostname" on "/opt/incus/lib/lxc/rootfs/etc/hostname" to respect bind or remount options
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/var/lib/incus/containers/postgres/network/hostname" were 1024, required extra flags are 0
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/var/lib/incus/containers/postgres/network/hostname" on "/opt/incus/lib/lxc/rootfs/etc/hostname" with filesystem type "none"
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/var/lib/incus/containers/postgres/network/resolv.conf" on "/opt/incus/lib/lxc/rootfs/etc/resolv.conf" to respect bind or remount options
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/var/lib/incus/containers/postgres/network/resolv.conf" were 1024, required extra flags are 0
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/var/lib/incus/containers/postgres/network/resolv.conf" on "/opt/incus/lib/lxc/rootfs/etc/resolv.conf" with filesystem type "none"
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2208 - Remounting "/var/lib/incus/shmounts/postgres" on "/opt/incus/lib/lxc/rootfs/dev/.incus-mounts" to respect bind or remount options
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2227 - Flags for "/var/lib/incus/shmounts/postgres" were 4096, required extra flags are 0
lxc postgres 20250821223428.199 DEBUG conf - ../src/lxc/conf.c:mount_entry:2271 - Mounted "/var/lib/incus/shmounts/postgres" on "/opt/incus/lib/lxc/rootfs/dev/.incus-mounts" with filesystem type "none"
lxc postgres 20250821223428.199 TRACE sync - ../src/lxc/sync.c:lxc_sync_wake_parent:104 - Child waking parent with sequence idmapped-mounts
lxc postgres 20250821223428.200 TRACE conf - ../src/lxc/conf.c:parse_vfs_attr:2078 - Raising nosuid
lxc postgres 20250821223428.200 TRACE conf - ../src/lxc/conf.c:parse_vfs_attr:2078 - Raising noexec
lxc postgres 20250821223428.200 TRACE conf - ../src/lxc/conf.c:parse_vfs_attr:2078 - Raising nodev
lxc postgres 20250821223428.200 TRACE conf - ../src/lxc/conf.c:parse_vfs_attr:2074 - Lowering rw
lxc postgres 20250821223428.200 TRACE conf - ../src/lxc/conf.c:parse_vfs_attr:2078 - Raising relatime
lxc postgres 20250821223428.200 TRACE conf - ../src/lxc/conf.c:lxc_idmapped_mounts_child:2892 - Finished setting up idmapped mounts
lxc postgres 20250821223428.200 TRACE conf - ../src/lxc/conf.c:lxc_idmapped_mounts_parent:3648 - Finished receiving idmapped mount file descriptors (-9 | -9) from child
lxc postgres 20250821223428.200 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_mount:2264 - Read-write cgroup mounts requested
lxc postgres 20250821223428.200 TRACE sync - ../src/lxc/sync.c:lxc_sync_wait_child:116 - Parent waiting for child with sequence cgroup-limits
lxc postgres 20250821223428.200 TRACE mount_utils - ../src/lxc/mount_utils.c:__fs_prepare:177 - Finished initializing new cgroup2 filesystem context 22
lxc postgres 20250821223428.200 TRACE mount_utils - ../src/lxc/mount_utils.c:fs_attach:266 - Mounted 23 onto 21
lxc postgres 20250821223428.200 DEBUG cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroupfs_mount:2197 - Mounted cgroup filesystem cgroup2 onto 21((null))
lxc postgres 20250821223428.200 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_mount:2365 - Force mounted cgroup filesystem in new cgroup namespace
lxc postgres 20250821223428.200 INFO utils - ../src/lxc/utils.c:run_script_argv:590 - Executing script "/opt/incus/share/lxcfs/lxc.mount.hook" for container "postgres"
lxc postgres 20250821223428.200 TRACE utils - ../src/lxc/utils.c:run_script_argv:633 - Set environment variable: LXC_HOOK_TYPE=mount
lxc postgres 20250821223428.200 TRACE utils - ../src/lxc/utils.c:run_script_argv:638 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc postgres 20250821223428.233 INFO conf - ../src/lxc/conf.c:lxc_fill_autodev:1104 - Populating "/dev"
lxc postgres 20250821223428.233 TRACE mount_utils - ../src/lxc/mount_utils.c:move_detached_mount:328 - Attach detached mount 22 to filesystem at 23
lxc postgres 20250821223428.233 DEBUG conf - ../src/lxc/conf.c:lxc_fill_autodev:1188 - Bind mounted host device 18(dev/full) to 20(full)
lxc postgres 20250821223428.233 DEBUG conf - ../src/lxc/conf.c:lxc_fill_autodev:1188 - Bind mounted host device 18(dev/null) to 20(null)
lxc postgres 20250821223428.233 DEBUG conf - ../src/lxc/conf.c:lxc_fill_autodev:1188 - Bind mounted host device 18(dev/random) to 20(random)
lxc postgres 20250821223428.233 DEBUG conf - ../src/lxc/conf.c:lxc_fill_autodev:1188 - Bind mounted host device 18(dev/tty) to 20(tty)
lxc postgres 20250821223428.233 DEBUG conf - ../src/lxc/conf.c:lxc_fill_autodev:1188 - Bind mounted host device 18(dev/urandom) to 20(urandom)
lxc postgres 20250821223428.233 DEBUG conf - ../src/lxc/conf.c:lxc_fill_autodev:1188 - Bind mounted host device 18(dev/zero) to 20(zero)
lxc postgres 20250821223428.233 INFO conf - ../src/lxc/conf.c:lxc_fill_autodev:1192 - Populated "/dev"
lxc postgres 20250821223428.233 INFO conf - ../src/lxc/conf.c:lxc_transient_proc:3300 - Caller's PID is 1; /proc/self points to 1
lxc postgres 20250821223428.233 TRACE conf - ../src/lxc/conf.c:lxc_transient_proc:3308 - Correct procfs instance mounted
lxc postgres 20250821223428.233 TRACE mount_utils - ../src/lxc/mount_utils.c:__fs_prepare:177 - Finished initializing new devpts filesystem context 21
lxc postgres 20250821223428.233 TRACE mount_utils - ../src/lxc/mount_utils.c:fs_set_property:215 - Set "source" to "devpts" on filesystem context 21
lxc postgres 20250821223428.233 TRACE mount_utils - ../src/lxc/mount_utils.c:fs_set_property:215 - Set "gid" to "5" on filesystem context 21
lxc postgres 20250821223428.233 TRACE mount_utils - ../src/lxc/mount_utils.c:fs_set_flag:227 - Set "newinstance" flag on filesystem context 21
lxc postgres 20250821223428.233 TRACE mount_utils - ../src/lxc/mount_utils.c:fs_set_property:215 - Set "ptmxmode" to "0666" on filesystem context 21
lxc postgres 20250821223428.233 TRACE mount_utils - ../src/lxc/mount_utils.c:fs_set_property:215 - Set "mode" to "0620" on filesystem context 21
lxc postgres 20250821223428.233 TRACE mount_utils - ../src/lxc/mount_utils.c:fs_set_property:215 - Set "max" to "1024" on filesystem context 21
lxc postgres 20250821223428.233 TRACE conf - ../src/lxc/conf.c:lxc_setup_devpts_child:1531 - Created detached devpts mount 22
lxc postgres 20250821223428.233 DEBUG conf - ../src/lxc/conf.c:lxc_setup_devpts_child:1537 - Attached detached devpts mount 22 to 20/pts
lxc postgres 20250821223428.233 DEBUG conf - ../src/lxc/conf.c:lxc_setup_devpts_child:1623 - Created "/dev/ptmx" file as bind mount target
lxc postgres 20250821223428.233 TRACE mount_utils - ../src/lxc/mount_utils.c:mount_at:663 - Mounted "/proc/self/fd/23" to "/proc/self/fd/24"
lxc postgres 20250821223428.233 DEBUG conf - ../src/lxc/conf.c:lxc_setup_devpts_child:1630 - Bind mounted "/dev/pts/ptmx" to "/dev/ptmx"
lxc postgres 20250821223428.234 TRACE mount_utils - ../src/lxc/mount_utils.c:move_detached_mount:328 - Attach detached mount 26 to filesystem at 24
lxc postgres 20250821223428.234 TRACE conf - ../src/lxc/conf.c:lxc_setup_dev_console:1789 - Setup console "/dev/pts/0"
lxc postgres 20250821223428.234 TRACE conf - ../src/lxc/conf.c:lxc_pivot_root:1438 - Changed into new rootfs "/opt/incus/lib/lxc/rootfs"
lxc postgres 20250821223428.234 INFO conf - ../src/lxc/conf.c:setup_personality:1703 - Set personality to "0lx0"
lxc postgres 20250821223428.234 TRACE conf - ../src/lxc/conf.c:setup_sysctl_parameters:3118 - Setting /proc/sys/net/ipv4/ping_group_range to 0 999999999
lxc postgres 20250821223428.234 TRACE conf - ../src/lxc/conf.c:setup_sysctl_parameters:3118 - Setting /proc/sys/net/ipv4/ip_unprivileged_port_start to 0
lxc postgres 20250821223428.234 TRACE conf - ../src/lxc/conf.c:setup_sysctl_parameters:3121 - Setup /proc/sys settings
lxc postgres 20250821223428.234 DEBUG conf - ../src/lxc/conf.c:capabilities_deny:2999 - Capabilities have been setup
lxc postgres 20250821223428.234 NOTICE conf - ../src/lxc/conf.c:lxc_setup:4007 - The container "postgres" is set up
lxc postgres 20250821223428.235 TRACE apparmor - ../src/lxc/lsm/apparmor.c:__apparmor_process_label_open:393 - On-exec not supported with AppArmor
lxc postgres 20250821223428.235 TRACE apparmor - ../src/lxc/lsm/apparmor.c:apparmor_process_label_set_at:1162 - Changing AppArmor profile on exec not supported
lxc postgres 20250821223428.235 INFO apparmor - ../src/lxc/lsm/apparmor.c:apparmor_process_label_set_at:1178 - Set AppArmor label to "incus-postgres_</var/lib/incus>//&:incus-postgres_<var-lib-incus>:"
lxc postgres 20250821223428.235 INFO apparmor - ../src/lxc/lsm/apparmor.c:apparmor_process_label_set:1223 - Changed AppArmor profile to incus-postgres_</var/lib/incus>//&:incus-postgres_<var-lib-incus>:
# pseudo filter code start
# filter for arch x86_64 (3221225534)
if ($arch == 3221225534)
# filter for syscall "finit_module" (313) [priority: 65535]
if ($syscall == 313)
action ERRNO(38);
# filter for syscall "open_by_handle_at" (304) [priority: 65535]
if ($syscall == 304)
action ERRNO(38);
# filter for syscall "kexec_load" (246) [priority: 65535]
if ($syscall == 246)
action ERRNO(38);
# filter for syscall "delete_module" (176) [priority: 65535]
if ($syscall == 176)
action ERRNO(38);
# filter for syscall "init_module" (175) [priority: 65535]
if ($syscall == 175)
action ERRNO(38);
# filter for syscall "umount2" (166) [priority: 65533]
if ($syscall == 166)
if ($a1.hi32 & 0x00000000 == 0)
if ($a1.lo32 & 0x00000001 == 1)
action ERRNO(13);
# default action
action ALLOW;
# filter for arch x86 (1073741827)
if ($arch == 1073741827)
# filter for syscall "finit_module" (350) [priority: 65535]
if ($syscall == 350)
action ERRNO(38);
# filter for syscall "open_by_handle_at" (342) [priority: 65535]
if ($syscall == 342)
action ERRNO(38);
# filter for syscall "kexec_load" (283) [priority: 65535]
if ($syscall == 283)
action ERRNO(38);
# filter for syscall "delete_module" (129) [priority: 65535]
if ($syscall == 129)
action ERRNO(38);
# filter for syscall "init_module" (128) [priority: 65535]
if ($syscall == 128)
action ERRNO(38);
# filter for syscall "umount2" (52) [priority: 65534]
if ($syscall == 52)
if ($a1 & 0x00000001 == 1)
action ERRNO(13);
# default action
action ALLOW;
# filter for arch x32 (3221225534)
# filter for syscall "kexec_load" (1073742352) [priority: 65535]
if ($syscall == 1073742352)
action ERRNO(38);
# filter for syscall "finit_module" (1073742137) [priority: 65535]
if ($syscall == 1073742137)
action ERRNO(38);
# filter for syscall "open_by_handle_at" (1073742128) [priority: 65535]
if ($syscall == 1073742128)
action ERRNO(38);
# filter for syscall "delete_module" (1073742000) [priority: 65535]
if ($syscall == 1073742000)
action ERRNO(38);
# filter for syscall "init_module" (1073741999) [priority: 65535]
if ($syscall == 1073741999)
action ERRNO(38);
# filter for syscall "umount2" (1073741990) [priority: 65534]
if ($syscall == 1073741990)
action ERRNO(13);
# default action
action ALLOW;
# invalid architecture action
action KILL;
# pseudo filter code end
lxc postgres 20250821223428.235 TRACE sync - ../src/lxc/sync.c:lxc_sync_barrier_parent:90 - Child waking parent with sequence cgroup-limits and waiting for sequence fds
lxc postgres 20250821223428.235 TRACE start - ../src/lxc/start.c:lxc_spawn:1908 - Set up legacy device cgroup controller limits
lxc postgres 20250821223428.235 TRACE start - ../src/lxc/start.c:lxc_spawn:1914 - Set up cgroup2 device controller limits
lxc postgres 20250821223428.235 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_finalize:2048 - Unified hierarchy supports freezer
lxc postgres 20250821223428.235 TRACE start - ../src/lxc/start.c:lxc_spawn:1917 - Finished setting up cgroups
lxc postgres 20250821223428.235 INFO utils - ../src/lxc/utils.c:run_script_argv:590 - Executing script "/proc/32403/exe forknet dhcp /var/lib/incus/containers/postgres/network /var/log/incus/postgres/forknet-dhcp.log" for container "postgres"
lxc postgres 20250821223428.235 TRACE utils - ../src/lxc/utils.c:run_script_argv:633 - Set environment variable: LXC_HOOK_TYPE=start-host
lxc postgres 20250821223428.235 TRACE utils - ../src/lxc/utils.c:run_script_argv:638 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc postgres 20250821223428.244 TRACE sync - ../src/lxc/sync.c:lxc_sync_wake_child:122 - Parent waking child with sequence fds
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_send_devpts_to_parent:1685 - Sent devpts file descriptor 22 to parent
lxc postgres 20250821223428.244 TRACE network - ../src/lxc/network.c:lxc_network_send_name_and_ifindex_to_parent:4160 - Sent network device eth0 with ifindex 41 to parent
lxc postgres 20250821223428.244 TRACE network - ../src/lxc/network.c:lxc_network_send_name_and_ifindex_to_parent:4164 - Sent network device names and ifindices to parent
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_recv_devpts_from_child:1467 - Received devpts file descriptor 9 from child
lxc postgres 20250821223428.244 TRACE network - ../src/lxc/network.c:lxc_network_recv_name_and_ifindex_from_child:4195 - Received network device eth0 with ifindex 41 from child
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_send_console_to_parent:3738 - Sent console to parent
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_sync_fds_child:3826 - Finished syncing file descriptors with parent
lxc postgres 20250821223428.244 TRACE sync - ../src/lxc/sync.c:lxc_sync_wait_parent:110 - Child waiting for parent with sequence ready-start
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_recv_console_from_child:3765 - Received console from child
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_sync_fds_parent:3796 - Finished syncing file descriptors with child
lxc postgres 20250821223428.244 DEBUG terminal - ../src/lxc/terminal.c:lxc_terminal_peer_default:704 - No such device - The process does not have a controlling terminal
lxc postgres 20250821223428.244 DEBUG terminal - ../src/lxc/terminal.c:lxc_terminal_create_log_file:878 - Using "/var/log/incus/postgres/console.log" as terminal log file
lxc postgres 20250821223428.244 TRACE terminal - ../src/lxc/terminal.c:lxc_terminal_create_ringbuf:859 - Allocated 131072 byte terminal ringbuffer
lxc postgres 20250821223428.244 TRACE sync - ../src/lxc/sync.c:lxc_sync_barrier_child:97 - Parent waking child with sequence ready-start and waiting with sequence restart
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: GOSU_VERSION=1.17
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: PGDATA=/var/lib/postgresql/18/docker
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/lib/postgresql/18/bin
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: PG_MAJOR=18
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: LANG=en_US.utf8
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: PG_VERSION=18~beta3-1.pgdg130+1
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: TERM=xterm
lxc postgres 20250821223428.244 TRACE conf - ../src/lxc/conf.c:lxc_set_environment:5224 - Set environment variable: HOME=/root
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:233 - index: 0
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:234 - ifindex: 41
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:290 - type: phys
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:293 - host side ifindex for phys device: 41
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:308 - flags: up
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:312 - link: veth4a1872fe
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:316 - l2proxy: false
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:319 - name: eth0
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:322 - hwaddr: 10:66:6a:83:f0:49
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:333 - ipv4 gateway auto: false
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:336 - ipv4 gateway dev: false
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:351 - ipv6 gateway auto: false
lxc postgres 20250821223428.248 TRACE confile_utils - ../src/lxc/confile_utils.c:lxc_log_configured_netdevs:354 - ipv6 gateway dev: false
lxc postgres 20250821223428.248 NOTICE execute - ../src/lxc/execute.c:execute_post_start:34 - 'docker-entrypoint.sh' started with pid '56826'
lxc postgres 20250821223428.248 TRACE start - ../src/lxc/start.c:lxc_serve_state_socket_pair:545 - Sent container state "RUNNING" to 6
lxc postgres 20250821223428.248 TRACE start - ../src/lxc/start.c:lxc_serve_state_clients:484 - Set container state to RUNNING
lxc postgres 20250821223428.248 TRACE start - ../src/lxc/start.c:lxc_serve_state_clients:487 - No state clients registered
lxc postgres 20250821223428.248 TRACE lxccontainer - ../src/lxc/lxccontainer.c:wait_on_daemonized_start:837 - Container is in "RUNNING" state
lxc postgres 20250821223428.248 TRACE mainloop - ../src/lxc/mainloop.c:__epoll_open:503 - Created epoll instance
lxc postgres 20250821223428.248 TRACE start - ../src/lxc/start.c:lxc_poll:627 - Mainloop is ready
lxc postgres 20250821223428.248 TRACE start - ../src/lxc/start.c:signal_handler:397 - Received signal ssi_signo(17) for ssi_pid(56827), si_signo(0), si_pid(0)
lxc postgres 20250821223428.248 NOTICE start - ../src/lxc/start.c:signal_handler:447 - Received 17 from pid 56827 instead of container init 56826
lxc postgres 20250821223428.248 TRACE commands - ../src/lxc/commands.c:lxc_cmd_accept:2115 - Accepted new client as fd 13 on command server fd 8
lxc postgres 20250821223428.248 TRACE commands - ../src/lxc/commands.c:lxc_cmd_accept:2115 - Accepted new client as fd 14 on command server fd 8
lxc postgres 20250821223428.248 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_init_pid; cleaning up client fd 13
lxc postgres 20250821223428.248 TRACE mainloop - ../src/lxc/mainloop.c:disarm_handler:65 - Disarmed 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.248 TRACE commands - ../src/lxc/commands.c:lxc_cmd_cleanup_handler:2022 - Closing client fd 13 for "lxc_cmd_cleanup_handler"
lxc postgres 20250821223428.248 TRACE mainloop - ../src/lxc/mainloop.c:delete_handler:79 - Deleted 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.248 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_init_pid; cleaning up client fd 14
lxc postgres 20250821223428.248 TRACE mainloop - ../src/lxc/mainloop.c:disarm_handler:65 - Disarmed 14 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.248 TRACE commands - ../src/lxc/commands.c:lxc_cmd_cleanup_handler:2022 - Closing client fd 14 for "lxc_cmd_cleanup_handler"
lxc postgres 20250821223428.248 TRACE mainloop - ../src/lxc/mainloop.c:delete_handler:79 - Deleted 14 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.248 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_state; cleaning up client fd 13
lxc postgres 20250821223428.248 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_limit_cgroup_fd; cleaning up client fd 13
lxc postgres 20250821223428.248 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_state; cleaning up client fd 14
lxc postgres 20250821223428.249 TRACE commands - ../src/lxc/commands.c:lxc_cmd_accept:2115 - Accepted new client as fd 13 on command server fd 8
lxc postgres 20250821223428.249 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_state; cleaning up client fd 13
lxc postgres 20250821223428.249 TRACE mainloop - ../src/lxc/mainloop.c:disarm_handler:65 - Disarmed 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.249 TRACE commands - ../src/lxc/commands.c:lxc_cmd_cleanup_handler:2022 - Closing client fd 13 for "lxc_cmd_cleanup_handler"
lxc postgres 20250821223428.249 TRACE mainloop - ../src/lxc/mainloop.c:delete_handler:79 - Deleted 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.249 TRACE commands - ../src/lxc/commands.c:lxc_cmd_accept:2115 - Accepted new client as fd 14 on command server fd 8
lxc postgres 20250821223428.249 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_limit_cgroup_fd; cleaning up client fd 13
lxc postgres 20250821223428.249 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_limit_cgroup_fd; cleaning up client fd 14
lxc postgres 20250821223428.249 TRACE mainloop - ../src/lxc/mainloop.c:disarm_handler:65 - Disarmed 14 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.249 TRACE commands - ../src/lxc/commands.c:lxc_cmd_cleanup_handler:2022 - Closing client fd 14 for "lxc_cmd_cleanup_handler"
lxc postgres 20250821223428.249 TRACE mainloop - ../src/lxc/mainloop.c:delete_handler:79 - Deleted 14 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.251 TRACE commands - ../src/lxc/commands.c:lxc_cmd_accept:2115 - Accepted new client as fd 13 on command server fd 8
lxc postgres 20250821223428.251 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_init_pid; cleaning up client fd 13
lxc postgres 20250821223428.251 TRACE mainloop - ../src/lxc/mainloop.c:disarm_handler:65 - Disarmed 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.251 TRACE commands - ../src/lxc/commands.c:lxc_cmd_cleanup_handler:2022 - Closing client fd 13 for "lxc_cmd_cleanup_handler"
lxc postgres 20250821223428.251 TRACE mainloop - ../src/lxc/mainloop.c:delete_handler:79 - Deleted 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.278 TRACE commands - ../src/lxc/commands.c:lxc_cmd_accept:2115 - Accepted new client as fd 13 on command server fd 8
lxc postgres 20250821223428.278 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_state; cleaning up client fd 13
lxc postgres 20250821223428.278 TRACE mainloop - ../src/lxc/mainloop.c:disarm_handler:65 - Disarmed 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.278 TRACE commands - ../src/lxc/commands.c:lxc_cmd_cleanup_handler:2022 - Closing client fd 13 for "lxc_cmd_cleanup_handler"
lxc postgres 20250821223428.278 TRACE mainloop - ../src/lxc/mainloop.c:delete_handler:79 - Deleted 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.278 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_init_pid; cleaning up client fd 13
lxc postgres 20250821223428.278 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_limit_cgroup_fd; cleaning up client fd 13
lxc postgres 20250821223428.279 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_limit_cgroup_fd; cleaning up client fd 13
lxc postgres 20250821223428.279 TRACE mainloop - ../src/lxc/mainloop.c:disarm_handler:65 - Disarmed 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.279 TRACE commands - ../src/lxc/commands.c:lxc_cmd_cleanup_handler:2022 - Closing client fd 13 for "lxc_cmd_cleanup_handler"
lxc postgres 20250821223428.279 TRACE mainloop - ../src/lxc/mainloop.c:delete_handler:79 - Deleted 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.279 TRACE commands - ../src/lxc/commands.c:lxc_cmd_accept:2115 - Accepted new client as fd 13 on command server fd 8
lxc postgres 20250821223428.279 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_state; cleaning up client fd 13
lxc postgres 20250821223428.279 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_init_pid; cleaning up client fd 13
lxc postgres 20250821223428.280 TRACE commands - ../src/lxc/commands.c:lxc_cmd_accept:2115 - Accepted new client as fd 13 on command server fd 8
lxc postgres 20250821223428.280 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_init_pid; cleaning up client fd 13
lxc postgres 20250821223428.280 TRACE mainloop - ../src/lxc/mainloop.c:disarm_handler:65 - Disarmed 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.280 TRACE commands - ../src/lxc/commands.c:lxc_cmd_cleanup_handler:2022 - Closing client fd 13 for "lxc_cmd_cleanup_handler"
lxc postgres 20250821223428.280 TRACE mainloop - ../src/lxc/mainloop.c:delete_handler:79 - Deleted 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.295 TRACE commands - ../src/lxc/commands.c:lxc_cmd_accept:2115 - Accepted new client as fd 13 on command server fd 8
lxc postgres 20250821223428.295 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_state; cleaning up client fd 13
lxc postgres 20250821223428.295 TRACE mainloop - ../src/lxc/mainloop.c:disarm_handler:65 - Disarmed 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.295 TRACE commands - ../src/lxc/commands.c:lxc_cmd_cleanup_handler:2022 - Closing client fd 13 for "lxc_cmd_cleanup_handler"
lxc postgres 20250821223428.295 TRACE mainloop - ../src/lxc/mainloop.c:delete_handler:79 - Deleted 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.295 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_init_pid; cleaning up client fd 13
lxc postgres 20250821223428.295 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_limit_cgroup_fd; cleaning up client fd 13
lxc postgres 20250821223428.296 TRACE commands - ../src/lxc/commands.c:lxc_cmd_accept:2115 - Accepted new client as fd 13 on command server fd 8
lxc postgres 20250821223428.296 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_state; cleaning up client fd 13
lxc postgres 20250821223428.296 TRACE mainloop - ../src/lxc/mainloop.c:disarm_handler:65 - Disarmed 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.296 TRACE commands - ../src/lxc/commands.c:lxc_cmd_cleanup_handler:2022 - Closing client fd 13 for "lxc_cmd_cleanup_handler"
lxc postgres 20250821223428.296 TRACE mainloop - ../src/lxc/mainloop.c:delete_handler:79 - Deleted 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.296 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_limit_cgroup_fd; cleaning up client fd 13
lxc postgres 20250821223428.297 TRACE commands - ../src/lxc/commands.c:lxc_cmd_accept:2115 - Accepted new client as fd 13 on command server fd 8
lxc postgres 20250821223428.297 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_state; cleaning up client fd 13
lxc postgres 20250821223428.297 TRACE mainloop - ../src/lxc/mainloop.c:disarm_handler:65 - Disarmed 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.297 TRACE commands - ../src/lxc/commands.c:lxc_cmd_cleanup_handler:2022 - Closing client fd 13 for "lxc_cmd_cleanup_handler"
lxc postgres 20250821223428.297 TRACE mainloop - ../src/lxc/mainloop.c:delete_handler:79 - Deleted 13 for "lxc_cmd_handler" handler
lxc postgres 20250821223428.297 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_limit_cgroup_fd; cleaning up client fd 13
lxc postgres 20250821223428.297 TRACE commands - ../src/lxc/commands.c:lxc_cmd_handler:2082 - Processed command get_init_pid; cleaning up client fd 13
lxc postgres 20250821223428.304 TRACE start - ../src/lxc/start.c:signal_handler:397 - Received signal ssi_signo(17) for ssi_pid(56826), si_signo(17), si_pid(56826)
lxc postgres 20250821223428.304 DEBUG start - ../src/lxc/start.c:signal_handler:465 - Container init process 56826 exited
lxc postgres 20250821223428.304 TRACE start - ../src/lxc/start.c:lxc_poll:644 - Closed console mainloop
lxc postgres 20250821223428.304 TRACE start - ../src/lxc/start.c:lxc_poll:649 - Closed mainloop
lxc postgres 20250821223428.304 TRACE start - ../src/lxc/start.c:lxc_poll:652 - Closed signal file descriptor 5
lxc postgres 20250821223428.304 TRACE network - ../src/lxc/network.c:lxc_restore_phys_nics_to_netns:3804 - Moving physical network devices back to parent network namespace
lxc postgres 20250821223428.340 TRACE network - ../src/lxc/network.c:lxc_restore_phys_nics_to_netns:3833 - Moved network device "eth0" back to network namespace
lxc postgres 20250821223428.340 INFO error - ../src/lxc/error.c:lxc_error_set_and_log:31 - Child <56826> ended on error (1)
lxc postgres 20250821223428.340 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_USER_NS=/proc/56806/fd/18
lxc postgres 20250821223428.340 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_MNT_NS=/proc/56806/fd/19
lxc postgres 20250821223428.340 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_PID_NS=/proc/56806/fd/20
lxc postgres 20250821223428.340 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_UTS_NS=/proc/56806/fd/21
lxc postgres 20250821223428.340 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_IPC_NS=/proc/56806/fd/22
lxc postgres 20250821223428.340 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_NET_NS=/proc/56806/fd/4
lxc postgres 20250821223428.340 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_CGROUP_NS=/proc/56806/fd/23
lxc postgres 20250821223428.346 TRACE network - ../src/lxc/network.c:lxc_delete_network_priv:3678 - Renamed interface with index 41 from "eth0" to its initial name "veth4a1872fe"
lxc postgres 20250821223428.346 TRACE network - ../src/lxc/network.c:lxc_delete_network_priv:3689 - Restored interface "veth4a1872fe" to its initial mtu "1500"
lxc postgres 20250821223428.346 DEBUG network - ../src/lxc/network.c:lxc_delete_network:4221 - Deleted network devices
lxc postgres 20250821223428.346 TRACE start - ../src/lxc/start.c:lxc_serve_state_clients:484 - Set container state to STOPPING
lxc postgres 20250821223428.346 TRACE start - ../src/lxc/start.c:lxc_serve_state_clients:487 - No state clients registered
lxc postgres 20250821223428.346 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_USER_NS=/proc/56806/fd/18
lxc postgres 20250821223428.346 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_MNT_NS=/proc/56806/fd/19
lxc postgres 20250821223428.346 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_PID_NS=/proc/56806/fd/20
lxc postgres 20250821223428.346 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_UTS_NS=/proc/56806/fd/21
lxc postgres 20250821223428.346 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_IPC_NS=/proc/56806/fd/22
lxc postgres 20250821223428.346 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_NET_NS=/proc/56806/fd/4
lxc postgres 20250821223428.346 TRACE start - ../src/lxc/start.c:lxc_expose_namespace_environment:907 - Set environment variable LXC_CGROUP_NS=/proc/56806/fd/23
lxc postgres 20250821223428.346 INFO utils - ../src/lxc/utils.c:run_script_argv:590 - Executing script "/opt/incus/bin/incusd callhook /var/lib/incus "default" "postgres" stopns" for container "postgres"
lxc postgres 20250821223428.346 TRACE utils - ../src/lxc/utils.c:run_script_argv:633 - Set environment variable: LXC_HOOK_TYPE=stop
lxc postgres 20250821223428.346 TRACE utils - ../src/lxc/utils.c:run_script_argv:638 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc postgres 20250821223428.450 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_remove:491 - Removed cgroup tree 10(lxc.payload.postgres)
lxc postgres 20250821223428.450 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:726 - Reusing 10(lxc.pivot) cgroup
lxc postgres 20250821223428.450 TRACE cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:741 - Opened cgroup lxc.pivot as 3
lxc postgres 20250821223428.484 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:cgfsng_monitor_destroy:925 - Device or resource busy - Failed to destroy 10(lxc.monitor.postgres-9)
lxc postgres 20250821223428.484 TRACE start - ../src/lxc/start.c:lxc_end:964 - Closed command socket
lxc postgres 20250821223428.484 TRACE start - ../src/lxc/start.c:lxc_end:975 - Set container state to "STOPPED"
lxc 20250821223428.484 ERROR af_unix - ../src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc 20250821223428.484 ERROR commands - ../src/lxc/commands.c:lxc_cmd_rsp_recv_fds:128 - Failed to receive file descriptors for command "get_state"
lxc postgres 20250821223428.484 INFO utils - ../src/lxc/utils.c:run_script_argv:590 - Executing script "/opt/incus/share/lxcfs/lxc.reboot.hook" for container "postgres"
lxc postgres 20250821223428.484 TRACE utils - ../src/lxc/utils.c:run_script_argv:633 - Set environment variable: LXC_HOOK_TYPE=post-stop
lxc postgres 20250821223428.484 TRACE utils - ../src/lxc/utils.c:run_script_argv:638 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc postgres 20250821223428.990 INFO utils - ../src/lxc/utils.c:run_script_argv:590 - Executing script "/opt/incus/bin/incusd callhook /var/lib/incus "default" "postgres" stop" for container "postgres"
lxc postgres 20250821223428.991 TRACE utils - ../src/lxc/utils.c:run_script_argv:633 - Set environment variable: LXC_HOOK_TYPE=post-stop
lxc postgres 20250821223428.991 TRACE utils - ../src/lxc/utils.c:run_script_argv:638 - Set environment variable: LXC_HOOK_SECTION=lxc
For OCI debugging it is always useful to also post the console output. Start your OCI container with –console at the end and report back.
>incus start <container> --console
In addition the config details are another preferred detail:
>incus config show <container>
From experience you might need to add a storage volume to the container, mounted at /var/lib/postgresql/data which might require some ownership tweaks to get it working.
Thanks adding a disk and mounting the storage helped. I was surprised that I needed to do this, since in docker I can start the container without a volume, and loose data on restart. But looks like OCI always needs a disk.
