I’ve got and nfs server in a container, and a client in another container.
After some problems install nfs on the container I read this
So I setup up the nfs server container like this
printf "mount fstype=rpc_pipefs,\nmount fstype=nfsd," | lxc config set nfs raw.apparmor -
lxc config set nfs security.privileged true
/etc/exports look like this
/opt/data *(rw,sync,no_subtree_check,no_root_squash,fsid=root)
And on the nfs server I can mount it
mount localhost:/opt/data /mnt
But from another container with the nfs client installed it doesn’t work
mount nfs_server:/opt/data /mnt/test/
mount.nfs: Operation not permitted
I’ve also tried with the client container as privileged, but it doesn’t work either… ![]()
Does anybody have any suggestions?
Cheers.
