Perform some tasks before starting lxd containers
I have some LXD containers running in a host, this host starts every morning, and all the lxd containers started during the boot, I’d like to do following task before certain lxd containers started:
sudo zfs snapshot mypool/database1
possible? for now I do following:
sudo lxc stop cont1
sudo lxc start cont1
works, but tedious, any suggestions? Thanks.
Thanks for the info, my use case is a little different, it is a folder in the host that is added to container:
sudo lxc config device add centos6-i386 dataset disk source=/mypool/database/data path=/data
I am taking snapshot of this /mypool/database/data, not the container, I stop the container before zfs snapshot.
after taking up a snapshot, send to another host as backup, works quite well, i don’t need to back up the lxd container itself as it can be easily launch.
Perhaps you could use systemd and a script (see link below)
I think LXD now has tools for backing up pools so you might want to switch to that, but if your way works - it works :man_shrugging:
I think this is what I need, thanks.
Ive just thought you may also want to execute your script before LXD starts, not 100% sure but you could try adding the following to the file
If all you need to do is take a snapshot prior to startup, we have an issue open around improving auto-snapshot timings which will cover this case in the future.
https://github.com/lxc/lxd/issues/7237#issuecomment-617495306
Thanks for pointing that issue, I have inquired there.
