Lox
October 19, 2022, 6:35am
1
After upgrade of server from 18.04 to 22.04 I have an issue inside a container:
» LANG=C apt update
Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:3 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
Reading package lists... Done
W: chown to _apt:root of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (1: Operation not permitted)
W: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (1: Operation not permitted)
W: chown to _apt:root of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (1: Operation not permitted)
W: chmod 0700 of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (1: Operation not permitted)
W: Download is performed unsandboxed as root as file '/var/lib/apt/lists/partial/archive.ubuntu.com_ubuntu_dists_focal_InRelease' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
W: Problem unlinking the file /var/lib/apt/lists/partial/archive.ubuntu.com_ubuntu_dists_focal_InRelease - PrepareFiles (13: Permission denied)
W: chmod 0600 of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_focal_InRelease failed - Item::QueueURI (1: Operation not permitted)
W: Problem unlinking the file /var/lib/apt/lists/partial/archive.ubuntu.com_ubuntu_dists_focal-updates_InRelease - PrepareFiles (13: Permission denied)
W: Problem unlinking the file /var/lib/apt/lists/partial/archive.ubuntu.com_ubuntu_dists_focal-backports_InRelease - PrepareFiles (13: Permission denied)
W: Problem unlinking the file /var/lib/apt/lists/partial/archive.ubuntu.com_ubuntu_dists_focal-security_InRelease - PrepareFiles (13: Permission denied)
W: chown to root:root of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_focal_InRelease failed - 201::URIDone (1: Operation not permitted)
W: chmod 0644 of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_focal_InRelease failed - 201::URIDone (1: Operation not permitted)
W: chmod 0600 of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_focal-updates_InRelease failed - Item::QueueURI (1: Operation not permitted)
W: chown to root:root of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_focal-updates_InRelease failed - 201::URIDone (1: Operation not permitted)
W: chmod 0644 of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_focal-updates_InRelease failed - 201::URIDone (1: Operation not permitted)
W: chmod 0600 of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_focal-backports_InRelease failed - Item::QueueURI (1: Operation not permitted)
W: chown to root:root of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_focal-backports_InRelease failed - 201::URIDone (1: Operation not permitted)
W: chmod 0644 of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_focal-backports_InRelease failed - 201::URIDone (1: Operation not permitted)
W: chmod 0600 of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_focal-security_InRelease failed - Item::QueueURI (1: Operation not permitted)
W: chown to root:root of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_focal-security_InRelease failed - 201::URIDone (1: Operation not permitted)
W: chmod 0644 of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_focal-security_InRelease failed - 201::URIDone (1: Operation not permitted)
E: Unable to read /var/lib/apt/lists/partial/ - open (13: Permission denied)
Here is the container config:
# lxc config show duniter
image.architecture: amd64
image.description: ubuntu 20.04 LTS amd64 (release) (20210819)
image.label: release
image.os: ubuntu
image.release: focal
image.serial: "20210819"
image.type: squashfs
image.version: "20.04"
limits.cpu: "4"
limits.memory: 4GB
volatile.base_image: 9c939141a94bbdcfd29b0b3be6dc135b9d3e8d73b19235f06de4593898e8b960
volatile.eth0.host_name: veth59b5d258
volatile.eth0.hwaddr: 00:16:3e:0c:78:5b
volatile.idmap.base: "0"
volatile.uuid: 8debd7c2-ff7f-4090-8eac-aaaa8b55a046
ipv4.address: 10.2.249.21
network: lxdbr0
pool: pool1
tomp
(Thomas Parrott)
October 20, 2022, 10:15am
2
What is the output of lxc storage show pool1?
tomp
(Thomas Parrott)
3
Are newly created instances OK?
Lox
October 21, 2022, 12:54am
4
source: pool1/lxd
volatile.initial_source: pool1/lxd
zfs.pool_name: pool1/lxd
driver: zfs
- /1.0/instances/backup
- /1.0/instances/coturn
- /1.0/instances/duniter
- /1.0/instances/front
- /1.0/instances/prepa
- /1.0/instances/stats
- /1.0/instances/texto
- /1.0/instances/mariadb
- /1.0/instances/vm31
- /1.0/instances/vm32
- /1.0/profiles/default
- /1.0/profiles/vm-pool1
status: Created
locations:
- none
Good catch, and no, I get this:
E: Could not open file /var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_jammy-security_main_cnf_Commands-amd64 - open (2: No such file or directory)
Traceback (most recent call last):
File "/usr/lib/cnf-update-db", line 32, in <module>
col.create(db)
File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 95, in create
self._fill_commands(con)
File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 144, in _fill_commands
raise subprocess.CalledProcessError(returncode=sub.returncode,
subprocess.CalledProcessError: Command '/usr/lib/apt/apt-helper cat-file /var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_jammy-security_main_cnf_Commands-amd64' returned non-zero exit status 100.
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
tomp
(Thomas Parrott)
October 25, 2022, 12:35pm
5
Please can you show lxc info, lxc storage show <pool>
Lox
October 27, 2022, 7:23am
6
Here you go @tomp :
# lxc info
config: {}
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
- devlxd_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_authentication
- backup_compression
- candid_config
- nvidia_runtime_config
- storage_unmapped
- projects
- candid_config_key
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- snapshot_schedule_aliases
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- rbac
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
- images_default_architecture
- network_ovn_acl_defaults
- gpu_mig
- project_usage
- network_bridge_acl
- warnings
- clustering_join_token
- clustering_description
- server_trusted_proxy
- clustering_update_cert
- storage_api_project
- resources_gpu_usb
- clustering_evacuation
- network_ovn_nat_address
- network_bgp
- network_forward
- custom_volume_refresh
- network_counters_errors_dropped
- metrics
- image_source_project
- clustering_config
- network_peer
- linux_sysctl
- network_dns
- ovn_nic_acceleration
- certificate_self_renewal
- instance_project_move
- storage_volume_project_move
- cloud_init
- network_dns_nat
- database_leader
- instance_all_projects
- clustering_groups
- ceph_rbd_du
- instance_get_full
- qemu_metrics
- gpu_mig_uuid
- event_project
- clustering_evacuation_live
- instance_allow_inconsistent_copy
- network_state_ovn
- storage_volume_api_filtering
- image_restrictions
- storage_zfs_export
- network_dns_records
- storage_zfs_reserve_space
- network_acl_log
- storage_zfs_blocksize
- metrics_cpu_seconds
- instance_snapshot_never
- certificate_token
- instance_nic_routed_neighbor_probe
- event_hub
- agent_nic_config
- projects_restricted_intercept
- metrics_authentication
- images_target_project
- cluster_migration_inconsistent_copy
- cluster_ovn_chassis
- container_syscall_intercept_sched_setscheduler
- storage_lvm_thinpool_metadata_size
- storage_volume_state_total
- instance_file_head
- instances_nic_host_name
- image_copy_profile
- container_syscall_intercept_sysinfo
- clustering_evacuation_mode
- resources_pci_vpd
- qemu_raw_conf
- storage_cephfs_fscache
- network_load_balancer
- vsock_api
- instance_ready_state
- network_bgp_holdtime
- storage_volumes_all_projects
- metrics_memory_oom_total
- storage_buckets
- storage_buckets_create_credentials
- metrics_cpu_effective_total
- projects_networks_restricted_access
- storage_buckets_local
- loki
- acme
- internal_metrics
- cluster_join_token_expiry
- remote_token_expiry
- init_preseed
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses: []
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----
[redacted]
-----END CERTIFICATE-----
certificate_fingerprint: [redacted]
driver: qemu | lxc
driver_version: 7.1.0 | 5.0.1
firewall: xtables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
idmapped_mounts: "true"
netnsid_getifaddrs: "true"
seccomp_listener: "true"
shiftfs: "false"
uevent_injection: "true"
unpriv_fscaps: "true"
kernel_version: 5.15.0-52-generic
lxc_features:
cgroup2: "true"
core_scheduling: "true"
devpts_fd: "true"
idmapped_mounts_v2: "true"
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
network_veth_router: "true"
pidfd: "true"
seccomp_notify: "true"
os_name: Ubuntu
os_version: "20.04"
project: default
server: lxd
server_clustered: false
server_event_mode: full-mesh
server_name: server
server_pid: 3172010
server_version: "5.7"
storage: zfs
storage_version: 2.1.4-0ubuntu0.1
storage_supported_drivers:
- name: cephobject
version: 15.2.16
remote: true
- name: dir
version: "1"
remote: false
- name: lvm
version: 2.03.07(2) (2019-11-30) / 1.02.167 (2019-11-30) / 4.45.0
remote: false
- name: zfs
remote: false
- name: btrfs
version: 5.4.1
remote: false
- name: ceph
version: 15.2.16
remote: true
- name: cephfs
version: 15.2.16
remote: true
tomp
(Thomas Parrott)
November 14, 2022, 10:14am
8
As you’re running 22.04, you’re kernel will be 5.15, and you’re running on ZFS, meaning idmapped mounts are not available, which means you’re likely using shiftfs and could be being affected by:
Can you try this:
Can you do snap unset lxd shiftfs.enable followed by sudo systemctl reload snap.lxd.daemon and see if the new instance will launch.
I don’t think this will fix your existing instance as you’re using shift=true, but lets try and narrow down the problem to shiftfs.
