I have problem with my fresh installation of lxd on physical server.
Hardware details:
- Asus H110M-A/M.2 Micro ATX
- Intel Core i7-6700 4 x 3.4 GHz
- DDR4 HyperX Predator 16GB 3200Mhz CL16
Os nad LXD details:
- Ubuntu 22.04.1 LTS
- LXC version: 5.0.1
- LXD version (snap list): lxd 5.0.1-9dcf35b 23541 5.0/stable/… canonical✓ -
This is how I did the whole setup, first of all I changed default location of lxc to different partition (I’m not sure if that may have any impact on my further problems, but maybe that was worth to mention):
snap stop lxd
mkdir /mnt/drives/virt/lxd
Than I added new mount point to /etc/fstab
/mnt/drives/virt/lxd /var/snap/lxd/common/lxd none bind 0 0
Next step was lxd init, this is how I did answer to the questions from the creator:
root@nas:/root# lxd init
Would you like to use LXD clustering? (yes/no) [default=no]:
Name of the storage backend to use (dir, lvm, zfs, ceph, btrfs) [default=zfs]: dir
Would you like to create a new local network bridge? (yes/no) [default=yes]:
What should the new bridge be called? [default=lxdbr0]:
What IPv6 address should be used? (CIDR subnet notation, “auto” or “none”) [default=auto]: none
Would you like the LXD server to be available over the network? (yes/no) [default=no]: yes
Address to bind LXD to (not including port) [default=all]:
Port to bind LXD to [default=8443]:
Trust password for new clients:
Again:
Would you like stale cached images to be updated automatically? (yes/no) [default=yes]:
Would you like a YAML "lxd init" preseed to be printed? (yes/no) [default=no]:
Bridge adapter lxdbr0 was created, please find output of ip a
from the host: admin@nas:~$ ip a1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state U - Pastebin.com
This is the output of the ip route list
from the host:
admin@nas:~$ ip route list
default via 192.168.1.1 dev enp0s31f6 proto dhcp src 192.168.1.204 metric 100
10.168.17.0/24 dev lxdbr0 proto kernel scope link src 10.168.17.1
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
172.18.0.0/16 dev br-7df03143e143 proto kernel scope link src 172.18.0.1
172.19.0.0/16 dev br-518524b036cd proto kernel scope link src 172.19.0.1
192.168.1.0/24 dev enp0s31f6 proto kernel scope link src 192.168.1.204 metric 100
192.168.1.1 dev enp0s31f6 proto dhcp scope link src 192.168.1.204 metric 100
Remote connection from other lxc server works just fine, I can create both containers and virtual machines, locally and from the remote server. The problem is, that my containers and vms do not have access to the internet and to each other - I cannot install anything from the repos on them, even apt update
does not work.
This is the output of ip a
from the cntainer:
root@full-elephant:~# ip route
default via 10.168.17.1 dev eth0 proto dhcp src 10.168.17.193 metric 100
10.168.17.0/24 dev eth0 proto kernel scope link src 10.168.17.193 metric 100
10.168.17.1 dev eth0 proto dhcp scope link src 10.168.17.193 metric 100
I can ping from the host to container:
admin@nas:~$ lxc list
| ubuntu01 | RUNNING | 10.168.17.225 (eth0) | | CONTAINER | 0 |
admin@nas:~$ ping 10.168.17.225
PING 10.168.17.225 (10.168.17.225) 56(84) bytes of data.
64 bytes from 10.168.17.225: icmp_seq=1 ttl=64 time=0.088 ms
64 bytes from 10.168.17.225: icmp_seq=2 ttl=64 time=0.061 ms
64 bytes from 10.168.17.225: icmp_seq=3 ttl=64 time=0.059 ms
^C
--- 10.168.17.225 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2053ms
rtt min/avg/max/mdev = 0.059/0.069/0.088/0.013 ms
And from the host to bridge adapter:
admin@nas:~$ ping 10.168.17.1
PING 10.168.17.1 (10.168.17.1) 56(84) bytes of data.
64 bytes from 10.168.17.1: icmp_seq=1 ttl=64 time=0.083 ms
64 bytes from 10.168.17.1: icmp_seq=2 ttl=64 time=0.049 ms
64 bytes from 10.168.17.1: icmp_seq=3 ttl=64 time=0.050 ms
^C
--- 10.168.17.1 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2044ms
rtt min/avg/max/mdev = 0.049/0.060/0.083/0.015 ms
I can ping bridge adapter from the container:
root@ubuntu01:~# ping 10.168.17.1
64 bytes from 10.168.17.1: icmp_seq=1 ttl=64 time=0.099 ms
64 bytes from 10.168.17.1: icmp_seq=2 ttl=64 time=0.073 ms
64 bytes from 10.168.17.1: icmp_seq=3 ttl=64 time=0.072 ms
^C
3 packets transmitted, 3 received, 0% packet loss, time 2047ms
rtt min/avg/max/mdev = 0.072/0.081/0.099/0.012 ms
However, I cannot update apt database on the container:
root@ubuntu01:~# apt update
Ign:1 http://security.ubuntu.com/ubuntu jammy-security InRelease
Ign:2 http://archive.ubuntu.com/ubuntu jammy InRelease
Ign:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
Err:1 http://security.ubuntu.com/ubuntu jammy-security InRelease
Cannot initiate the connection to security.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out Could not connect to security.ubuntu.com:80 (185.125.190.36), connection timed out Could not connect to security.ubuntu.com:80 (185.125.190.39), connection timed out
Err:2 http://archive.ubuntu.com/ubuntu jammy InRelease
Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (91.189.91.38), connection timed out Could not connect to archive.ubuntu.com:80 (185.125.190.39), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to archive.ubuntu.com:80 (185.125.190.36), connection timed out
Err:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/jammy/InRelease Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (91.189.91.38), connection timed out Could not connect to archive.ubuntu.com:80 (185.125.190.39), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to archive.ubuntu.com:80 (185.125.190.36), connection timed out
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/jammy-updates/InRelease Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable)
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/jammy-security/InRelease Cannot initiate the connection to security.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out Could not connect to security.ubuntu.com:80 (185.125.190.36), connection timed out Could not connect to security.ubuntu.com:80 (185.125.190.39), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.
I can’t ping google’s dns as well:
root@ubuntu01:~# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
^C
--- 8.8.8.8 ping statistics ---
26 packets transmitted, 0 received, 100% packet loss, time 25598ms
Pinging from one container to another is not possible as well:
| ubuntu02 | RUNNING | 10.168.17.243 (eth0) | | CONTAINER | 0 |
root@ubuntu01:~# ping 10.168.17.243
PING 10.168.17.243 (10.168.17.243) 56(84) bytes of data.
^C
--- 10.168.17.243 ping statistics ---
22 packets transmitted, 0 received, 100% packet loss, time 21504ms
Any idea what could go wrong? I tested exacly the same setup on raspberry pi with Ubuntu Server 22 and everything works just fine, no idea why is it not working on this machine.
