Hi
I’m running Ceph as backend storage for my OpenStack cluster. I thought I’d try it out on LXD, so I create an RBD pool called lxd, ran RBD init on the pool then tried the command
lxc storage create ceph1 ceph source=lxd
but unfortunately get the following back:
Now this ceph.conf works fine for OpenStack so not sure whats wrong with its format?
[client.rgw.p67.rgw0]
host = p67
keyring = /var/lib/ceph/radosgw/ceph-rgw.p67.rgw0/keyring
log file = /var/log/ceph/ceph-rgw-p67.rgw0.log
rgw frontends = beast endpoint=192.168.88.67:8080
rgw thread pool size = 512
[client.rgw.p70.rgw0]
host = p70
keyring = /var/lib/ceph/radosgw/ceph-rgw.p70.rgw0/keyring
log file = /var/log/ceph/ceph-rgw-p70.rgw0.log
rgw frontends = beast endpoint=192.168.88.70:8080
# Please do not change this file directly since it is managed by Ansible and will be overwritten
[global]
cluster network = 192.168.88.0/24
fsid = 9bd31b02-ee3c-4dc7-8334-c12bc9596ca0
mon host = [v2:192.168.88.67:3300,v1:192.168.88.67:6789],[v2:192.168.88.70:3300,v1:192.168.88.70:6789]
mon initial members = p67,p70
osd pool default crush rule = -1
public network = 192.168.88.0/24
[osd]
osd memory target = 23535812608
