I have always used interfaces configured via ifupdown as LXD interfaces and now I am discovering LXD managed bridges. However, I can’t figure out how they work.
You can’t do something like your lxdbr0 through LXD and in general such bridges which provide host connectivity are best done through ifupdown.
However, for a bridge like your lxdbr50, that definitely can be done (and probably should be done) through LXD.
lxc network create lxdbr50 would give you a similar bridge with DHCP, DNS and IPv4/IPv6 subnets. You can turn off IPv4 or IPv6 (or both) by setting ipv4.address or ipv6.address to none.
I understand about lxdbr0, so I continue with ifupdown for him.
About lxdbr50, how can I set eth0.50 as “bridge_port” on LXD bridge ? My LXD subnet is on VLAN50.
You can set bridge.external_interfaces to eth0.50 however, you’ll need that interface to exist ahead of time, so will need to define it as a VLAN in your ifupdown config.
pulsarr@infra-odroidc4-neree:~$ lxc network set lxdbr50 bridge.external_interfaces=eth0.50
Error: Config key "bridge.external_interfaces" is cluster member specific
You seem to have clustering enabled for some reason.
In this case, you’ll need lxc network set lxdbr50 bridge.external_interfaces=eth0.50 --target neree
