Hi everyone,
I’ve an Ubuntu 16.04.5 LTS host running Lxc 2.0.11, with two network interfaces to reach two different subnets. In this moment I’m using this settings custom template:
lxcbr0 8000.00163e000000 no veth5QEGB5
vetha9c90c84
lxcbr1 8000.a64ec9f7da73 no veth2609861c
vethKXKDB0
and this default settings:
environment.http_proxy: ""
user.network_mode: ""
nictype: macvlan
parent: eno1
eth1:
nictype: bridged
parent: lxcbr1
used_by: []
On the guest Ubuntu I’ve two network interfaces:
- eth0 is static and works fine for the first subnet;
- eth1 is configured to use DHCP, an IP address was assegned correctly;
I configured the default gateway to use eth0 and a new route to reach the second subnet using eth1… but the second subnet is unreacheable.
Some ideas?
Thank you very much
