Hi everyone,
I’m new to lcx/lxd. I do not understand storage. Please help.
Currently I am using the “dir” backend, all is fine, except I see the available space from the entire drive, despite having the limit set in the profile.
root: path: / pool: data size: 5GB type: disk
where the “data” is “dir” backend storage (with this setup, from the container I see all the 2+ TB of space, instead of 5 GB).
On the server I have a hardware raid, I do not want additional safety with zfs or btrfs (btw, do these backends use a file or a physical partition/disk?). I would want something simple either a “dir” backend with a specific limit or something like a file on the filesystem for each container (I understand that loopback devices are not recommended). So what would be a better choice?
Any advice is appreciated. Thank you.
