I’m creating a ZVOL which I then want to pass to a privileged container to then create an ext4 fs on it. I’ve managed to do this, but looking at mount/lsblk I noticed something odd:
#host
administrator@lxd-test:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 14.9G 0 disk
├─sda1 8:1 0 14G 0 part /
├─sda2 8:2 0 1K 0 part
└─sda5 8:5 0 952M 0 part [SWAP]
sdb 8:16 0 111.8G 0 disk
├─sdb1 8:17 0 111.8G 0 part
└─sdb9 8:25 0 8M 0 part
sdc 8:32 0 111.8G 0 disk
├─sdc1 8:33 0 111.8G 0 part
└─sdc9 8:41 0 8M 0 part
zd0 230:0 0 1G 0 disk
└─zd0p1 230:1 0 1023M 0 part
# container
/dev/sda1 on /dev/zd0p1 type ext4 (rw,relatime,errors=remount-ro,data=ordered)
/dev/zd0p1 on /mnt type ext4 (rw,relatime,stripe=2,data=ordered)
root@spike-test1:~# lsblk
├─sda1 8:1 0 14G 0 part /dev/zd0p1
└─zd0p1 230:1 0 1023M 0 part /mnt
notice how in the container zd0p1 is listed as the mount point for sda1… is that expected/safe or is that a symptom of something that will eventually go wrong?
fwiw in case anybody cares here’s the step I had to take:
on host
sudo zfs create -V 1G data/testvol -> /dev/zd0
fdisk /dev/zd0 (initially I exported zd0 to the container and fdisk’ed in there, but the parition device is created on the host and does not exist on the container)
The way you pass devices into an unprivileged container is by bind-mounting the device node from /dev/ of the host onto the device name in the container.
In this case /dev/zd0p1 from your host’s /dev is getting cloned at /var/lib/lxd/devices/… and then bind-mounted onto /dev/zd0p1 in the container. As far as the kernel is concerned this is therefore a bind-mount from a file on /dev/sda1 of the host onto /dev/zd0p1 in the container.
The mount table output is somewhat confusing but this is all correct.
Thank but it still isn’t useful because containers are not allow to mount, right ? The device should be added as a “disk” to be used in the container if I understand all that well.
