General description
I’m trying to setup an OpenWRT container running inside incus to manage my network. The host server is running Debian 12. It has 4 ethernet ports which inside the server are enp2s0 to enp5s0 and I have a bridge br0 setup for the host to connect on the network. The setup I have with this server is that all physical interfaces are passed through to OpenWRT using nictype=physical, br0 is connected inside the container for communication and a few other incus managed bridges as well. Below I’ll give more details on the configuration files for this precise build.
In particular, everything is working as expected except for when I reboot the container either from the container itself or by using incus restart openwrt. This usually fails and the container doesn’t come back up due to some physical interface which was passed through to the container leaving the container with a different name. The container doesn’t restart with an error indication that the nic device doesn’t exist.
Has anynoe encountered this issue before? Has anyone fixed this issue or know a particular cause in my setup? Is it a bug?
Configuration details
The host network setup has a bridge with a static IP address and nothing else.
victoitor@router-server:~$ cat /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
victoitor@router-server:~$ cat /etc/network/interfaces.d/br0
## dhcp ip config file for br0
auto br0
iface br0 inet static
address 10.0.0.10
netmask 255.255.255.0
gateway 10.0.0.1
bridge_ports none
bridge_stp off # disable Spanning Tree Protocol
bridge_waitport 0 # no delay before a port becomes available
bridge_fd 0 # no forwarding delay
Incus has a few bridges setup, but dns and dhcp are turned off. I’ll show the configuration of only one of those bridges as the other ones are identical.
victoitor@router-server:~$ incus network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| br0 | bridge | NO | | | | 3 | |
| dmz | bridge | YES | none | none | | 2 | CREATED |
| iot | bridge | YES | none | none | | 2 | CREATED |
| services | bridge | YES | none | none | | 2 | CREATED |
| untrusted | bridge | YES | none | none | | 2 | CREATED |
victoitor@router-server:~$ incus network show iot
dns.mode: none
ipv4.address: none
ipv4.dhcp: "false"
ipv4.firewall: "false"
ipv6.address: none
ipv6.dhcp: "false"
ipv6.firewall: "false"
type: bridge
- /1.0/instances/openwrt
- /1.0/profiles/router
managed: true
status: Created
locations:
- none
This is the container configuration and the router profile which it uses.
victoitor@router-server:~$ incus config show openwrt
image.architecture: amd64
image.description: Openwrt 23.05 amd64 (20240115_11:57)
image.os: Openwrt
image.release: "23.05"
image.serial: "20240115_11:57"
image.type: squashfs
image.variant: default
volatile.base_image: f17085e23771357cdf5e06d99c418707dfdeb0c40a50a97602f2ad7d35ef6d86
volatile.cloud-init.instance-id: 6463fddd-1c48-4ebd-a286-c1be00c19e1b
volatile.eth0.host_name: enp2s0
volatile.eth0.last_state.created: "false"
volatile.eth0.last_state.hwaddr: 60:be:b4:02:59:1c
volatile.eth0.last_state.mtu: "1500"
volatile.eth1.host_name: enp3s0
volatile.eth1.last_state.created: "false"
volatile.eth1.last_state.hwaddr: 60:be:b4:02:59:1d
volatile.eth1.last_state.mtu: "1500"
volatile.eth2.host_name: enp4s0
volatile.eth2.last_state.created: "false"
volatile.eth2.last_state.hwaddr: 60:be:b4:02:59:1e
volatile.eth2.last_state.mtu: "1500"
volatile.eth3-wan.host_name: enp5s0
volatile.eth3-wan.last_state.created: "false"
volatile.eth3-wan.last_state.hwaddr: 60:be:b4:02:59:1f
volatile.eth3-wan.last_state.mtu: "1500"
volatile.idmap.base: "0"
volatile.local-dmz.host_name: veth56b86216
volatile.local-dmz.hwaddr: 00:16:3e:95:05:01
volatile.local-iot.host_name: veth9062c426
volatile.local-iot.hwaddr: 00:16:3e:71:5d:f4
volatile.local-lan.host_name: veth46767acc
volatile.local-lan.hwaddr: 00:16:3e:4b:a4:cb
volatile.local-services.host_name: veth318a27d2
volatile.local-services.hwaddr: 00:16:3e:39:54:b9
volatile.local-untrusted.host_name: veth6ea55423
volatile.local-untrusted.hwaddr: 00:16:3e:f7:cb:2e
volatile.uuid: a3099060-8bf3-4a6e-8e30-f9d841c3d478
volatile.uuid.generation: a3099060-8bf3-4a6e-8e30-f9d841c3d478
devices: {}
- router
victoitor@router-server:~$ incus profile show router
boot.autostart: "true"
boot.autostart.priority: "10"
description: Default router profile
nictype: physical
parent: enp2s0
eth1:
nictype: physical
parent: enp3s0
eth2:
nictype: physical
parent: enp4s0
eth3-wan:
nictype: physical
parent: enp5s0
local-dmz:
network: dmz
local-iot:
network: iot
local-lan:
nictype: bridged
parent: br0
local-services:
network: services
local-untrusted:
network: untrusted
pool: default
This is how the interfaces look like inside and outside the container.
victoitor@router-server:~$ incus exec openwrt -- ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq master br-base state DOWN qlen 1000
link/ether 60:be:b4:02:59:1c brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master br-base state UP qlen 1000
link/ether 60:be:b4:02:59:1d brd ff:ff:ff:ff:ff:ff
4: eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq master br-base state DOWN qlen 1000
link/ether 60:be:b4:02:59:1e brd ff:ff:ff:ff:ff:ff
5: eth3-wan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 1000
link/ether 60:be:b4:02:59:1f brd ff:ff:ff:ff:ff:ff
inet 192.168.0.7/24 brd 192.168.0.255 scope global eth3-wan
inet6 fe80::62be:b4ff:fe02:591f/64 scope link
6: br-dmz: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
link/ether 00:16:3e:95:05:01 brd ff:ff:ff:ff:ff:ff
inet 10.0.4.1/24 brd 10.0.4.255 scope global br-dmz
inet6 fe80::62be:b4ff:fe02:591c/64 scope link
7: br-base: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
8: br-base.14@br-base: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-dmz state UP qlen 1000
9: br-guest: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
inet 10.0.3.1/24 brd 10.0.3.255 scope global br-guest
10: br-base.13@br-base: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-guest state UP qlen 1000
11: local-dmz@br-iot: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-dmz state UP qlen 1000
12: br-iot: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
link/ether 00:16:3e:71:5d:f4 brd ff:ff:ff:ff:ff:ff
inet 10.0.2.1/24 brd 10.0.2.255 scope global br-iot
13: local-iot@br-base.12: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-iot state UP qlen 1000
14: br-base.12@br-base: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-iot state UP qlen 1000
15: local-lan@br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP qlen 1000
link/ether 00:16:3e:4b:a4:cb brd ff:ff:ff:ff:ff:ff
16: br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
inet 10.0.0.1/24 brd 10.0.0.255 scope global br-lan
17: local-services@br-base.10: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-services state UP qlen 1000
link/ether 00:16:3e:39:54:b9 brd ff:ff:ff:ff:ff:ff
18: br-base.10@br-base: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP qlen 1000
19: local-untrusted@br-services: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-untrusted state UP qlen 1000
link/ether 00:16:3e:f7:cb:2e brd ff:ff:ff:ff:ff:ff
20: br-services: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
inet 10.0.5.1/24 brd 10.0.5.255 scope global br-services
21: br-base.15@br-base: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-services state UP qlen 1000
22: br-untrusted: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
inet 10.0.1.1/24 brd 10.0.1.255 scope global br-untrusted
23: br-base.11@br-base: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-untrusted state UP qlen 1000
victoitor@router-server:~$ ip a
inet6 ::1/128 scope host noprefixroute
6: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether e2:da:41:4f:38:c4 brd ff:ff:ff:ff:ff:ff
inet 10.0.0.10/24 brd 10.0.0.255 scope global br0
inet6 fe80::e0da:41ff:fe4f:38c4/64 scope link
7: dmz: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:c9:b0:7a brd ff:ff:ff:ff:ff:ff
8: iot: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:2b:1b:e1 brd ff:ff:ff:ff:ff:ff
9: services: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:3b:c5:a7 brd ff:ff:ff:ff:ff:ff
10: untrusted: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:09:29:e1 brd ff:ff:ff:ff:ff:ff
12: veth56b86216@if11: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master dmz state UP group default qlen 1000
link/ether 36:63:8e:dc:e2:80 brd ff:ff:ff:ff:ff:ff link-netnsid 0
14: veth9062c426@if13: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master iot state UP group default qlen 1000
link/ether 3e:91:57:4a:da:ca brd ff:ff:ff:ff:ff:ff link-netnsid 0
16: veth46767acc@if15: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
link/ether 7e:6d:e6:c1:fb:8d brd ff:ff:ff:ff:ff:ff link-netnsid 0
18: veth318a27d2@if17: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master services state UP group default qlen 1000
link/ether 22:1f:69:8a:a6:e6 brd ff:ff:ff:ff:ff:ff link-netnsid 0
20: veth6ea55423@if19: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master untrusted state UP group default qlen 1000
link/ether 7e:a0:e1:cf:f0:4d brd ff:ff:ff:ff:ff:ff link-netnsid 0
As I mentioned, everything works fine until there is an attempt to restart the container, in which case it fails to start. The following was obtained by running incus exec openwrt -- reboot. But something similar occurs when I try incus restart openwrt.
victoitor@router-server:~$ incus list
| openwrt | STOPPED | | | CONTAINER | 0 |
victoitor@router-server:~$ incus start openwrt
Error: Failed to start device "eth1": Parent device 'enp3s0' doesn't exist
Try `incus info --show-log openwrt` for more info
victoitor@router-server:~$ incus info --show-log openwrt
Status: STOPPED
Type: container
Created: 2024/01/15 17:12 -03
Last Used: 2024/01/16 13:51 -03
Log:
2: enp2s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
3: phys20DyIm: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
altname enp3s0
4: physjGqQYH: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
altname enp4s0
5: physgu2bpE: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
altname enp5s0
6: br0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
7: dmz: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
8: iot: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
9: services: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
10: untrusted: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
This time the naming change happened to enp3s0 up to enp5s0, but not to enp2s0. Sometimes the naming change happens to just one interface (usually always happens to enp5s0).
Is this a bug or is there something odd with my setup?
