LVM storage problem - all container stopped and doesn't start anymore after switch to core20
Hello, I have a huge problem: all containers stopped and doesn’t start anymore.
When I try to start a container I have this error:
Error: Failed preparing container for start: Failed to activate LVM logical volume "/dev/pool_0/containers_iceCast": Failed to run: lvchange --activate y --ignoreactivationskip /dev/pool_0/containers_iceCast: Volume group "pool_0" not found
  Cannot process volume group pool_0
But with vgs/lvs commands I see vg and lv volumes.
Some one have experienced this kind of troubles?
esosan
(I have also filled a issue on GitHub)
Please can you show the output of:
sudo lvs
lxc storage ls
lxc storage show <lvm pool name>
Also, what version of LXD are you running?
hi tomp, I’m using 4.15.
here the outputs
  containers_gdg            pool_0    -wi------k   3.00g
  containers_git            pool_0    -wi------k   3.00g
  containers_iceCast        pool_0    -wi------k   3.00g
  containers_m--clamav      pool_0    -wi------k   3.00g
  containers_m--clamavOLD   pool_0    -wi------k   3.00g
  containers_m--dcc         pool_0    -wi------k   3.00g
  containers_m--dcot        pool_0    -wi------k   3.00g
  containers_m--pfix        pool_0    -wi------k   3.00g
  containers_m--spam18      pool_0    -wi------k   3.00g
  containers_mysql          pool_0    -wi------k   3.00g
  containers_named          pool_0    -wi------k   3.00g
  containers_owncloud       pool_0    -wi------k   3.00g
  containers_rCube          pool_0    -wi------k   3.00g
  containers_rCube14        pool_0    -wi------k   3.00g
  containers_redis          pool_0    -wi------k   3.00g
  containers_solr           pool_0    -wi------k   3.00g
  containers_www--ext       pool_0    -wi------k   3.00g
  containers_www--std       pool_0    -wi------k   3.00g
  containers_wwwHurdega     pool_0    -wi------k   3.00g
  custom_default_git_data   pool_0    -wi------k   3.00g
  custom_default_data       pool_OC   -wi------k 193.00g
  custom_default_solrData   pool_data -wi------k <11.18g
  custom_default_vmail_data pool_data -wi------k <29.32g
  custom_default_www_audio  pool_data -wi------k   5.00g
  home                      vg        -wi-ao---- <19.53g
  lxc_pool00                vg        -wi-a-----  60.00g
  lxc_pool01                vg        -wi-a-----  20.00g
  lxc_poolOC00              vg        -wi-a----- 220.00g
  lxc_pooldata00            vg        -wi-a-----  50.00g
  lxc_pooldata01            vg        -wi-a-----  50.00g
lxc storage ls
|   NAME    | DRIVER |                     SOURCE                     | DESCRIPTION | USED BY |
| default   | dir    | /var/snap/lxd/common/lxd/storage-pools/default |             | 0       |
| pool0     | lvm    | pool_0                                         |             | 21      |
| poolOC    | lvm    | pool_OC                                        |             | 1       |
| pool_DATA | lvm    | pool_data                                      |             | 3       |
lxc storage show pool0
  lvm.use_thinpool: "false"
  lvm.vg_name: pool_0
  source: pool_0
  volatile.initial_source: pool_0
  volume.block.filesystem: xfs
  volume.size: "3221225472"
driver: lvm
- /1.0/instances/gdg
- /1.0/instances/git
- /1.0/instances/iceCast
- /1.0/instances/m-clamav
- /1.0/instances/m-clamavOLD
- /1.0/instances/m-dcc
- /1.0/instances/m-dcot
- /1.0/instances/m-pfix
- /1.0/instances/m-spam18
- /1.0/instances/mysql
- /1.0/instances/named
- /1.0/instances/owncloud
- /1.0/instances/rCube
- /1.0/instances/rCube14
- /1.0/instances/redis
- /1.0/instances/solr
- /1.0/instances/www-ext
- /1.0/instances/www-std
- /1.0/instances/wwwHurdega
- /1.0/profiles/default
- /1.0/storage-pools/pool0/volumes/custom/git_data
status: Created
locations:
- none
And the output of sudo vgs too please.
Also can you try this:
sudo snap set lxd lvm.external=true
sudo systemctl reload snap.lxd.daemon
This will get LXD to use your host’s lvm tools rather than the bundled snap ones.
What host OS and version are you using btw?
  VG        #PV #LV #SN Attr   VSize    VFree
  pool_0      2  20   0 wz--n-   79.99g  19.99g
  pool_OC     1   1   0 wz--n- <220.00g <27.00g
  pool_data   2   3   0 wz--n-   99.99g <54.50g
  vg          1   6   0 wz--n-   <1.80t  <1.39t
ubuntu 18.04
I have try, and now the containers are all running. but there is a new problem, no one have an assigned ip.
OK cool, well that’s interesting that that allowed them to start.
Can you show the output of sudo lvs again now, and also can you lxc shell <instance> ok into one of the containers?
  LV                        VG        Attr       LSize   Pool Origin Data%  Meta%  Move Log Cpy%Sync Convert
  containers_gdg            pool_0    -wi-ao---k   3.00g
  containers_git            pool_0    -wi-ao---k   3.00g
  containers_iceCast        pool_0    -wi-ao---k   3.00g
  containers_m--clamav      pool_0    -wi-ao---k   3.00g
  containers_m--dcot        pool_0    -wi-ao---k   3.00g
  containers_m--pfix        pool_0    -wi-ao---k   3.00g
  containers_m--spam18      pool_0    -wi-ao---k   3.00g
  containers_mysql          pool_0    -wi-ao---k   3.00g
  containers_named          pool_0    -wi-ao---k   3.00g
  containers_owncloud       pool_0    -wi-ao---k   3.00g
  containers_rCube          pool_0    -wi-ao---k   3.00g
  containers_redis          pool_0    -wi-ao---k   3.00g
  containers_solr           pool_0    -wi-ao---k   3.00g
  containers_www--std       pool_0    -wi-ao---k   3.00g
  containers_wwwHurdega     pool_0    -wi-ao---k   3.00g
  custom_default_git_data   pool_0    -wi-ao---k   3.00g
  custom_default_data       pool_OC   -wi-ao---k 193.00g
  custom_default_solrData   pool_data -wi-ao---k <11.18g
  custom_default_vmail_data pool_data -wi-ao---k <29.32g
  custom_default_www_audio  pool_data -wi-ao---k   5.00g
  lxc_pool00                vg        -wi-ao----  60.00g
  lxc_pool01                vg        -wi-ao----  20.00g
  lxc_poolOC00              vg        -wi-ao---- 220.00g
  lxc_pooldata00            vg        -wi-ao----  50.00g
lxc shell works!
now it’s just the network the problem…
Can you show output of lxc config show <instance> --expanded for one of the problem instances.
Then also show lxc network show <network> for the network that the instance is connected to.
Also can you show the output of ip a and ip r from the LXD host and inside one of the problem instances.
ips are redacted…
  boot.autostart: "true"
  boot.autostart.priority: "1000"
  image.architecture: amd64
  image.description: ubuntu 18.04 LTS amd64 (release) (20190212.1)
  image.label: release
  image.os: ubuntu
  image.release: bionic
  image.serial: "20190212.1"
  image.version: "18.04"
  volatile.base_image: 35f6bff57c250208c6dc73445eefe8c1020853a1bc8571ebd8bfb1fe3a239504
  volatile.eth0.host_name: veth3515a489
  volatile.eth0.hwaddr: 00:16:3e:fa:70:ab
  volatile.idmap.base: "0"
  volatile.idmap.current: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
  volatile.idmap.next: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
  volatile.last_state.idmap: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
  volatile.uuid: f5e3b6f5-7059-4995-999e-4c5841dfceee
  bind_4_tcp:
    bind: host
    connect: tcp:10.4.43.176:53
    listen: tcp:##.##.##.##:53
    nat: "true"
    type: proxy
  bind_4_udp:
    bind: host
    connect: udp:10.4.43.176:53
    listen: udp:##.##.##.##:53
    nat: "true"
    type: proxy
  bind_6_tcp:
    bind: host
    connect: tcp:[fd42:26ae:9c2f:e23:216:3eff:fefa:70ab]:53
    listen: tcp:[##:##:#:#::#]:53
    nat: "true"
    type: proxy
  bind_6_udp:
    bind: host
    connect: udp:[fd42:26ae:9c2f:e23:216:3eff:fefa:70ab]:53
    listen: udp:[##:##:#:#::#]:53
    nat: "true"
    type: proxy
    ipv4.address: 10.4.43.176
    ipv6.address: fd42:26ae:9c2f:e23:216:3eff:fefa:70ab
    nictype: bridged
    parent: lxdbr0
    pool: pool0
lxc network show lxdbr0
ipv4.address: 10.4.43.1/24
ipv4.nat: “true”
ipv6.address: fd42:26ae:9c2f:e23::1/64
ipv6.nat: “true”
raw.dnsmasq: |
auth-zone=lxd
dns-loop-detect
description: “”
type: bridge
managed: true
status: Created
locations:
- none
Cool thanks. And what does sudo ps aux | grep dnsmasq show?
Also sudo ss -ulpn?
Can you also show sudo grep /var/snap/lxd/common/lxd/logs/lxd.log dnsmasq please
LXC HOST
ip a
inet6 ::1/128 scope host
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq state UP group default qlen 1000
link/ether 00:25:90:79:85:4a brd ff:ff:ff:ff:ff:ff
inet 46.105.121.211/24 brd 46.105.121.255 scope global enp1s0
inet6 2001:41d0:2:e8d3::1/128 scope global
inet6 fe80::225:90ff:fe79:854a/64 scope link
3: enp2s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 00:25:90:79:85:4b brd ff:ff:ff:ff:ff:ff
4: wgclient_home: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
link/none
inet 10.127.10.12/24 scope global wgclient_home
5: lxdbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:97:44:03 brd ff:ff:ff:ff:ff:ff
inet 10.4.43.1/24 scope global lxdbr0
inet6 fd42:26ae:9c2f:e23::1/64 scope global
inet6 fe80::216:3eff:fe97:4403/64 scope link
7: vethae7df84d@if6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 5a:72:a1:27:14:04 brd ff:ff:ff:ff:ff:ff link-netnsid 0
9: veth3515a489@if8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether ea:4d:8a:2c:91:14 brd ff:ff:ff:ff:ff:ff link-netnsid 1
11: veth11bb0b31@if10: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 02:00:0e:6e:61:f2 brd ff:ff:ff:ff:ff:ff link-netnsid 2
13: veth58fde0b5@if12: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether e6:30:b7:ae:2f:e0 brd ff:ff:ff:ff:ff:ff link-netnsid 3
15: veth982cdf44@if14: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 36:82:ef:bb:05:c1 brd ff:ff:ff:ff:ff:ff link-netnsid 4
17: veth712d0c5b@if16: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 4e:6b:12:f1:96:56 brd ff:ff:ff:ff:ff:ff link-netnsid 5
19: veth36f55459@if18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether fa:d4:b5:f3:55:52 brd ff:ff:ff:ff:ff:ff link-netnsid 6
21: veth4bd7e789@if20: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether c6:bb:34:17:72:56 brd ff:ff:ff:ff:ff:ff link-netnsid 7
23: veth97903699@if22: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 9a:1a:2f:66:9d:de brd ff:ff:ff:ff:ff:ff link-netnsid 8
25: vethcb7e14a3@if24: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether a2:a2:a7:da:18:13 brd ff:ff:ff:ff:ff:ff link-netnsid 9
27: vethb07621eb@if26: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 46:aa:78:14:c8:58 brd ff:ff:ff:ff:ff:ff link-netnsid 10
29: vethd6fe5eba@if28: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 16:59:31:6a:1b:ca brd ff:ff:ff:ff:ff:ff link-netnsid 11
31: vetheb147d01@if30: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 32:d5:14:1c:65:71 brd ff:ff:ff:ff:ff:ff link-netnsid 12
33: veth4c1f23ac@if32: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether d6:1c:fa:c9:c1:2d brd ff:ff:ff:ff:ff:ff link-netnsid 13
35: vethfe8aae29@if34: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 9e:16:f1:80:1a:a5 brd ff:ff:ff:ff:ff:ff link-netnsid 14
ip r
default via ... dev enp1s0 proto static
10.4.43.0/24 dev lxdbr0 proto kernel scope link src 10.4.43.1
10.127.10.0/24 dev wgclient_home proto kernel scope link src 10.127.10.12
.../24 dev enp1s0 proto kernel scope link src 46.105.121.211
.../24 dev wgclient_home scope link
LXC INSTANCE
ip a
8: eth0@if9: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:fa:70:ab brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::216:3eff:fefa:70ab/64 scope link
ip r
nothing
root 7438 0.0 0.0 13144 1096 pts/0 S+ 11:17 0:00 grep --color=auto dnsmasq
it’s not started?
ss -ulpn
    State     Recv-Q      Send-Q            Local Address:Port            Peer Address:Port
    UNCONN    0           0                       0.0.0.0:58406                0.0.0.0:*
    UNCONN    0           0                     127.0.0.1:53                   0.0.0.0:*         users:(("named",pid=1921,fd=518),("named",pid=1921,fd=517),("named",pid=1921,fd=516),("named",pid=1921,fd=515),("named",pid=1921,fd=514),("named",pid=1921,fd=513),("named",pid=1921,fd=512))
    UNCONN    0           0                 127.0.0.53%lo:53                   0.0.0.0:*         users:(("systemd-resolve",pid=1647,fd=12))
    UNCONN    0           0                          [::]:58406                   [::]:*
    UNCONN    0           0                         [::1]:53                      [::]:*         users:(("named",pid=1921,fd=525),("named",pid=1921,fd=524),("named",pid=1921,fd=523),("named",pid=1921,fd=522),("named",pid=1921,fd=521),("named",pid=1921,fd=520),("named",pid=1921,fd=519))
grep dnsmasq /var/snap/lxd/common/lxd/logs/lxd.log
t=2021-06-17T10:50:21+0200 lvl=warn msg=“Skipping AppArmor for dnsmasq due to raw.dnsmasq being set” driver=bridge name=lxdbr0 network=lxdbr0 project=default
t=2021-06-17T10:50:22+0200 lvl=eror msg=“The dnsmasq process exited prematurely” driver=bridge err=“Process exited with non-zero value 1” network=lxdbr0 project=default
