We often have new contributors ask us about ideas for initial contributions to
our projects. To accommodate that, we use an Easy label in our Github issues
to indicate what we feel are good starting points for contributors.
Below is an up to date list of those issues across all our projects as well as
an indication as to whether they’ve been assigned to somebody already.
If you’d like to work on one of those, just comment in the Github issue, we’ll
assign it to you and we’ll answer any question you may have as you work on it.
Issues
lxc/distrobuilder
- –compression should apply to both metadata and data tarballs
Opened since: 2025-10-12 21:01:24+00:00
lxc/incus
- Cleanup command descriptions
Opened since: 2026-01-30 08:04:13+00:00
Assignee: bensmrs
Milestone: later - Snapshot retention policy (instances and storage volumes)
Opened since: 2023-08-28 14:44:20+00:00
Assignee: bensmrs
Labels: Documentation, API
Milestone: soon
lxc/incus-os
- Implement OpenMetrics
Opened since: 2026-01-19 15:48:24+00:00
Assignee: Triiltz
Milestone: 2027.02
lxc/incus-ui
- Branding Customization
Opened since: 2026-11-06 18:18:06+00:00
Milestone: v0.1
lxc/lxc
- config/init/common/lxc-containers.in: bogus startup
Opened since: 2026-03-11 23:19:51+00:00 - Unprivileged container: Failed to mount rootfs
Opened since: 2021-02-13 09:30:34+00:00
Assignee: chackoj-1204
Labels: External, Documentation - lxc-attach --rcfile: original config file is loaded before given config file
Opened since: 2021-02-05 09:05:44+00:00
Labels: Bug - Update lxc-checkconfig, to reflect new NFT support.
Opened since: 2020-03-10 16:08:21+00:00
Labels: Feature - Document mount order
Opened since: 2019-04-12 00:12:32+00:00
Labels: Feature - Request: provide AppArmor profile for lxc-user-nic
Opened since: 2018-09-19 02:26:56+00:00
Labels: Feature - Cleanup error handling
Opened since: 2018-07-16 12:51:13+00:00
Labels: Feature - ZFS filesystems must be created with exec=on
Opened since: 2015-11-13 21:29:12+00:00
lxc/lxcfs
- /proc/stat: Virtualize process counters
Opened since: 2024-07-12 10:48:42+00:00
Labels: Bug - /proc/diskstats: Handle cgroup2
Opened since: 2024-06-21 19:38:32+00:00
Labels: Bug - FUSE: Check libfuse version during live upgrade
Opened since: 2024-06-18 14:32:42+00:00
Assignee: mihalicyn
Labels: Bug - Missing error handlings for pthread_mutex_lock
Opened since: 2021-12-14 02:45:32+00:00
Labels: Maybe - fuzzing: integrate and setup with https://github.com/google/oss-fuzz
Opened since: 2020-09-04 11:12:10+00:00
Labels: Feature
lxc/lxcri
- Improve debugging.
Opened since: 2021-06-10 14:22:01+00:00
Assignee: r10r
Labels: enhancement, easy - Fix signal (SIGINT) handling when running kubectl with terminal attached
Opened since: 2021-06-10 14:05:58+00:00
Assignee: r10r
Labels: bug, easy - Add SELinux support.
Opened since: 2021-02-12 19:03:56+00:00
Labels: easy
lxc/terraform-provider-incus
- The file block in incus_instance doesn’t allow to upload binary file
Opened since: 2026-05-17 17:24:26+00:00 - Plan succeeds but apply fails when adding storage buckets feature to an existing non-empty project
Opened since: 2026-03-31 12:02:25+00:00 - Add import functionality to
incus_serverresource
Opened since: 2025-11-24 12:26:15+00:00 - Extend file block functionality in the instance resource to provide more granular control
Opened since: 2024-06-26 21:01:21+00:00
